VWVortex.com - ESP On or Off?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 48
    Thread: ESP On or Off?
    1. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      2009 Passat Wagon 2.0T; 2014 TSI Passat Sedan
      01-17-2011 12:30 AM #1
      With my B6 '09 wagon, when I turn off ESP by pressing the console button, the icon flashes on the dash display and then goes out. Is this working correctly? I would think it would flash when ESP is on and it has encountered slipping and corrected. With the button set to off, I would think the light would stay lit on the dash?
    2. Member Track5tar's Avatar
      Feb 16th, 2010
      Salt Lake City, UT and Las Vegas, NV
      Mine: 2010 Passat Hers: 2012 B8 A4
      01-17-2011 01:33 AM #2
      Quote Originally Posted by gkamieneski View Post
      When u push the button hold it for a few secs and it would confirm on or off on mfd
      Unitronic > APR Switched from APR to UNI and never looking back
      CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
    3. Member 08GraniteGreenPassat's Avatar
      May 15th, 2009
      2010 VW Passat DSG TSI KO4
      01-17-2011 02:52 AM #3
      What is this you speak of?
      I've never hear of this. I thought on the 08.5 and above passats when you hit the esp button it just turned the traction control portion of esp off while still having the light flash annoyingly.
      2002 Passat GLX Candy White gone 2006 Jetta 2.5 Platinum Gray gone 2008 Passat 2.0t Granite Green gone 2010 Passat White Gold Current
    4. Member
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      01-17-2011 02:59 AM #4
      on my 08, the ESP light stays lit on the instrument cluster when I turn it off.
      the Passat uses a TRW system for the ESP components, unlike the Golf/Jettas getting the ATE system.
    5. Member 08GraniteGreenPassat's Avatar
      May 15th, 2009
      01-17-2011 03:02 AM #5
      You probably have an fsi engine also, which means your car is an early build 08.
    6. Member
      May 10th, 2010
      North Jersey
      01-17-2011 03:23 AM #6
      Bentley manual still lists TRW for the ABS/ESP controller for the CCTA engines.
    7. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      01-17-2011 03:31 PM #7
      Mine is a 2009 wagon with the TSI engine. I am trying to make sure ESP is working correctly because this weekend it did not seem too stable in light snow. I also noticed that the OEM Contis were down to 6/32 all around before the 20k rotation. Not my experience with the Michelins on my Jetta or other Contis I have had.
      May 10th, 2010
      North Jersey
      01-17-2011 04:00 PM #8
      TSI's in the B6 Passat is the CCTA engine code
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      01-17-2011 08:57 PM #9
      If your ESP switch light on the center console is on then it means you turned off the system.
    10. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      01-17-2011 10:35 PM #10
      Quote Originally Posted by Boosted2003! View Post
      I guess that is my point, when I switch ESP off from the center console (there is no light in the console switch), the icon on the dash flashes. On my Jetta when I turn ESP off with the switch on the console the icon in the dash stays lit, not flashing. It seems to me the Passat wagon should be the same way, turn ESP off, the light stays illuminated in the dash.
    11. Member wiredvw's Avatar
      Jan 17th, 2006
      Minneapolis, MN
      2010 VW Passat B6 Wagon
      01-17-2011 11:20 PM #11
      I tried the same thing the other night with the same results. I just got a B6 wagon back in Sept after selling a 2000 Jetta (w/ traction control). The Jetta light would stay on if you turned the system off. The Passat light flashed a few times then stayed off. I floored it a few times to see what the deal was...it certainly was off, but didn't like that there was no way to tell if the system was on or off other than intentionally getting the fronts to break loose (easy enough when they're covered in snow). I will try and remember to ask the service tech tomorrow when I bring my car in to have the hvac looked at...the is only air flow on full blast (4).
      May 10th, 2010
      North Jersey
      01-17-2011 11:30 PM #12
      Quote Originally Posted by wiredvw View Post
      the N24 resistor is toast already. Cheap warranty repair.
    13. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      01-18-2011 11:07 AM #13
      Quote Originally Posted by BsickPassat View Post
      Are you saying the idiot light should stay on in the dash (not flash then go out) when you turn ESP off on the console. I need to go in this week for 20K maintenance, so I would like to be able to tell them what to look for.
    14. Member
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      01-18-2011 11:17 AM #14
      i believe his post for the resistor was for the hvac fan issue.
      in my passat when ESP is off the light with the pic of the car is lit up in the dash display there is no light on the esp button on the console... wen esp is on there are no lights on on the dash unless u lose traction then the light will flicker on the dash display and then go off once u regain traction
      Unitronic Stage III w/ PT5558BB Turbo Unitronic.ca, IE HPFP, 3in B&B TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC/Forge SS, 42Draft Design CNC Shifter bushings, BFI stage 2 motor/tranny mounts, 034 Dogbone, KW V2 coilovers, Nuespeed 25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
    15. Member
      May 10th, 2010
      North Jersey
      01-18-2011 11:20 AM #15
      It should stay on when you disable ESP. For kicks, in the snowy parking lot I was doing scandinavian flicks to force the ESP to kick in (like the ATE MK60's on the Golf/Jetta/GTI/GLI), and didn't kick in with the ESP off.
      From what I can tell, VW is still using a TRW 440 ABS/ESC controller on the 09+.
      Yep, have the dealership check it out.
    16. Member Track5tar's Avatar
      Feb 16th, 2010
      01-18-2011 11:29 AM #16
      I have a CBFA.. Bought it in Vegas
    17. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      01-18-2011 01:38 PM #17
      I am certainly going to have the dealer check it out. Those of you out there with '09s and newer, does the light stay on in the dash when you turn off ESP? Seems it does with '08s and earlier and it certainly does with my '06 Jetta.
      Could be there is a problem with all the '09s and newer?
    18. Member Track5tar's Avatar
      Feb 16th, 2010
      01-18-2011 01:54 PM #18
      I'll check mine in a few hours
    19. Member
      Mar 10th, 2009
      01-18-2011 02:00 PM #19
      Quote Originally Posted by Bill6211789 View Post
      My 06 6mt the light stays illuminated on the cluster also the button(ESP OFF) on the center console stays illuminated.
      I know the 09 GTI's when you turned off the ESP. The button near the shifter would illuminate and cluster light would flash at you.
    20. Member
      Dec 11th, 2009
      Clifton Park, NY
      2006 VW BT Passat
      01-18-2011 02:40 PM #20
      yes! i forgot tht the little off does illuminate on the button too
    21. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      01-18-2011 02:47 PM #21
      Thanks everyone, but trying to keep this specific to '09 and newer Passats as it appears there are some behavioral differences in the idiot lights for the newer models.
    22. Member low_passat's Avatar
      Sep 11th, 2010
      Goodyear, AZ
      '07 B6 Passat
      01-18-2011 03:03 PM #22
      Hate to state the obvious, but have you checked your owners manual? I would think it's explained in there.
      2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
    23. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      01-18-2011 06:04 PM #23
      Yup...not handled too well in there. Those of us with '09s and newer just want to know how the idiot light behaves when you turn off ESP. My wife makes the point, how do I know if it is on or off, if I turn it off and it flashes for about 10 seconds on the dash then stops illuminating? What becomes the difference there and ESP being on altogether?
    24. Member wiredvw's Avatar
      Jan 17th, 2006
      Minneapolis, MN
      01-18-2011 11:39 PM #24
      Quote Originally Posted by B6 Passat View Post
      Nice try, but it's not explained that well. So I tried turning off ESP again after getting my car back from the dealership, it was a resistor (this one better last longer than 4 months!) and it did more this time around. When I press the ESP button the MFD displayed "TCS Off" and the light blinked and continued blinking while the system was off. The button did not illuminate or visually depress. When I press the ESP again the MFD display said "TCS On" and the light goes off. When I let loose in the snow with ESP off the light flashed vigorously, but the system did not engage...
      Hope that helps.
    25. Member gkamieneski's Avatar
      Jun 7th, 1999
      New Hampshire
      01-19-2011 08:23 AM #25
      Hope that helps.
      Doesn't the light flash vigorously when ESP is on and you encounter slippery conditions as well?
