Results 1 to 24 of 24
Thread: 9W7 BT speech prompt volume
  1. Member btitus's Avatar
    Nov 8th, 2010
    2011 GTI Autobahn 4dr, 2011 A3 TDI
    01-18-2011 07:16 AM #1
    x-posted from the MKVI forum -- has anyone been able to successfully change the default volume on the BT voice prompts?
    I got my VCDS cable from Ross-Tech the other day and have been playing around making all the usual updates.
    One thing I'd really like to do however, is change the default volume of the voice dialing prompts on the 9W7 bluetooth module. I did see a post or two mentioning this, and in 77-telephone adaptation there is a channel called "Base Volume of Speech Output." The default value is "4.76837e-007 db" (basically, 0), and I was able to change this to different values. I tried -2, -3, and -6, and although the coding was accepted, there does not seem to be any difference in the volume.
    Just wondering if anyone has been able to successfully change the speech volume, or if there is a different/additional setting I need to make in order for it to take effect.
    TIA!
    To clarify: yes, you can change the prompt volume with the in-car volume controls, but the problem is that the voice prompts and the call volume are tied to the same control. What ends up happening is that you have to turn the volume down during voice prompts (so you don't break your eardrums), then you have to quickly turn it up when the call connects. Call volume on the phone itself (Moto Droid) is maxed.
  2. Member Branman's Avatar
    Oct 5th, 2004
    DE
    2011 GTI ko4'd
    01-18-2011 07:20 AM #2
    nice move. If anyone can figure out a fix its the genius guys at ross-tech.
    11 mk6 gti APR KO4 12.0@119 GoAPR
    Jul 27th, 2007
    Ottawa, Canada
    07 Rabbit, 10 Tiguan, 1928 Chev, 02 Dakota
    01-19-2011 12:20 PM #3
    There are two separate adaptation channels, one for each volume, but for the life of me, can't get the volume for the voice commands to behave. I set it lower and it will only stay lower for the current session. Once the car is turned off and back on the volume raises again, but the stored value remains the same. i gave up after many attempts.
  4. Member btitus's Avatar
    Nov 8th, 2010
    01-19-2011 01:32 PM #4
    Quote Originally Posted by shawng View Post
    Well, that's disheartening. Same experience here.
    Jul 27th, 2007
    Ottawa, Canada
    01-19-2011 03:28 PM #5
    I have it set at -6 db and it is perfect... until I turn it off and on. I even tried setting the BT audio higher so that they would be closer to balanced and then I could just turn it down at the radio, but oh no, that setting is at max already. This is a no win situation at this time unless someone can figure out the voodoo.
  6. Member btitus's Avatar
    Nov 8th, 2010
    01-19-2011 03:35 PM #6
    Yeah, I was hoping someone would know of some other bit that has to be set in order for the stored value to be used. It's odd that it retains the value, but doesn't seem to pay attention to it on restart.
  7. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    01-19-2011 08:02 PM #7
    This was an issue for shawng:
    http://forums.vwvortex.com/showthrea...-coding-needed
    I retrofitted that module and I don't have any functionality concerns with it. Some modules will default adaptation values after the diagnostic session has ended. My 9W2 (base phone module) was like that in a few channels. Some radios will do the same and adaptation is only for diagnosis.
    Bump this back up with a complete Auto-Scan after the weekend and we can compare notes and adaptation values.
    I primarily use a Droid 2 with this module. Unlike the old 9W2 phone module, it can't seem to sync 2 phones at one time?
    Dana Marie
    P.S. No Scan = No Soup
  8. Member Branman's Avatar
    Oct 5th, 2004
    DE
    2011 GTI ko4'd
    01-19-2011 08:55 PM #8
    Dana, do you have the same issue with the volume of the voice command too loud?
  9. Member btitus's Avatar
    Nov 8th, 2010
    01-23-2011 04:30 PM #9
    Quote Originally Posted by Dana @ Ross-Tech View Post
    Here's my autoscan; thanks for looking into this.
    VCDS Version: Release 10.6.3
    Data version: 20101206
    Sunday,23,January,2011,15:17:43:01124
    Chassis Type: 7N0
    Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55 56
    62 72 77
    VIN: WVWGV7AJ0BW045634
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
    Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
    Component: 2.0l R4/4V TFSI 0020
    Revision: AAH17--- Serial number:
    Coding: 0403010A18070160
    Shop #: WSC 01357 011 00200
    VCID: 74C90B656E3D
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
    Component: ESP MK60EC1 H30 0106
    Revision: 00H30001
    Coding: 114B600C492600FF881106E7921D0041B70800
    VCID: 74C90B656E3D
    Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
    Part No SW: 5K0 959 434 HW: 5K0 959 434
    Component: VWKESSYPQ35GP 082 0707
    Revision: 00082000 Serial number: 0000000000
    Coding: 030C0C
    ASAM Dataset: EV_KESSY_PQ35GP A01010
    ROD: EV_KESSY_PQ35GP_VW36.rod
    VCID: F2C58D7D9429
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
    Component: Climatic H14 0305
    Revision: 00009001
    Coding: 0000001002
    ASAM Dataset: EV_Climatic A01005
    ROD: EV_Climatic_VW36.rod
    VCID: 75CF36616547
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
    Component: BCM PQ35 H 104 0615
    Revision: 00104 AE
    Coding: 6D180A3A80272AC41088008174008F84402D0086574D8DF064 802020A040
    VCID: 3A55E55D0CD9
    Part No: 1K1 955 119 F
    Component: Wischer 30061 21 0512
    Coding: 009795
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
    Component: AirbagVW10G 021 0706
    Serial number: 003C4R00LYM.
    Coding: 00003031
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3957FA5109DF
    Seat occupied recognition:
    Part No SW: 5K0 959 339 HW: 5K0 959 339
    Component: BF-Gewichtss. 007 0002
    Serial number: ---0000R--0005881J00
    Driver's Airbag Crash Sensor:
    Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME33037552ZZZL
    Passenger Side Airbag Crash Sensor:
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME34472454ZZZR
    Driver's Rear Airbag Crash Sensor:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME10076452ZZZG
    Passenger's Rear Airbag Crash Sensor:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME08265A22ZZZR
    Driver's Front Airbag Crash Sensor:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME0A1D0323ZZZ8
    Passenger's Front Airbag Crash Sensor:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME15656022ZZZ4
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
    Component: LENKS.MODUL 009 0135
    Revision: FF010036 Serial number: 20100701100382
    Coding: 100A140000
    ASAM Dataset: EV_SMLSNGVOLWS A01004
    ROD: EV_SMLSNGVOLWS_VW36.rod
    VCID: 7DDF2E415D77
    MFL:
    Part No SW: 5K0 959 542 HW: 5K0 959 542
    Component: E221__MFL-TAS H05 0010
    Coding: 820000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K6 920 971 C HW: 5K6 920 971 C
    Component: KOMBI H04 0406
    Serial number: 00000000000000
    Coding: 270D01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 354FF66125C7
    Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
    Part No SW: 7N0 907 530 HW: 1K0 907 951
    Component: J533 Gateway H27 0602
    Revision: H27 Serial number: 300610F2000772
    Coding: E9817F0650061203000002
    VCID: EDFF9E018D17
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0406
    Coding: 000007
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAF5951DBCF9
    Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
    Part No SW: 5K0 905 861 HW: 5K0 905 861
    Component: ELV-PQ35 018 0100
    Revision: 00000000 Serial number: 10000115186002
    Coding: 0100000000000000
    ASAM Dataset: EV_ELVMarquVW360UDS A01003
    ROD: EV_ELVMarquVW360UDS_VW36.rod
    VCID: EDFF9E018D17
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
    Component: SG EXT.PLAYER H13 0111
    Revision: A1001003 Serial number: 7668233083
    Coding: 020000
    VCID: 27732C29EF6B
    Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
    Part No SW: 1K0 035 274 HW: 1K0 035 274
    Component: RNS315-NAR H03 0007
    Serial number: VWZAZ2K8404850
    Coding: 040500210100000000001000
    ASAM Dataset: EV_RNS315VWNARV1UDS A01005
    ROD: EV_RNS315VWNARV1UDS.rod
    VCID: E1E7F23141CF
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
    Component: Tuer-SG 009 2151
    Coding: 0001204
    VCID: 334BC8792BB3
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 74 3001
    Revision: 00H17000
    VCID: 3147C271D1AF
    Address 47: Sound System (R12) Labels: 5K0-035-456.clb
    Part No SW: 5K0 035 456 HW: 5K0 035 456
    Component: KonzernAmp 8K H06
    Revision: -------- Serial number: BP218109098519
    ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
    ROD: EV_AudioVerst8KanalBNO1_VW36.rod
    VCID: E7F3EC29AFEB
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Component: Tuer-SG 009 2119
    Coding: 0001204
    VCID: 3245CD7DD4A9
    Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0142
    Revision: 00H04000 Serial number:
    Coding: 1446940
    VCID: 3449CB652EBD
    Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000022
    Component: AFS-Lst.-Modul r 0004
    Coding: 00000022
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
    Component: Tuer-SG 007 2101
    Coding: 0001168
    Shop #: WSC 01357 011 1012552
    VCID: 354FF66125C7
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
    Coding: 0001168
    VCID: 364DF16D38C1
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
    Component: TELEFON H05 0440
    Revision: 1B001001 Serial number: 00007668359616
    Coding: 0A00000000010100
    ASAM Dataset: UHVNA A01007
    ROD: UHVNA_VW36.rod
    VCID: 3245CD7DD4A9
    End ---------------------------------------------------------------------
  10. Member
    Jul 27th, 2007
    Ottawa, Canada
    01-23-2011 07:10 PM #10
    Same coding as mine. Is there any way to get a report of all the adaptation channels.
  11. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-23-2011 10:14 PM #11
    Quote Originally Posted by Branman View Post
    No I don't .. but that's my personal opinion. I've never had a car with voice command to compare it to either.
    Dana Marie
  12. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-23-2011 10:19 PM #12
    The newer UDS modules (like this telephone module) do not support conventional measuring blocks or adaptation channels so the control module maps are not possible. We could manually note the stored adaptation values and list them here.
    Dana Marie
  13. Member btitus's Avatar
    Nov 8th, 2010
    01-24-2011 09:45 AM #13
    Just an FYI, it doesn't really seem to be a personal preference issue -- for folks that are having the issue it's like this -- basically, when you have your system volume set at a level where you can hear your phone calls, if you engage voice command, the volume is so deafeningly loud that people outside the car can hear it.
    So, it sounds like your setup is not behaving that way.
  14. Member Branman's Avatar
    Oct 5th, 2004
    DE
    2011 GTI ko4'd
    01-24-2011 10:11 AM #14
    I personally have my BT phone in-call volume set at about 24 to hear the person very clearly. When I hit the voice control the lady comes on and is so freaking loud the speakers sound like they are gonna pop. If I turn the down the volume of the lady speaking to a normal level it will also turn down the in-call volume which then cannot be heard very well. It sounds like this is the same issue everyone is having.
  15. Member
    Jul 27th, 2007
    Ottawa, Canada
    01-24-2011 05:32 PM #15
    yup, that about sums up the issue.
    @ Dana, it is -19C outside right now and while warmer in the garage, this will have to wait. I hope someone else can do this in a warmer locale.
  16. Member btitus's Avatar
    Nov 8th, 2010
    01-24-2011 05:49 PM #16
    What actually needs to be done? Being new to VCDS, I'm not familiar with all of the terms & procedures.
  17. Member btitus's Avatar
    Nov 8th, 2010
    01-27-2011 11:41 AM #17
    bump.
    just wondering if there is anything I can do to help with researching this issue?
  18. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02-06-2011 01:40 PM #18
    Sorry for the delay. Due to the winter season I'm a little limited on car/shop time as well.
    My default was:
    http://img51.imageshack.us/img51/333...olumestock.png
    I made a bunch of changes, ending with this last night:
    http://img535.imageshack.us/img535/9...olumeafter.png
    I locked the car overnight so I believe my summary is pretty accurate, ruling out a key or sleep cycle altering the results:
    The volume of the voice command (spoken volume from the female voice) seems to have 2 settings.
    1) When the radio is Off and the button is pressed I believe the adaptation value is accurate. After the adjustment ( reducing the channel value ) I can hardly hear her voice.
    I don't normally press that button with the radio off and I will admit it was quite loud with default adaptation values.
    2) When the radio is On the volume of the telephone controls the voice command and the actual volume of the calls. My observation is that I have the Minimum Telephone Volume settings in the RNS set near the 1/4 mark. Normally I turn down the Navi and Tele volume when I am finishing up a trip or phone call, so I never had a complaint in this area.
    See if the RNS/RCD has a [Sound] button menu for Telephone volume. This seems to control the min start-up volume and increases the volume if the knob was turned below that setting. Ex: If I turn the volume off and the phone rings it starts at the 1/4 way mark I have selected there.
    I didn't try messing with this while driving, but I wouldn't doubt the speed sensitive volume (overall radio settings) would also change the telephone volume with vehicle speed.
    Dana Marie
  19. Member btitus's Avatar
    Nov 8th, 2010
    02-06-2011 03:19 PM #19
    So in scenario 1, is the phone call volume also affected by the adaptation value?
  20. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02-06-2011 04:38 PM #20
    Quote Originally Posted by btitus View Post
    I cannot comment on the call volume (since I didn't have anyone call with the radio off) but the voice command level was accurate to the adaptation value IMO.
    Dana Marie
  21. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02-06-2011 04:46 PM #21
    If you have different results let us know. I'm not calling that Correct or Fact so any comments or opinions are welcome. This is (most of) the car I'm using for these observations:
    Saturday,05,February,2011,16:28:51:03064
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 47 52 55 56
    62 72 77
    VIN: WVWHD7AJ4AWxxxxxx
    02-Auto Trans -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
    Component: BCM PQ35 H+ 103 0576
    Revision: 00103 AC
    Coding: 6E180A3E90272AC40088008554008904413D1586434D8D6064 8020200000
    VCID: 356A218D25C7
    Part No: 1K1 955 119 E
    Component: Wischer 30060 21 0501
    Coding: 009795
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
    Component: J0527 055 011
    Coding: 0001832
    VCID: 76E8E6817841
    Part No: 5K0 959 542
    Coding: 00000131
    Shop #: WSC 00000
    Part No SW: 5K6 920 970 G HW: 5K6 920 970 G
    Component: KOMBI H05 0206
    Coding: 180F00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
    VCID: 387428B932D5
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0112
    Revision: H07 01 Serial number: 230609F2001083
    Coding: ED817F06501612000002
    VCID: 69D2BDFD39FF
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 5N0 919 879 HW: 5N0 919 879
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1225223T5Q6C04
    Coding: 0000002
    VCID: FEF87EA1D071
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0140
    Revision: A1001003 Serial number: 7667440739
    Coding: 010000
    VCID: 2854F8F9E275
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 3C0 035 684 C HW: 3C0 035 684
    Component: RNS-MID H17 1040
    Serial number: VWZ6Z7H9250052
    Coding: 0C070000010000AE00
    ASAM Dataset: ------------------------- ------
    VCID: 234EEFD59B53
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Component: KonzernAmp 8K H06 0340
    Revision: -------- Serial number: BP218198607632
    VCID: E7D63BC5AFEB
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    VCID: 234EEFD59B53
    1 Fault Found:
    000 - -
    Revision: 1B001001 Serial number: 00007668766339
    Coding: 0200000000010100
    ROD: UHVNA_VW36.rod
    VCID: 32601A91D4A9
    Dana Marie
  22. Member btitus's Avatar
    Nov 8th, 2010
    06-12-2012 09:11 AM #22
    This remains the only thing that really bugs me about my car... the deafening volume of the BT lady. I assume no further discoveries have been made on how to separate the call volume from the voice control volume, but thought I would ping this thread just to see. TIA.
    2011 GTI / Autobahn / 4DR / 6MT
    APR Stage 1 Tune / Carbonio CAI
  23. Member Mr.Timewise's Avatar
    Feb 3rd, 2010
    Hawthorn Woods, IL USA
    2010 Jetta SE 2.5L Tiptronic; 2002 allroad 2.7T Tiptronic
    06-12-2012 03:10 PM #23
    Unfortunately, the BT lady volume is just not adjustable independently of the telephone reception level. No one has found a working volume offset setting just for the BT lady.
    2010 Jetta SE 2.5L Tiptronic Salsa Red
    9W7 Bluetooth | RNS-510 | Homelink sun visor | Extendable passenger sun visor | MFSW w/ paddles | Hi-line SWCM | Hi-Line MFD+ instrument cluster | Auto-dimming inside rear view mirror w/ compass | Trunk lid open switch in grab handle | Silver lens tail lights | Front & rear door warning/puddle lights
  24. n00b Civil25's Avatar
    Aug 17th, 2012
    Central Florida
    2011 JSW
    08-18-2012 11:11 AM #24
    I have the same problem, I have used multiple phones from multiple os's (android, blackberry, and ios). I get the same results with every phone that I try. When the bluetooth volume on the phone is maxed out I have to have the car's volume 3/4 to max depending on how much noise is coming in from the outside of the car. If I have the car's volume up that high when the bluetooth lady comes on I cringe from the sounds the speakers make. I have already had to have 2 speakers replaced in my 11 JSW and I am convinced it is due to this issue as I never have the radio volume above 1/4 . I just got my Ross-Tech cable yesterday so I am a bit hesitant to start messing with any of the coding right away on my own. If anyone has a fix to this i would GREATLY appreciate it! Thanks guys!
