Page 7 of 7 FirstFirst ... 3 4 5 6 7
Results 211 to 229 of 229
Thread: Flapper Switch DIY...nailed it
  1. Member Ripdubski's Avatar
    Aug 12th, 2004
    G-Vegas, SC
    08 .:R32 DBP, 01 Jetta GLS GB
    04-22-2012 11:37 AM #211
    Excellent info. Thx!
    With that then i think my solution is
    Code:
    (12)
    (11)---N321
    (14)---+---ecu
           +---/\/\/---12v
    Which is slightly different than i had before in that 11 and 14 are swapped around, but i dont think that was a problem. I fear my resistor may have been bad. I pulled it from some very old parts i had laying around. So i will get a new 1k .5w one and try again.
    that said, how can you tell its wokring if you cant hear a difference at idle? Any easy test?
    Thx!
    Ripdubski
    08 .:R32 DBP, 01 Jetta GLS 2.Slow AutoTragic GB
    Flickr - shutterfly
  2. Member Ripdubski's Avatar
    Aug 12th, 2004
    G-Vegas, SC
    04-22-2012 04:37 PM #212
    Hooked it up as in my last post. Still cant tell any difference even while driving. Unsure if its workng or not. Checked all connections, seem good. Checked resistor and voltage on ecu side of brown/lilac. Kinda of at loss at this point.
    Thx!
    Ripdubski
    Flickr - shutterfly
  3. Junior Member
    Oct 7th, 2011
    Sweden
    Mk5 R32 2007
    04-22-2012 05:03 PM #213
    Quote Originally Posted by Ripdubski View Post
    Like I said in this post:
    http://forums.vwvortex.com/showthrea...1#post73916011
    Stock:
    "* Flapper is always off in 1st and 2nd gears.
    * Flapper is off over 3500 rpms (unless engine braking)
    * Flapper is on when engine braking
    * When downshifting at higher rpms, flapper is briefly off"
    So, third gear and revs below 3500 should give you flapper closed/quiet, if stock mode.
  4. Member Ripdubski's Avatar
    Aug 12th, 2004
    G-Vegas, SC
    04-22-2012 09:07 PM #214
    Quote Originally Posted by viggen32x View Post
    Stock:
    Thx. I saw that. Ill listen more intently tomorrow. I guess the quickest tell is engine braking. If its louder when sitch is on, then it should be working. Spent too much of time on it this weekend and a little disappointed at this point.
    Thx!
    Ripdubski
    Flickr - shutterfly
  5. Member Ripdubski's Avatar
    Aug 12th, 2004
    G-Vegas, SC
    04-28-2012 09:56 PM #215
    I can *just* make out the difference in certain conditions, but mostly i cannot. I did resolve the p-code error. Turns out the fuse for the accessory socket blew at some point between wiring and testing and re-assembly. No more flapper error! Maybe aftermarket exhaust time.
    Thx!
    Ripdubski
    Flickr - shutterfly
  6. Junior Member
    Oct 7th, 2011
    Sweden
    Mk5 R32 2007
    05-06-2012 01:32 PM #216
    If you want to temporarily get louder exhaust sound inside your car, try folding the rear seat. It makes quite a difference.
  7. Junior Member UnitedGrayR32's Avatar
    Sep 12th, 2010
    Minneapolis
    2008 R32
    05-10-2012 01:42 AM #217
    I am doing a 3 way switch and need a little clarification/help. If any of my assumptions are incorrect please let me know.
    1. In my car the control wire is brown and the 12V is blue and red striped. I don't see lilac so I didn't know if that meant it could be "lilac or brown" or it was "lilac AND brown".
    2. As far as I can see from the diagrams, I should cut the brown wire and run two wires, each of these two wires is tied to the two cut ends of the brown wire.
    3. Run the two newly attached wires to the front of the .:R to the switch (in my case 3 way).
    4. If I can find a 12V source up front and a ground I should be able to wire the switch as it is in the diagram.
    5. Which end of the cut brown wire is the ECU side and which is the solenoid side? I define the brown wire directions as either up over the wheel well or down merging with the thick wire loom attached to the floor of the boot.
    Thank you!
    .:R UNITED GRAY R32 774/
    5000
  8. Junior Member
    Oct 7th, 2011
    Sweden
    Mk5 R32 2007
    05-10-2012 04:24 AM #218
    Quote Originally Posted by UnitedGrayR32 View Post
    "up over the wheel well" -> ECU
    "down merging with the thick wire loom attached to the floor of the boot." -> Solenoid
  9. Member Ripdubski's Avatar
    Aug 12th, 2004
    G-Vegas, SC
    05-10-2012 06:48 PM #219
    Link to my Carstyles one for reference, though this is were it all began.
    Flapper DIY - CarStyle4You Edition
    Thx!
    Ripdubski
    Flickr - shutterfly
  10. Member Zebrado83's Avatar
    Mar 16th, 2009
    Hyndman, PA
    93 VW Corrado 3.0L VRT / 08 VW R32 / BMW E39 540i
    06-01-2012 09:40 PM #220
    Spoken like a kid. Is it possible to cut some wires and have it loud all of the time? I just want the easiest way to make it loud!!!!!
  11. Member vdubnhead's Avatar
    Dec 29th, 2010
    KC but A2=home
    '08 gas-gargling-wookie
    06-01-2012 09:44 PM #221
    Quote Originally Posted by Zebrado83 View Post
    not sure if serious...but if you are...disconnect the vacuum tube from the flapper on the exhaust, plug it up with a golf tee...done.
    enjoy the loudness.
    http://www.performanceleds.com/
    106,400+ happy miles
  12. Member Zebrado83's Avatar
    Mar 16th, 2009
    Hyndman, PA
    06-01-2012 11:03 PM #222
    I tried that and I noticed it is still quiet at idle and in low rpms. I'm just trying to get it as loud as my brothers MKIV R32 with flapper mod. I could care less about controlling it.
  13. Banned BetaOp9's Avatar
    May 4th, 2006
    2008 VW R32 [TR #2392]
    06-01-2012 11:12 PM #223
    Buy a MKIV.
    Many have tried to reproduce the MKIV exhaust on the MKV. Not sure anyone has achieved it really. If you just want loud, there are plenty of aftermarket catbacks to achieve this...or simply delete the resonator/tampa mod it.
  14. 06-19-2012 11:15 AM #224
    Maybe I missed it somewhere but for this switch to work is the vacuum line hooked up to the flapper (like stock) or is it disconnected?
  15. Senior Member abeR's Avatar
    Sep 13th, 2002
    Joe's Garage / Chicago
    3.2 electric boogaloo bitches
    06-19-2012 11:22 AM #225
    Quote Originally Posted by jm121189 View Post
    the point of this mod is to be able to use the flapper on command, how would it work if it was disconnected?
    eat your wheaties!
  16. 06-19-2012 01:58 PM #226
    Sorry, thought the wires ran directly to the flap, now I get it.
  17. Senior Member abeR's Avatar
    Sep 13th, 2002
    06-19-2012 02:20 PM #227
    flippy flap floppity flizzo my man!
  18. Junior Member fireboy.chad's Avatar
    Oct 30th, 2012
    Arlington, WA
    2008 VW R32 Candy White
    04-15-2013 12:06 PM #228
    Where di you get your OEM look switch/button? I like the fit and finish..
  19. Member Ripdubski's Avatar
    Aug 12th, 2004
    G-Vegas, SC
    04-15-2013 08:47 PM #229
    Quote Originally Posted by fireboy.chad View Post
    http://forums.vwvortex.com/showthrea...le4You-Edition
    Thx!
    Ripdubski
    Flickr - shutterfly
