nice diy.... bud dude, clean your car lol
#1
Alright so at the request of another vortex-er, here is my own DIY for retrofitting the mk4 shift knob, boot and trim ring into your mk3
Please correct anything I may have done or typed wrong and I want to apologize for the cell phone pics but my new camera seems to have grown legs and disappeared![]()
Required tools:
Your brain
Dremel with a cutting wheel
box cutter
patience
First: Remove the plastic piece from the shift console, next inspect the trim ring around the mk4 shift boot and remove the trim ring
Next take the trim ring, place it on the paper and trace the inside making sure to keep good accuracy then cut out the center
Should look like this when done
Next tape the paper to the plastic piece that holds the boot and start cutting making sure to be very careful not to trim too much off.
then put it all together
Put it in your car and you shall have this (I will eventually be shortening the height of the shift knob)
then once it fits nicely your all done! drink afor your success
Mk4 shift knob, boot and trim ring into your mk3/mk2 DIY:
http://forums.vwvortex.com/showthrea...ng-to-your-mk3
#3
#4
I wonder if you would have to do this same process if you did a mk4 shift tower install??
#5
#7
Posted here as well . . . Nice write up none the less. . . . . ill try to edit it in as another point of the install this week. . . thanks
http://forums.vwvortex.com/showthrea...ll-Hint-Thread
http://forums.vwvortex.com/showthrea...1#post68934286
http://forums.vwvortex.com/showthrea...highlight=MkIV
#8
Thanks guys, that was my first DIY ive ever made
#10
#11
How did you affix the shift knob? I tried a zip-tie, but it wasn't tight enough. Ended up using some Gorilla glue and never had an issue afterwards.
RIP MkIII Jetta. 6 years, 160k miles and countless memories.
#12
#13
#14
Same pretty much for the mkV trim as well, just make sure whichever you use, that the shift tower can go back far enough to get into 2nd and 4th easily.
#16
#17
#19
That's a Mk4 Shift Knob?
I have the same one in my mk3. I found if out of a mk2 gti in a junkyard tho![]()
CCVW
#20
#21
i am definetly doing this... it will go nicely with all the 3.5 cabrio stuff .. thank you and nice diy
dirtbag.
PVW 9/09
#22
#23
Just got mine today.. and YES that is a tv molded to my cup holders![]()
#24
#25
#26
#29
how did you make that silver trim sits perfectly to mk3 plastic because they are not same when you look it from side ?
#30
#32
mine has clips as well but they are to weak to hold the whole knob with boot on its place :S
#33
#34
#35
