Bump
#1
Ive got a few parts leftover from my R32 Swap, some aftermarket and some OE all in good condition and still work. I am posting everything I have here, so, if you don't see it advertised I don't have it. BTW my swap can be found in my Signature below.
2001 MK4 Golf Grille $40 Shipped. The Emblem is wedged into place and it wont come out while driving or over bumps but it will come out if it is pushed or if you slam the hood, I just went ahead and got another grille.
Vibrant 1304 3.5" Round Stainless Steel Tip $30 Shipped 2.25" Inlet
MK4 GTI Used (7k Miles) Supersprint Muffler $250 Shipped.
2001 Mk4 Vr6 Used OE Pulley Set. $75 Shipped
2001 Mk4 Vr6 Used Gruven Parts Light Weight Billet Crank Pulley No key way $60 Shipped
vr6 24v ECS P/S Pulley $40 Shipped
2001 Mk4 Vr6 Used Air Box w/ K&N Drop in Filter $50 Shipped
2001 Mk4 Vr6 Used Wiper Blade Arms w/ New Lattitude Wiper Blades $25 Shipped
2001 Mk4 Vr6 Used Front Lower Bumper Air Vent Set. Pax side vent will require an adhesive or silicone to stay in place. $40 Shipped
2001 Mk4 Vr6 Used Motor Mount - Left Side $30 Shipped
2001 Mk4 Vr6 Used Clutch Pedal & Clutch Master Cylinder $40 Shipped
2001 Mk4 Vr6 Used Secondary Air Pump (06A959253B) $75 Shipped
MK4 Two Used Front Window Regulator Motors (1C1 959 801/2) $35 Shipped ea
2001 Mk4 Used Nuespeed Chrome Tower Bar $75 Shipped
2001 Mk4 Used ABD Fresh Air Intake $100 Shipped
Mk4 MOMO Billet gear shift knob and boot. $60 Shipped
2008 Mk5 R32 New Camshaft & Timing - Rail & guide Assy & Timing gear set (066109210AB) (022109087K/88N. It came on my new motor, we could not use it so you can get it, if you need it. $350 Shipped
2008 Mk5 R32 New Upper Timing Chain Cover. It came on my new motor, we could not use it so you can get it, if you need it. $60 Shipped
2008 Mk5 R32 Six Used Injectors with clips Low Miles (022906031L) $150 Shipped
2008 Mk5 R32 Used Air Box $50 Shipped
O2M 6-Spd Differential. $115 Shipped
My Swap http://forums.vwvortex.com/showthrea...98-My-R32-Swap Parts For Sale http://forums.vwvortex.com/showthrea...or-Sale-Thread Dont Shop Underground VW!!! http://forums.vwvortex.com/showthrea...Underground-vw/
#2
Bump
#3
ttt
#5
PM Sent.
#6
ttt
#7
Location? Interested in the engine
(+)===\X/===(+)
why do you care about awards so much? As I was reading your post, before I even looked what kind of car you drove, I knew it would be a mk4 or newer.
#8
#9
ttt
#10
willing to split the pulleys? im pretty sure its my water pump pulley that is rusted to hel and causing a very annoying squeaking noise![]()
#11
Sure. I realize most folks don't need all four.
#12
im pretty sure the one i need is the one over the water pump but ill double check tomorrow if it is how much you want for it?![]()
#13
#14
ttt
#15
ttt Lowered Prices
#16
ttt
#17
Pulley for mkv r?
FS: 19x9 5x112 Forgestar Wheels & Tires
.:Tango el gato el los pantalones:.
#19
ttt
#20
ttt
#21
ttt
#22
ttt
#23
ttt
#24
New item available.
Used Momo billet shift knob/ oe boot.
#25
ttt
#26
ttt
#27
ttt
#28
ttt
#29
ttt
#30
ttt
#31
ttt
#32
If the engine setup does not sale within the next 3 weeks, I am breaking it down and selling the parts. First come first serve.
#33
ttt
#34
ttt
#35
ttt
