Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 71 to 105 of 413
Thread: Caddy V4.0 - glutton for punishment
  1. Member autocross16vrocco's Avatar
    Jan 17th, 2003
    Columbus, Ohio
    06 BMW 330i, 82 Jetta Diesel, 81 VW Caddy, 09 Nightster
    02-24-2011 10:24 PM #71
    Mmm High Life. That is what my projects are sponsered with.
    Looking good so far.
  2. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    02-27-2011 07:04 PM #72
    High Life sponsors most of my car work these days
    Well I got V2.0 of the extended strut mounts made up today.
    Before welding:
    All done:
    V2.0 is a 1.25" rise, vs my first pair (in white in the pics) which were a 1" rise
  3. Member 91jetta_mike's Avatar
    Sep 9th, 2009
    Skagit County, Washington
    R.I.P. 91 Jetta, 86 Wolfsburg Cabriolet
    02-27-2011 08:38 PM #73
    Keep up the work
    *subscribed
    My Signature..
  4. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    03-05-2011 06:52 PM #74
    Ever wonder what the 'guts' of a MK1 control arm look like? Well here you go:
    Cut them apart for the front and rear bushing portions to use in some new arms I had an idea for the other day. Here is the frame work of the first arm, and I used the wood table and screws to outline a jig for the 2nd arm to match:
    And with both arms near done, one more than the other:
    Still have to make up the bottom plate for the ball joint on both arms and weld that one.
    Why?, you might ask did I do all this?
    Well its hard to tell from the pics but the ball joint mounting location is angled a fair amount. And will position the ball joint parallel to the ground with the end of the arm 2.25" higher than the bushing mounts. Bascially this will set the ball joints parallel to the ground with the stance of my Caddy, vs with the stock arms the ball joints were fully maxed out at the end of their travel/movement. My hope and plan is that this will help out with the bump steer and twitchy handling due to the large static drop of the caddy. As a side note they weight about 2lbs less ea than the stock arms.
  5. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    03-05-2011 07:05 PM #75
    Hope it works.
    Looks very cool regardless.
  6. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    03-06-2011 12:55 PM #76
    Man... those arms look awesome.
    When I was working on my "Z'd" arms I noticed something very interesting. All of the measurements I took showed that the ball joint mount is parallel but not perpendicular to the inner control arm mounts. It seems to be slightly forward of the front/inner control arm mount. Your new ones look to be perpendicular to the inner mounts. This may cause your front wheels to be moved back in the wells a little.
    Just an observation... nothing more! Keep up the great work!
  7. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    03-06-2011 05:56 PM #77
    I think that is the pic angle and the nature of not being able to see the arms 'stock', as all the points line up exactly with a stock arm.
    Also spent yet another day sanding, filling, sanding, touch up, sanding, spot filling..........
    Its amazing how long it takes to get this done right, I have so much more respect for those body guys and shops that do this all the time
  8. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    03-06-2011 06:03 PM #78
    When I take a square, run it down the leading edge of the arm and line it up wit the control arm mount it will shows otherwise.
    No worries!
  9. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    03-07-2011 06:03 PM #79
    I meant that about the arms I made, not the stock arms
  10. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    03-26-2011 07:08 PM #80
    Well after god knows how many hours of sanding, filling, and priming finally got some color on the bay:
    Need to mask off the rest of the bay and get it all under color then can put the motor in and get going on more 'fun' stuff
  11. 03-26-2011 11:58 PM #81
    bays looking good dude. are you doing the firewall?
    LE6B
  12. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    03-27-2011 02:45 AM #82
    I wish I had the patience to pull this off!
  13. Member
    Nov 10th, 2001
    Decatur, GA
    www.durtydubs.com & www.euro-wise.com
    03-27-2011 10:28 AM #83
    Quote Originally Posted by _WCHLVR_ View Post
    funny, cause i'd have never used the word "patience" to describe anything about adam... guess working on his truck is what calms this grumpy old man...
    looking good adam...
    take care,
    nash
  14. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    03-27-2011 09:35 PM #84
    yes firewall and front core support are next, just wanted to get the sides where all the time was spent in color finally for some kind of payoff. The paint is single stage factory Mojave Beige and I cant express too much how happy I am with the color and flatness of it.
    And Nash, I got your number son....and your Mom's
  15. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    03-28-2011 08:34 PM #85
    Raintray holes are no now more, well all but the few I will still use:
  16. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    04-02-2011 02:13 PM #86
    Well yanked the dash, seat and carpet. Both to clear the way for welding the lower firewall and to add more/new sound deadening
  17. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    04-04-2011 12:26 PM #87
    Begun motor assembly,striaght out of the crate and on the stand:
    lots of new and shiny to go on:
    Head off with ARP studs and SPA spacer headgasket on:
  18. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    04-11-2011 07:59 PM #88
    And now all together awaiting transmission:
  19. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    VW Caddy, VW THING & Audi A4 Quattro
    04-11-2011 08:52 PM #89
    loving all the custom work
  20. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    04-12-2011 01:42 AM #90
    Really cool cam pulley. Who makes that beast?
  21. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    04-12-2011 11:07 AM #91
    Its a brand new piece from SPA Brazil, all billet alu
  22. Member airbornejet's Avatar
    Jul 12th, 2002
    Charlotte, NC
    86 Golf
    04-12-2011 06:59 PM #92
    nice work....
  23. 04-12-2011 08:25 PM #93
    yeah that pulley looks gnarley
    LE6B
  24. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    04-23-2011 05:04 PM #94
    Well new pics wouldnt show much, in detail mode at this point. Back to sand,fill, prime repeat mode on the last few holes in the firewall. I did decide to ditch the heater core hoses, and associated holes in the firewall. The final call to remove the heater core was sealed when I found a near perfect set of rado leather seats w/heat.
    Engine is a little more compelte as well with some more details, basically the hold up now is finding a decent 02a/j to finish the assembly and get it in the bay to move forward with plumbing and wiring.
  25. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-05-2011 03:15 PM #95
    And as much as I wondered if I would ever get the bay 'done' it finally is:
    Now I can get the motor in, well that is as soon as I can get an acceptable 02a or 02j trans.....
  26. Member mk1daily's Avatar
    Jan 7th, 2010
    Tacoma, WA
    '81 2.0 Rabbit, '87 1.8 carbed Cabby, '80 350 Rat Rod Caddy
    05-05-2011 03:28 PM #96
    Quote Originally Posted by grizzlyone View Post
    There was some trading involved as well as cash money, but all in all ~$325 for this:
    Jealous.
    Truck looks good, keep it up!
  27. Member
    Feb 15th, 2001
    Durham, NC
    2010 GTI 4dr 6spd, 2006 Saab 9-2x Aero, 1971 BMW 2002
    05-05-2011 06:35 PM #97
    It turned out better than I thought it would
  28. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-06-2011 04:15 PM #98
    Just got some new shiny from the machine shop:
  29. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-10-2011 08:46 PM #99
    Finally sourced a B3 16v passat 02a trans, so now i can put the drivetrain in and begin the building of the trans mounts.
  30. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-11-2011 07:24 PM #100
    Cut up a stock upper trans mount to get the 'ring' to use for making my 02a trans mount bracket. Also made some progress on my version of a crossmember support, its a piece of 1/8" SS:
    Still need to add a few holes on top for the rad mount and to bolt the support in on the top, as well as fine tune the vertical portion and front mount holes.
  31. Member
    Nov 10th, 2001
    Decatur, GA
    05-11-2011 09:53 PM #101
    hadn't been online in a while and glad i peeked in...good stuff adam...
    can't wait to shower you with love and affection in 2 weeks...
    take care,
    nash
  32. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-14-2011 07:26 PM #102
    Quote Originally Posted by Nashty Rabbit View Post
    take care,
    nash
    Aww shuks
    Well motor is finally back in!
    Now I can make up some trans mounts and get back to working on the wireing and plumbing
  33. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-15-2011 02:52 PM #103
    The beginings of the upper trans mount:
    I need more magnets,
  34. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    05-15-2011 03:41 PM #104
    Lookin good!
  35. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-15-2011 07:23 PM #105
    And one upper 02A trans mount all dont, well cept for paint:
    Now on to the lower transmount
