Page 6 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 ... LastLast
Results 176 to 210 of 413
Thread: Caddy V4.0 - glutton for punishment
  1. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-01-2011 12:11 PM #176
    Another delievery from the UPS man, my tiny air ride parts:
    Thats a regular size of spray paint in the pic for reference. The bags are 4" OD and go from 2.5" compressed to 8" fully expanded. Its a 1gal tank, and 1/4hp pump. I had to get the plates made up as no one I could find offers precut plates for the 4" bags.
  2. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    11-01-2011 02:34 PM #177
    Those are pretty cool little bags. Who is the manufacturer?
  3. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-01-2011 04:14 PM #178
    Not sure who makes them, I got them from ChasisTech
  4. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-06-2011 01:41 PM #179
    Well finally got the the end links for the 4-link, also got a collection of precut tabs to make things a little easier and faster:
    The larger links are for the bottom strait links, as they take the most load and are ~ 2 3/4" wide. The others are 1 1/2" wide and will be for the upper diagonal links. Links and some of the tabs came from Speedway, and the other brackets from BallisticFab
  5. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-07-2011 01:04 PM #180
    Got so more work done on the subframe. Figured out the angles and placement for the upper triangulated links and got those mounted up. As well welded on some mounting strips for both the air tank and air horns:
    Also got some brackets bent up and welded on some ends caps for my lower link relocations:
    Basically these will bolt into the stock front leaf mounts and then relocate the lower links towards the front of the caddy and lower them for better geometry. They also make the change from the stock leaf width to my end link width. The gold nut and bolts were to keep the opening the right size while I welded the back plates on. Obviously still needs several holes drilled in them and some nuts welded on. I was able to get the bag mount plates drilled out for the mounting bolts and air fitting. But the fitting hole still needs to be bigger, just waiting on the adaptor to show up to know the exact size.
  6. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-07-2011 08:26 PM #181
    Did a quick mock up on the axle with the tabs I have the the end links, obviously the triangulated links tabs will be on top not even with the striaght links as in the pic:
  7. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    11-07-2011 09:16 PM #182
    Great work here.
  8. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    11-07-2011 09:17 PM #183
    Hot damn! Love it.
    Your QA1's, are they the bearing or bushing version?
  9. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-07-2011 09:29 PM #184
    Quote Originally Posted by _WCHLVR_ View Post
    Hot damn! Love it.
    They are the bushing version.
    While no doubt the bearing/hiem version is more precise those really arent meant for doing lots of street miles. And as before this redo, I plan to drive it alot. The bushings are also quite a bit quieter than hiems are.
  10. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    11-07-2011 10:49 PM #185
    Yeah... totally agree. Isolating the axle is certainly the best for road use for sure. I just wish the QA1's would give a little better range of motion for those with height adjustable suspensions. I have found that the Daystar Poly Flex Joints when combined with a full poly rod ends is fair compromise for road use and flexibility.
    The QA1 should be a perfect fit for your performance oriented application for sure.
  11. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-09-2011 07:55 PM #186
    Finished up the cutting and drilling for the various fittings and the runners on the intake manifold and dropping it off tomorrow for welding. Also think I am going to revisit my control arm design for a V2.0. Put in a big order for a bunch of AN fittings and hardline, I am planing to do all the air and fuel lines in bent hardlines. Also made my plan for the brakes front and rear, going to order shiny bits tomorrow for those
  12. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    11-09-2011 11:20 PM #187
    Love it.
  13. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-12-2011 04:23 PM #188
    More progress has been made
    Got the axle tacked in place to layout the tabs for the 4 links, rear shocks, and the air bag mounts:
    Going to drop the subframe and finish weld all the bits later today, as well as work on finishing up the exhaust.
  14. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-12-2011 08:19 PM #189
    Decided to go ahead and get the exh knocked out before pulling the subframe back out for final welding:
    All 3 'red things' are CherryBomb glasspacks, 1 2.5" before the split then 2 2.25" units. Made up my own 2.5" to dual 2.25" Y for the set up to get the angles right and fit the space the best. Just need to weld up the glasspacks and fab up a couple of hangers
  15. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    11-13-2011 03:08 AM #190
    Looks really nice. I am looking forward to try my hand at making my own exhaust. Found a really nice mandrel bending shop just outside Portland that ships.
  16. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-13-2011 03:21 PM #191
    Got the rest of the links tacked up as well as well as made a mount for the air tank and the first of the 3 planned exhasut hangers:
  17. 11-13-2011 09:57 PM #192
    Quality work goin on.
    Im running a 3" turbo back (catted w muffler) - and it's officially loader than I can handle. You brave Mang.
    LE6B
  18. Member _WCHLVR_'s Avatar
    Dec 7th, 2010
    Bend, Oregon
    11-13-2011 10:06 PM #193
    Quote Originally Posted by sk8ordie View Post
    I think its funny how these little trucks resonate. Its like the bed is an amplifier for noise. LOL
  19. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-14-2011 10:06 AM #194
    With the previous set up I was running 2.25" turboback with 2 resonators to a side pipe only, and it wasnt to bad. Both that set up, and this one, will have downturns aimed back and down which I think helps alot with the loudness.
  20. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-14-2011 09:13 PM #195
    Pulled the axle out and welded up all the tabs I had tacked in during the mock up:
    Ordered up some limit straps and some tubing for the gas filler extension today. Hope to have it on the ground again on its wheels after the weekend, if all the parts show up
  21. Member syracusegli's Avatar
    Jan 21st, 2005
    syracuse, NY
    twin charged mk1 cabby
    11-14-2011 09:46 PM #196
    i like how you made your own beam, came out nice, nice work
    Quote Originally Posted by 2mAn View Post
    go crash into a hybrid
    For all things Metal ---> www.roguemetalworks.com
  22. Member dubina4steve's Avatar
    Aug 5th, 2007
    Damascus/Towson, MD
    98 GTI, 81 Rabbit Truck
    11-17-2011 01:09 AM #197
    This is making me start to want to build my own rear beam for mine. This is an awesome build
  23. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-17-2011 11:56 AM #198
    Yeah much like the lower links, pretty sure I went massive overkill with the axle. Its 2.5" S40 pipe so is 2.88" OD and has almost 1/4" walls. I have never cut up a stock Caddy axle but I doubt its even half that wall thickness. The nice thing is the S40 pipe is easy to find and relatively cheap.
  24. Member
    Nov 10th, 2001
    Decatur, GA
    www.durtydubs.com & www.euro-wise.com
    11-17-2011 04:13 PM #199
    adam do'n some serious work....
    take care,
    nash
  25. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-18-2011 08:47 PM #200
    Getting so close to putting it back on its own wheels again......
    Got the rest of the bits to finish up the exhaust, the other hanger and downturn. Also got the alu upper swedged links and the tube adaptors for the lower links. Then I went ahead and put the bags and upper links in to make sure of the tube length for the lowers:
    Tomorrow will weld up the lowers and put both the subframe and exhaust to finish weld it all up
  26. 11-18-2011 08:50 PM #201
    sorry if you have already mention it - where will the fuel tank/cell be located?
    LE6B
  27. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-18-2011 08:54 PM #202
    There was one quick mick up pic with it on the previous page when I had just started the subframe:
  28. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-19-2011 06:15 PM #203
    I actually may be done welding
    But really I got the axle finished up completely, added a gusset to the upper link mounts and welded on 2 nuts for the limit straps:
    The straps are a whopping 10", which as it turns out are a specialty size in off road parts so they cost as much as 24"+ units, each
    Also got the subframe all knocked out. Cleaned up the old air tank mounts and fully welded the upper bag mounts. Also added a 1" x1/8" strip to reinforce the edges that projected out beyond the subframe:
    Pulled the exhaust out and finished welded it up with all the hangers so its 100% dont now as well:
  29. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-19-2011 06:29 PM #204
    Oh yeah also weighed up the final assemblies:
    Subframe, bare : 73lbs
    Axle, bare, 34lbs
    I figure the axle is a wash with the stock, and with you take into account the leaf springs, larger and heavier gas tank, I would say I really have only added ~50lbs to the truck. When you add in the fact of the gas tank holding 4 gals less and the smaller lighter battery I will be running its almost dead even from before.
    But I wont throwout any % guesses, I will also being willing to bet the front to rear weight bias will be much closer to 50/50 than it was before
  30. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-21-2011 05:22 PM #205
    Finally got the manifold back from the alu welders:
  31. 11-21-2011 07:48 PM #206
    Glad to hear the tank will remain under the bed. Cell in a bed is so tacky.
    LE6B
  32. Member sin bar's Avatar
    Jan 12th, 2008
    sin bar ga
    wagoon.
    11-21-2011 08:11 PM #207
    BUT WILL THERE BE ROOM FOR FIXIES?
    love it, adam, keep it up!
  33. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-22-2011 08:18 PM #208
    Put in the manifold to figure out the rest of the layout, as well as got the brake booster hose made up:
  34. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    11-23-2011 06:46 PM #209
    Got the lower link tube adaptors and welded them all up, shown with the uppers as well:
  35. Banned vento86's Avatar
    Oct 13th, 2008
    11-23-2011 11:04 PM #210
    nice.. cant wait to see this thing laid out
