Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 141 to 175 of 278
Thread: Havok's Nugget Yellow eventually VR6T build thread
  1. Member Roketdriver's Avatar
    Jan 23rd, 2009
    Flint, MI
    2001 Passat Wagon
    07-15-2011 09:42 AM #141
    I like this build and your attitude
    Quote Originally Posted by HavokRuels View Post
    I value everyones opinions on my thread. I am new to this type of modding and I learn something new everyday.
    GOOGLE IS YOUR FRIEND.
    I like grocery getters.
  2. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    07-18-2011 01:51 PM #142
    Got almost everything in today to rebuild the bottom end but I did forget new wrist pins.
    ABA Block
    New:
    Main Crank bearings
    Rod bearings
    Piston rings
    Crank seals
    Intermediate shaft seals
    Thrust Bearings
    Baffle pan
    Oil Pan
    The block past inspection with flying colors and nothing over sized had to be ordered
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
  3. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    07-18-2011 02:19 PM #143
    ABA Block
    New:
    Main Crank bearings
    Rod bearings
    Piston rings
    Crank seals
    Thrust Bearings
    Baffle pan
    Oil Pan
    Might want to consider tighter tolerance rod bearings
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    Quote Originally Posted by ein View Post
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  4. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-18-2011 02:31 PM #144
    Like .25+ oversized?
    This is what I bought: Kolbenschmidt
    Connecting Rod Bearing Set; Standard with Journal Oil Holes
    Specifically for diesel engines plus gas 16V and newer 8V engines, this set can be used on older 8V engines as an upgrade. 1 set per car.
    My block is obd1 1994 aba
  5. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    07-18-2011 02:43 PM #145
    No .25 would be for a cut crank. They make bearings that have tighter tolerances in smaller increments. I would have to go digging through the tech forum for the info.
  6. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-18-2011 05:46 PM #146
    I will do some research
  7. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    07-18-2011 06:32 PM #147
    And measure the journals before deciding on what size bearings. I would rather have an engine built on the tight side with freshly polished crank journals than having an engine built loose without touching the crank.
  8. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-21-2011 05:59 PM #148
    Power washed, cleaned and painted my transmission
    Still not done though, I am painting some parts black and putting new seals on the stub axles
  9. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    Limassol, CYPRUS (That's in Europe,lol)
    '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
    07-22-2011 01:25 AM #149
    ^^ Nice...
    ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
    My Corrado (sort of) build thread / On Database
    My MK1 build thread
    SpoonFedTuning
  10. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    09-11-2011 03:27 PM #150
    Now that the GTi build is about wrapped up and ready for fluids, I am 4 expansion plugs and 2 oil galley plugs away from assembling the 2.0 bottom end. Got the plug kit from TT some love for the advertisers.
    It's been 3 months and still no sight of my euro belts and manualk regulators and I am not getting responses from the shop in Germany that sold them to me I would have finished the interior by now but those two items have me by the balls.
  11. Junior Member
    Jul 26th, 2011
    Central NJ
    1990 Corrado G60
    09-29-2011 01:03 AM #151
    Lovin this build
    Cant wait to see more
  12. Member Golfatron3's Avatar
    Mar 6th, 2002
    Ottawa, ON
    94 Ice Grey Violet VR6, 92 Tornado Red VR6 Syncro Wagon
    10-14-2011 09:40 PM #152
    Awesome build so far
    You need a set of motorsport wheels though
    I Corrados
    Buy my VR6 Syncro Wagon! l Instagram: sebp19
    -Seb
  13. Member Mk4SR's Avatar
    Nov 20th, 2010
    Stavanger, Norway
    Golf Mk4 1.6 SR 99'
    10-27-2011 03:55 PM #153
    Nice project
    All I want for Christmas is to go low
  14. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    10-27-2011 08:20 PM #154
    /\ Thanks
    I have it on hold right now while I build some capital to get balls deep into it. I will post pics of the bottom end build soon.
  15. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    10-30-2011 07:47 PM #155
    Intermediate shaft bearing installation, expansion / oil galley plug and oil squirter installation pics on an ABA block for kicks. Enjoy
    Note the 2nd to last pic is an expansion plug installed where the PCV system used to tie in to the bottom end. Please note that some threads and websites say to use a 35mm plug, that is incorrect! You should use a 40mm plug
  16. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
    10-30-2011 08:29 PM #156
    Quote Originally Posted by crazynorweegian View Post
    Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
    tek-euro.com SpoonFedTuning
    my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
  17. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    11-03-2011 06:50 PM #157
    Let's stray from the craziness of the forum for a minute and help a brother out. No bull**** just tech info.
    OBD1 ABA bottom end: Stock Forged Crank, stock forged rods and stock aluminum pistons.
    What would you consider to be the threshold for the pistons in terms of HP? I am pretty sure the crankshaft and rods will do well but the pistons? Remember boys it's a G60 that will be turbocharged rather than super charged.
    I honestly don't know what the stock piston limits are.
  18. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    11-03-2011 07:15 PM #158
    Stock pistons are cast, as all stock VW pistons are.
    I would be more worried about the rod bolts than anything else as they are usually the first weak point.
  19. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    11-03-2011 07:40 PM #159
    See that's the kind of stuff I like to know.
    So a cast aluminum piston must have it's weaknesses no?
  20. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    11-03-2011 07:57 PM #160
    Yep, but you won't hit it unless you are trying to break the 300 hp barrier. It would probably be in the 350 hp area. Even then I doubt the piston will be the issue.
    I have seen 16v's with stock bottom ends hit 450+ and the thing that lets go is the rod bolts.
    ARP rod bolts/ Main bolts / Head studs are a must for higher horspower stuff.
    The stock replacement rod bolts are really weak compared to the originals. And they have to be replaced since the stock stuff is stretch bolts. This goes for the mains too.
    ARP stuff is 100 bucks for actual VW made rod bolts, 100 bucks for the mains and 100 bucks for the head stud kit.
    That is where I would put my money instead of pistons. If you are really worried about the rods look into SCAT rods. They are cheap and come with ARP hardware. Or Integrated Engineering for a couple more bucks.
    If you need ARP part numbers let me know I have them written down.
    Also in case you were wondering the Corrado has a unique rear-view mirror mount that it does not share with any other car.
  21. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    11-03-2011 08:13 PM #161
    Now that's the kind of tech **** I am talking about. The weakness is in the studs all the way around and I will be spending money on that. It's amazing how many people spend thousands on internals when stock can hold up to reasonable HP gains.
    BTW the Corrado windshield has a special film that detects and rejects any other type of rearview mirror.
  22. 11-03-2011 08:21 PM #162
    i had a friend with a 16v that had a stock bottom end pushing 450hp at the wheels and he drove it 60 miles to work every day...alot depends on the driver...
    "You can take my Corrado when you pry it from my Cold Dead Hands".
    http://corradodatabase.com/index.php...orrado&id=4617
  23. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    11-03-2011 08:46 PM #163
    Quote Originally Posted by -skidmarks- View Post
    & tune
  24. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    11-03-2011 08:48 PM #164
    I would also suggest having the rods balanced and then shotpeened if you want some extra strength from them. Also have the crank balanced.
    It will make everything rev much smoother and is a bit of piece of mine for not much money.
    The special film you are referring to is listed in ETKA as the anti-f*cktard film. True story.
    I believe it. The 16v I am referring to is Jesse Padila's car and had a boost spike on the dyno. Last they saw it hit around 560 before the bottom end let go. Split the block.
  25. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    11-03-2011 08:48 PM #165
    Quote Originally Posted by Sr. Karmann View Post
    & tune
    Absolutely. Tune is a HUGE key to all of this.
  26. Member dogger's Avatar
    Jul 29th, 2005
    Pasadena, CA
    1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro S-Line
    11-03-2011 08:49 PM #166
    We have a few local cars that put up those kind of numbers on stock bottom ends as well. Of course the ended up breaking other things like driveline and such.
    Kyle if you're going that far you should cryo everything too.
    Hope this car will be awd or
  27. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    11-03-2011 08:55 PM #167
    Jesse's car is local to you. Blue Mk2 with a Ralley headlight setup.
    Cryo is too expensive compared to the rest of that. Ever looked into the prices?
  28. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    11-03-2011 11:26 PM #168
    Here are some part numbers to get you started.
    ARP:
    Head Studs: 204-4701 (these are undercut and not the standard cut. You want this for a street car)
    Main Studs: 204-5402
    Rod Bolts: 104-6004
    Eurospec also sells head studs and main studs. The main studs are alot cheaper through them but they are not ARP so you may have to call to get a rating on the bolt from them.
    http://eurospecsport.com/products/co...e-updated.html
  29. Member dogger's Avatar
    Jul 29th, 2005
    Pasadena, CA
    11-04-2011 12:51 AM #170
    Yea Jesse's car is one am referring to. He's a boost addict.
    Cryo is the way to go if you want to put down power and not break things though. Good investment.
  30. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    11-04-2011 07:07 AM #171
    ARP:
    Rod Bolts: 104-6004
    Sweet, I will invest in the ARP studs just to be sure. ABA blocks are simple to buy and build but I have all winter so I need to have some patience and do it correct the 1st time. Wanna have fun when the car hits the road. Top end will be completely beefed up but as I had suspected, a solid stock bottom end can hold some pretty good numbers as you had pointed out.
  31. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    11-04-2011 07:39 AM #172
    350hp in a G60 will be a ton of fun. I built mine for that range
    ARP FTMFW
  32. Member dogger's Avatar
    Jul 29th, 2005
    Pasadena, CA
    11-04-2011 07:44 AM #173
    350hp in a G60 will have some traction issues.
  33. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    11-04-2011 08:01 AM #174
    ARP FTMFW
    Yeah that would be a blast to drive.
    dogger
    Rolling starts can help a little bit bit that problem
  34. 11-04-2011 08:51 AM #175
    & tune
    for sure!!! i think it was a kevin black tune
