Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 106 to 140 of 278
Thread: Havok's Nugget Yellow eventually VR6T build thread
  1. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    04-06-2011 06:18 PM #106
    Engine bay is completely empty (except for brake booster), cut off all brackets and studs sticking out and ready for final sanding, smoothing and frame rail covers and all I suffered was a split thumb tip and a burned index finger.
    It helps when the car is right outside the shop window and the air hose is easily accessed
    Wire and new tyco relay connectors have been ordered for the wire tuck.
    Oh and just got these for my corrado support vehicle
    Came off of a 1995 740
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
  2. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    04-08-2011 08:07 PM #107
    Did the rain tray delete today and was fairly simple with the right tools. Find all the weld dimples and grind them down just right and the assembly more or less pops out with a little persuasion.
    Enjoy!
    And my parts cars:
  3. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    04-30-2011 06:07 PM #108
    Spagetti for dinner? Nope, just the wiring for the power window systen after I removed the door actuator wiring. What a waste! Putting together a much simpler design based off the ford mustang which reduces this pile of crap to just several wires.
    Brought the floor boards down to the metal surface, got my seam sealer, kitty hair fiberglass, sound deadener, foam and carpeting in. Have a couple of small rust holes in the floor that will be fixed this weekend. Gonna re-carpet tomorrow and close up the firewall then starts the interior re-wire and wire tuck to the lights.
  4. Member Toffeerado's Avatar
    Aug 3rd, 2003
    Vancouver, Canada
    04-30-2011 06:19 PM #109
    Quote Originally Posted by HavokRuels View Post
    What do you guys think about houndstooth for the center of my seats and the door cards?
    Leave the door cards out of it, that stuff is busy and just distract from the seats. I had a 70's mk1 with hounds tooth factory, door cards were black thats all.
    When using a busy EYE catching pattern leave it on ONE area if you start spreading it around the car it gets too busy.
    Also houndstooth is 70's what else is going old school on your car? gonna be dating your interior pretty badly.
    Quote Originally Posted by Radvr6T View Post
    A true built car is one in which the owner alone has done its work intirely!
    Not had a shop build the motor,Not had a shop paint it ,Not had a upolster do the interior,Not just supplied money for work of any kind for the vehicle!
    According to this guy no one builds cars.
  5. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    04-30-2011 06:45 PM #110
    Quote Originally Posted by Toffeerado View Post
    I actually decided to go with the westfalia reproduction plaid
  6. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-11-2011 08:19 PM #111
    Finally some progress! Removed interior, stripped floor panels and prepped for the re-do.
    1) Sprayed undercoat
    2) Applied sound deadener, I chose 40mil edead at 2.00 per sq ft. Product worked well.
    3) Applied foam sound deadener, again an edead product at only 1.00 per sq ft.
    NEXT: Custom black carpet with latex backing that can be heat moulded or glued down.
    Removed all wiring for door lock actuator system, power windows and power seat belts. I secured a brand new set of Corrado manual window regulators from VW in Germany
    The goal is to have only the wiring for the power mirrors in the doors, and just the wiring running to the back for the rear lights, spoiler and fuel pump.
  7. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    05-11-2011 09:02 PM #112
    you couldn't pay me to spray undercoating on the inside of a car.
    POR-15 or bust.
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    Quote Originally Posted by ein View Post
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  8. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-11-2011 09:19 PM #113
    POR-15 or bust.
    I did it for free and it came out great! Please humor me with what's so bad about spraying undercoat/sound deadener on the inside
  9. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    05-11-2011 09:31 PM #114
    stuff SUCKS.. take forever to dry and traps moisture.
  10. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-12-2011 07:25 AM #115
    I'll take my chances.
  11. Member Praks's Avatar
    Nov 12th, 2008
    Poland
    1990/ Vw/Corrado vr6 supercharged
    05-13-2011 10:02 AM #116
    mine 2 seater in progress...
  12. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    Limassol, CYPRUS (That's in Europe,lol)
    '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
    05-13-2011 10:09 AM #117
    This may sound stupid (probably missed it somewhere) but where are you mounting the reservoirs since you shaved all of the brackets???
    ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
    My Corrado (sort of) build thread / On Database
    My MK1 build thread
    SpoonFedTuning
  13. Member BlackRado's Avatar
    Jul 14th, 2002
    05-13-2011 10:22 AM #118
    your parts cars are my favorite two colors from the factory... aside from black.
  14. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-19-2011 11:55 AM #119
    Quote Originally Posted by Praks View Post
    wow same set up I am going with. Gives me hope! Looks great!!
  15. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-19-2011 11:56 AM #120
    Quote Originally Posted by RedYellowWhite View Post
    There is a kit for all three plus a mounting bracket. The will either be tucked behaind the left headlight or mounted on the side wall
  16. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-19-2011 11:57 AM #121
    Quote Originally Posted by BlackRado View Post
    Yeah I loved the colors. Blue was aftermarket as the car was originally nugget yellow
  17. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-19-2011 11:58 AM #122
    OK gents help me out here.
    Purchased a low mileage aba engine for 100.00 and will be doing the bottom end conversion and wanted to know if the supercharger bracket mounts directly to that block.
  18. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    05-19-2011 12:17 PM #123
    You talking about the "Stroeve Motorsport" items??? If not, link of said "kit"...
    My MK1 build thread
    SpoonFedTuning
  19. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-19-2011 12:56 PM #124
    yep stroeve but since I only need two (coolant /p/s) I will probably go moroso or canton.
  20. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    06-21-2011 08:06 PM #125
    so I haven't done much due to waiting on the manual regulators and manual seatbelts but I managed to do a door speaker delete and here are the results:
    After my horrible experience with DAP spray adhesive I went with 3M super trim adhesive and the results as you can see were excellent. The adhesive stuck perfectly and didn't back off even bending the edges over to the back. Got it at autozone for 22.00
    oh and I aslo finished fabrication on my rear upper strut bar mounts. Got the aluminum in too for the cross brace and just have to weld it up. Pics soon
  21. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-02-2011 01:19 PM #126
    just picked up 3 of these and 1 cassette player slide out
  22. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-07-2011 07:00 PM #127
    My Recaro LS seats that I picked up
  23. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    07-08-2011 01:04 AM #128
    My Recaro LS seats that I picked up for 175.00 ....
    ^^Nice I love cloth Recaros
    Don't like those leather headrests tho, a pair of fishnet ones would look awesome
    My MK1 build thread
    SpoonFedTuning
  24. Member Wirbelsturm.VW's Avatar
    Sep 23rd, 2007
    The Street of the Willows, PA/Wilmington DE
    2000 Beetle 1992 Corrado SLC
    07-08-2011 01:08 AM #129
    x2
    REJUVENATION
    PA/DE
  25. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-08-2011 06:58 AM #130
    Yep I am actually looking around for the Halo headrests
  26. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
    07-14-2011 02:10 PM #131
    Officially subscribed
    Quote Originally Posted by crazynorweegian View Post
    Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
    tek-euro.com SpoonFedTuning
    my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
  27. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-14-2011 06:51 PM #132
    My custom rear upper strut mounts. Just have to weld the end brackets together on the aluminum stress bar and test fit.
  28. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    07-14-2011 07:08 PM #133
    and fix that wicked rust hole?
  29. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-14-2011 07:12 PM #134
    Yeah that will be gone soon. Picking up my paint on the 25th and will be resprtaying the rear and hopefully the engine bay.
  30. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    07-15-2011 12:13 AM #135
    Quote Originally Posted by Sr. Karmann View Post
    ^^x2....Damn man, I've never seen one rusting there
    You know paint won't cure that rust, right? .....
    Brackets look good
    My MK1 build thread
    SpoonFedTuning
  31. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-15-2011 07:14 AM #136
    Brackets look good
    lol I was thinking a big wad of chewing gum then paint
  32. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    07-15-2011 08:06 AM #137
    It's gonna need to be Big League Chew for that one
  33. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    07-15-2011 08:37 AM #138
    My MK1 build thread
    SpoonFedTuning
  34. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    07-15-2011 09:02 AM #139
    so many flavors to choose from too!!
  35. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    07-15-2011 09:31 AM #140
    Grape or original will go well with your color scheme
