Results 1 to 4 of 4
Thread: 2001 Jetta Wolfsburg 1.8t code P0170
  1. 01-25-2011 07:04 PM #1
    Hi everybody,
    First timer, here. I know everything I know about my car through this site so thanks!
    I've got a 2001 Jetta Wolfsburg 1.8T with just under 104K miles. It's running fine but I've been chasing down this P0170 code for a few months and now my inspection's due so the pressure's on to get it fixed (as if it wasn't before).
    The car runs fine with the exception of cold starts. I've scoured the forums and hope I haven't missed anything obvious, but here's what I've done so far:
    -replaced MAF (just tested this under load at redline and got readings of ~156 g/s. My car has an APR chip so I assume these readings are good. I aslo assume this rules out the MAF as the culprit.
    -checked for obvious vacuum leaks to no avail
    -replaced pre-cat O2 sensor (was originally throwing P0133 so it wasn't just on a whim)
    I'm still inclined to suspect a vacuum leak and need to do replace the braided lines anyway but it must be a small one. So my questions:
    1. Would VAG-COM give me more info than my OBDII scanner about fuel trim specifically and narrow down the possible issues (ie, determine whether it's a vacuum leak or a sensor failure)?
    2. Since I reset my CEL, all monitors have come back up except the catalytic converter monitor. That one still comes back incomplete. Is it possible the post-cat O2 sensor is involved with that? I know it's not directly involved with fuel trim issues like the pre-cat sensor.
    3. Do any VAG-COM owners in Austin (78704) feel like helping out?
    cheers
  2. 01-25-2011 07:07 PM #2
    Just to be clear, I replaced the MAF, reset the CEL, and then just tested the new MAF as a sanity check today when the P0170 code came back.
  3. 01-25-2011 07:19 PM #3
    And finally, here's the data from my scanner, just in case someone spots something I didn't. I'll be quiet now.
    O2 Monitor Test
    O2 Bank1 Sensor1
    $81 (Values)
    MOD : $10
    MEAS: 118
    MIN : 90
    MAX : 255
    $82 (Values)
    MOD : $10
    MEAS: 128
    MIN : 90
    MAX : 255
    $83 (Values)
    MOD : $10
    MEAS: 99
    MIN : 15
    MAX : 205
    $84 (Values)
    MOD : $10
    MEAS: 51
    MIN : 0
    MAX : 255
    O2 Bank1 Sensor2
    $81 (Values)
    MOD : $10
    MEAS: 118
    MIN : 90
    MAX : 255
    $82 (Values)
    MOD : $10
    MEAS: 128
    MIN : 90
    MAX : 255
    $83 (Values)
    MOD : $10
    MEAS: 99
    MIN : 15
    MAX : 205
    $84 (Values)
    MOD : $10
    MEAS: 51
    MIN : 0
    MAX : 255
    Live Data
    DTC_CNT 1
    FUELSYS1 CL
    FUELSYS2 N/A
    LOAD_PCT(%) 3.5
    ETC(°C) 94
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 3970
    VSS(km/h) 58
    SPARKADV(°) 2
    IAT(°C) 36
    MAF(g/s) 9.25
    TP(%) 7.8
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.005
    OBD OBD&OBD2
    EQ_RAT11 1.999
    O2S11(mA) 2.395
    DTC_CNT 1
    FUELSYS1 OL_Fault
    FUELSYS2 N/A
    LOAD_PCT(%) 43.9
    ETC(°C) 93
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 3595
    VSS(km/h) 53
    SPARKADV(°) 38
    IAT(°C) 33
    MAF(g/s) 15.75
    TP(%) 11.0
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.735
    OBD OBD&OBD2
    EQ_RAT11 0.780
    O2S11(mA) -0.145
    DTC_CNT 1
    FUELSYS1 CL
    FUELSYS2 N/A
    LOAD_PCT(%) 4.7
    ETC(°C) 93
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 1343
    VSS(km/h) 45
    SPARKADV(°) 5
    IAT(°C) 35
    MAF(g/s) 2.25
    TP(%) 2.0
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.585
    OBD OBD&OBD2
    EQ_RAT11 0.750
    O2S11(mA) -0.988
    DTC_CNT 1
    FUELSYS1 CL
    FUELSYS2 N/A
    LOAD_PCT(%) 1.6
    ETC(°C) 93
    SHRTFT1(%) 2.3
    LONGFT1(%) 3.1
    RPM(/min) 759
    VSS(km/h) 27
    SPARKADV(°) 13
    IAT(°C) 38
    MAF(g/s) 2.25
    TP(%) 2.4
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.625
    OBD OBD&OBD2
    EQ_RAT11 0.958
    O2S11(mA) -0.129
    DTC_CNT 1
    FUELSYS1 CL
    FUELSYS2 N/A
    LOAD_PCT(%) 2.0
    ETC(°C) 93
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 1946
    VSS(km/h) 11
    SPARKADV(°) 26
    IAT(°C) 36
    MAF(g/s) 16.25
    TP(%) 6.3
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.665
    OBD OBD&OBD2
    EQ_RAT11 0.787
    O2S11(mA) -0.734
    DTC_CNT 1
    FUELSYS1 CL
    FUELSYS2 N/A
    LOAD_PCT(%) 2.4
    ETC(°C) 93
    SHRTFT1(%) -17.2
    LONGFT1(%) 3.1
    RPM(/min) 781
    VSS(km/h) 5
    SPARKADV(°) 5
    IAT(°C) 38
    MAF(g/s) 7.25
    TP(%) 4.3
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.715
    OBD OBD&OBD2
    EQ_RAT11 0.969
    O2S11(mA) -0.344
    DTC_CNT 1
    FUELSYS1 CL
    FUELSYS2 N/A
    LOAD_PCT(%) 36.5
    ETC(°C) 93
    SHRTFT1(%) 13.3
    LONGFT1(%) 3.1
    RPM(/min) 3542
    VSS(km/h) 28
    SPARKADV(°) 25
    IAT(°C) 34
    MAF(g/s) 46.25
    TP(%) 36.9
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.030
    OBD OBD&OBD2
    EQ_RAT11 0.957
    O2S11(mA) -0.266
    DTC_CNT 1
    FUELSYS1 CL
    FUELSYS2 N/A
    LOAD_PCT(%) 20.0
    ETC(°C) 94
    SHRTFT1(%) 14.1
    LONGFT1(%) 3.1
    RPM(/min) 3629
    VSS(km/h) 53
    SPARKADV(°) 2
    IAT(°C) 34
    MAF(g/s) 52.75
    TP(%) 21.6
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.690
    OBD OBD&OBD2
    EQ_RAT11 0.940
    O2S11(mA) -0.258
    DTC_CNT 1
    FUELSYS1 OL_Fault
    FUELSYS2 N/A
    LOAD_PCT(%) 74.5
    ETC(°C) 95
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 5712
    VSS(km/h) 85
    SPARKADV(°) 35
    IAT(°C) 34
    MAF(g/s) 12.75
    TP(%) 8.2
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.635
    OBD OBD&OBD2
    EQ_RAT11 1.999
    O2S11(mA) 2.320
    DTC_CNT 1
    FUELSYS1 OL-Drive
    FUELSYS2 N/A
    LOAD_PCT(%) 8.6
    ETC(°C) 95
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 4747
    VSS(km/h) 71
    SPARKADV(°) 17
    IAT(°C) 34
    MAF(g/s) 90.75
    TP(%) 15.3
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.730
    OBD OBD&OBD2
    EQ_RAT11 0.841
    O2S11(mA) -0.492
    DTC_CNT 1
    FUELSYS1 OL-Drive
    FUELSYS2 N/A
    LOAD_PCT(%) 2.7
    ETC(°C) 94
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 1043
    VSS(km/h) 58
    SPARKADV(°) 10
    IAT(°C) 36
    MAF(g/s) 2.00
    TP(%) 2.4
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.450
    OBD OBD&OBD2
    EQ_RAT11 0.958
    O2S11(mA) -0.637
    DTC_CNT 1
    FUELSYS1 OL_Fault
    FUELSYS2 N/A
    LOAD_PCT(%) 20.0
    ETC(°C) 93
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 2838
    VSS(km/h) 63
    SPARKADV(°) 23
    IAT(°C) 34
    MAF(g/s) 5.00
    TP(%) 4.7
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.710
    OBD OBD&OBD2
    EQ_RAT11 0.810
    O2S11(mA) -1.023
    DTC_CNT 1
    FUELSYS1 OL_Fault
    FUELSYS2 N/A
    LOAD_PCT(%) 5.5
    ETC(°C) 93
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 2887
    VSS(km/h) 65
    SPARKADV(°) 6
    IAT(°C) 33
    MAF(g/s) 5.25
    TP(%) 5.1
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.595
    OBD OBD&OBD2
    EQ_RAT11 0.945
    O2S11(mA) -0.242
    DTC_CNT 1
    FUELSYS1 OL_Fault
    FUELSYS2 N/A
    LOAD_PCT(%) 5.5
    ETC(°C) 92
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 3196
    VSS(km/h) 71
    SPARKADV(°) 36
    IAT(°C) 33
    MAF(g/s) 15.50
    TP(%) 11.0
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.710
    OBD OBD&OBD2
    EQ_RAT11 0.780
    O2S11(mA) -1.102
    DTC_CNT 1
    FUELSYS1 OL-Drive
    FUELSYS2 N/A
    LOAD_PCT(%) 5.9
    ETC(°C) 91
    SHRTFT1(%) 0.0
    LONGFT1(%) 3.1
    RPM(/min) 3017
    VSS(km/h) 67
    SPARKADV(°) 13
    IAT(°C) 33
    MAF(g/s) 35.50
    TP(%) 16.9
    AIR_STAT OFF
    O2S B1S12--B2S----
    O2B1S2(V) 0.665
    OBD OBD&OBD2
    EQ_RAT11 0.942
    O2S11(mA) -0.391
  4. 01-26-2011 04:14 PM #4
    It was indeed the post-cat o2 sensor in my case. Replacing that did the trick.
