Results 1 to 29 of 29
Thread: :: ECS Tuning :: ECS Wobble Bolts (14 x 1.5 x 27) - Now Available !!!
Hybrid View
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    01-26-2011 12:43 PM #1
    ECS Wobble Bolts (14 x 1.5 x 27) - $3.99 each
    ECS own conical seat wobble wheel bolt, conical seats fit most aftermarket wheels. Used for mounting
    * 14mm diameter
    * 1.5mm thread pitch
    * 27mm length
    Click here for video!
  2. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    02-19-2011 06:20 PM #2
    So these will let 114.3x5 wheels fit?
    Also how long are our factory bolts? I always thought that they were 30+?
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-20-2011 04:29 PM #3
    Correct, these will allow mounting of 5x114.3 wheels to a 5x112 car. OEM wheel bolts are 27mm long.
  4. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    02-21-2011 01:53 PM #4
    Quote Originally Posted by jon@ecstuning.com View Post
  5. Member djrockytharp's Avatar
    Mar 4th, 2008
    Houston TX.
    2011 VW GTI
    05-22-2011 01:11 PM #5
    so you can mount 5x114.3 without redrilling them?
    2011 GTI
    2001 Jetta Wolfsburg
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    05-23-2011 07:40 AM #6
    Correct, these allow you to mount a 5x114.3 wheel on a 5x112 car without re-drilling them as long as a few criteria are met. The bolt holes on some JDM wheels are for 12mm studs, not 14mm wheel bolts, so in some cases the bore on the wheel bolt would need to be opened up / drilled out. The offsets on the wheels also need to be correct as it is not possible to run a spacer with these bolts, as these are the same length as a stock bolt.
  7. Member djrockytharp's Avatar
    Mar 4th, 2008
    Houston TX.
    2011 VW GTI
    05-23-2011 12:02 PM #7
    so as far as offsets whats a general number to stay around.
    2011 GTI
