Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 105
Thread: ** GruvenParts.com Releases AFFORDABLE Adjustable Front Upper Control Arms !! **
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2011 09:37 AM #1
    A4/B5 Front Adjustable Control Arms
    Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms
    BY FAR – THE BEST VALUE IN ADJUSTABLE CONTROL ARMS ON THE MARKET !
    You asked GruvenParts.com for affordable, bulletproof, and fully rebuildable Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms and we have delivered!
    Just like the GruvenParts.com popular TT/R32 rear adjustable control arms, we designed these based on years of fabricating rock crawler suspension systems for racers and weekend warriors alike. They are made from a special aircraft grade of 4130 chrominum-molybdenum alloy and then powder coated in high gloss black for maximum durability. The AMERICAN MADE racing heim joints are CAD plated, PTFE lined, and can be ordered with dust boots all around for those planning to re-enact a Grouppe B Ralley race. Finally, all parts are fully rebuildable.
    Don’t waste your hard earned money with the over-priced competitor versions. The quality and performance of the GruvenParts.com adjustable upper control arms are second to none!
    These come as a set of 4 and fit the following models :
    Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
    Audi A6/RS6 (incl. AllRoad) - 1998-2004
    VW Passat - 1998-2005
    This product replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
  2. Member Lazer Viking's Avatar
    Oct 17th, 2006
    the keystone state
    too many audis
    01-31-2011 09:47 AM #2
    finally.. i'll be picking a set up soon
  3. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    01-31-2011 10:08 AM #3
    The hype made it seem like they were going to be a lot cheaper than $400.00
    The TT and R32 parts used as examples were in the $200.00 range. To be honest, $75.00 cheaper than the competition isn't really "blowing the competition out of the water"
  4. Member Lazer Viking's Avatar
    Oct 17th, 2006
    the keystone state
    too many audis
    01-31-2011 10:40 AM #4
    the reason the price for the tt/r32 is only 200 bucks, is because that includes 2 arms.
    you need 4 to have it fully adjustable, these control arms are on the same price point as those.. you just get 4 arms, instead of 2
    also,
    stern arms are $600
    034's are $525
    and the cpp arms were around $600 also when you could still get them
    so id say the price is pretty good
  5. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2011 11:26 AM #5
    As it was pointed out, the R32/TT arms are $249.99 for 2 and $469.00 for 4.
    For the A4 front suspension, you need 4 arms, this price is LESS expensive than R32/TT.
    Some other things to keep in mind :
    The heims on these are not readily available off the shelf.
    These require custom manufactured hardened steel end pins
    Everything is fully rebuildable
    A boot kit is available
    Price is a good bit less than competition
    I * PROMSE* when you see these parts, you are going to wonder how we can sell at this price. Very little margin in it, but we want to break into this market. I would expect pricing on this product to increase from this introduction, this is nearly the material and machine time cost alone.
  6. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-02-2011 09:37 AM #6
    Guys, working on special group buy pricing of $350/set if we can get 20 orders.
    Please email me directly if you want to be included on this. Paul@GruvenParts.com
  7. Member MikekiM's Avatar
    Aug 21st, 2001
    San Diego
    09 Jetta Sportwagon
    02-03-2011 12:24 AM #7
    Can you explain why one ball joint is so much longer than the other? stock ones already can hit the chassis. with such a long ball stud, it's going to be so much easier for them to hit the chassis during a hard bump. Plus the geometry is going to change considerably due the angle on those ball joints.
    there's a reason the stock arms have a bump stop on the ball joint end.
  8. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-03-2011 09:00 AM #8
    Mike I will update the picture, the pins installed in that picture are longer than the final design. It doesnt hit the chassis. The reason for the height offset is because at full turn lock the heim body actually contacts the jam nut, so we have to offset 1 slightly. I will update the picture soon to show the correct pin length.
  9. 02-08-2011 01:34 PM #10
    Quote Originally Posted by Lazer Viking View Post
    also,
    stern arms are $600
    034's are $525
    There has been GB's on the Stern for $500 and 034 for $475 both including free ground shipping in the USA.
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-10-2011 08:49 AM #11
    Ours are priced at $399.99, everyday. No group buy needed.
  11. Member MikekiM's Avatar
    Aug 21st, 2001
    San Diego
    09 Jetta Sportwagon
    02-10-2011 06:44 PM #12
    This design was tried years ago by CPP, and sucked miserably. They clunked to no end, even when they added rubber boots. Good luck with them..
  12. 02-10-2011 08:04 PM #13
    Quote Originally Posted by MikekiM View Post
    034 also offers a set that is of the same design. $475 retail
  13. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-15-2011 12:02 PM #14
    Sounds like they used poor heim joints, ours are very high quality. We have had excellent results
    You wont find these at a better price, I promise. I doubt we'll even be able to hold price for too long.
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-17-2011 09:09 AM #15
    We also offer ours with dust boots, so that will certainly help for grimy environments!
    Again, we are not new to building adjustable control arms, we have sold many kits for R32/TT rear.
  15. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-21-2011 11:40 AM #16
    And now ...
    adjustable (affordable) rear A4 control arms are coming
    www.GruvenParts.com
    Stay tuned ...
  16. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    02-21-2011 12:36 PM #17
    Quote Originally Posted by GruvenParts.com View Post
    And now ...
    www.GruvenParts.com
    Stay tuned ...
    Can you give us any timeline on these?
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-22-2011 11:31 AM #18
    Timeline depends on demand - post up if you want the adjustable rear control arms too.
  18. Member
    Dec 3rd, 2009
    Halifax, NS. (shipping isn't that bad...)
    01.5 A4 1.8tqm, 99 A4 1.8tqm (<parting out)
    02-22-2011 11:46 AM #19
    Yup.
    Still waiting on this front Group Buy too. Status on that?
  19. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    02-22-2011 11:59 AM #20
    If the price is good i'd be interested in getting a set.
  20. Member keeganhartman's Avatar
    Jan 24th, 2005
    b5 a4 with switches
    02-22-2011 07:34 PM #21
    maybe maybe i'm thinking it would be nice but idk if it would be necessary
  21. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-24-2011 04:01 PM #22
    Sorry for delay in posting the GB for the fronts. Super busy down here, should have time to put that together next week.
    If you want to be notified you can email us and when the GB page goes up I will email you.
    Thanks
  22. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-28-2011 01:49 PM #23
    Bump for billet goodness and lots more is on the way !
    www.GruvenParts.com
    Our TT/R32 + A4/Passat Adjustable control arms are now available fully booted for extreme environments.
    TT/R32 Rear Adjustable Control Arms
  23. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-05-2011 02:02 PM #24
    A4 / Passat 1.8T Billet Dipstick
    www.GruvenParts.com is proud to release these gorgeous Billet Dipsticks to replace OEM part number 053-115-611C (053115611C). Our billet dipstick is CNC’d from a solid block of 6061-T651 aluminum with a stainless steel cable permanently attached. The cable end has a flitting with hash marks to signify oil level min and max.
    As an added bonus, this part is made to perfectly fit our Billet Dipstick Funnels and can be ordered as a set to save! If you are ordering the billet funnel with the billet dipstick, please ensure your car uses dipstick funnel OEM P/N 053-103-663 (053103663).
    This billet dipstick replaces OEM part number 053-115-611C (053115611C) and fits the following vehicles :
    1996 - 2002 Audi A4/S4/Avant Quattro 1.8T (AEB)
    1998 – 2001 VW Passat 1.8T (AEB)
    1988 – 1992 Audi 80/90
    1982 – 1987 Audi 4000
    1987 – 1993 VW Fox
    1982 - 1985 VW Quantum 1.8L
    Don’t see your car listed here? Don’t worry! We have many more of these billet dipsticks coming for nearly all makes / models. Visit www.GruvenParts.com for the latest.
  24. Member colinisneat's Avatar
    Jul 29th, 2008
    Valparaiso,IN
    '01 A4 1.8T QM
    04-11-2011 10:27 PM #26
    I'm in for some adjustable rear control arms!!
    INSTAGRAM - colinisneat
    Join the craze!! http://forums.vwvortex.com/showthrea...ower-Standards
  25. Member OntITTech's Avatar
    Aug 2nd, 2008
    2000 A4 1.8T, 93 Audi 90CS
    04-12-2011 09:57 AM #27
    I have been working with Paul in getting this GB together. I have a list of 12 guys already who are in, and I am looking for another 10+ to make sure this GB Happens.
    The parts are in stock and ready to ship so lets get moving on this guys.
    PM Me or E-mail Paul (Paul@Gruvenparts.com) if you haven't gotten a hold of either of already if you are in on this GB for some great control arms at an amazing price.
    Also when you send either of us the message let us know if you would be interested in adjustable rear control arms as well so Paul can put some priority on them.
    Lets show em why B5'ers do it right!
    There are 2 Types of Drivers: Those who wash their cars, and those who drive them!
    AUDI- Automobile Usually Driven Insanely
    Ebony Black Pearl 2000 A4 1.8T Stage 1+
    Crystal Silver 1993 Audi 90 CS. Stock..... For Now.
  26. Member bahnblitz's Avatar
    Jan 18th, 2002
    LI, NY
    Audi Allroad, scirocco 16v, jetta coupe 16v, ecodiesel jetta
    04-14-2011 04:36 AM #28
    Hope I can still get in on this!
    e2 Motorsport
    Freeport, NY
    VW/Audi specialists, VAG-COM certified! PVW featured! I-Car Platinum certified!
  27. 04-17-2011 04:18 PM #29
    So for the group buy of the adjustable upper control arms, how much will it come to?
  28. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-19-2011 01:52 PM #30
    Quote Originally Posted by $teady$upreme View Post
    Please see the group buy thread for latest :
    http://forums.vwvortex.com/showthrea...nParts.com-***
    Thanks
  29. Member
    Apr 19th, 2011
    Rain City
    04-19-2011 10:27 PM #31
    Do you guys offer the dust boot kit like the 034?
  30. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-20-2011 11:23 AM #32
    Quote Originally Posted by SaiB View Post
    Yes we offer complete dust book kit for these. Same boots they use in Nextel Cup racing, really nice stuff
    I will be changing picture soon to show control arms with dust boots installed.
  31. Member OntITTech's Avatar
    Aug 2nd, 2008
    05-10-2011 12:15 PM #34
    well after having these on for 3 weeks now I am loving life. The Fronts sit flat on the road again, and with a proper alignment all of the vibration and chatter from the front end is gone.
    Thanks Paul
    Bump for an incredible set of control arms
  32. Member
    Dec 3rd, 2009
    05-10-2011 01:14 PM #35
    Friday is Pay day!
