Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 141 to 175 of 250
Thread: Windsor Blue AWP 1.8T Swap
  1. 02-22-2012 08:21 PM #141
    also calling 1.8t motor gurus what should i replace while the engine is out besides all gaskets n seals??
  2. Member killercoconuts's Avatar
    Nov 24th, 2008
    Connecticut
    1986 Scirocco mk4 Wolfsburger
    02-22-2012 08:38 PM #142
    I'm no guru, but from my knowledge i'd say coolant temp sensor, thermostat, valve cover gasket kit, and a good timing belt kit. otherwise 1.8t's are a pretty solid motor.
  3. 02-22-2012 09:22 PM #143
    When you do these Valve cover gaskets on these 1.8ts its a good idea to do the cam adjuster gaskets...And I'd probably replace the coolant flange too from the adjuster leaking onto it.
  4. Member killercoconuts's Avatar
    Nov 24th, 2008
    Connecticut
    02-22-2012 10:08 PM #144
    Quote Originally Posted by johnny truelove View Post
    http://www.germanautoparts.com/Volks...a/Engine/327/1
  5. 02-26-2012 05:34 PM #146
    ok so i started the tear down fri and picked up some new gaskets n seals
    heres a few pics
    and heres a few snps shots from last summer .....man i cant wait for MVOC and the summer
  6. Member killercoconuts's Avatar
    Nov 24th, 2008
    Connecticut
    02-26-2012 06:09 PM #147
    I dig this car so much. Wish I still had my mk3.
  7. 02-26-2012 07:51 PM #148
    Quote Originally Posted by killercoconuts View Post
    thanks man its come a long way
  8. 02-29-2012 05:53 PM #149
  9. 03-02-2012 09:33 PM #150
    well back at it again tonight did some cleaning up and put in new exhaust studs valve cover seal ...and any gasket and seal i can replace....and iam thinking cream valve cover and intake hmmm :?:
    and a lil prayer to the patron saint of 1.8T swaps :wink:
  10. 03-16-2012 11:34 PM #151
    so heres a little update, i manged to score a forged tip
    but unfortunately the stock manifold is cracked so iam repairing this one unless i can find another :roll:
    and the glamour shots
    once the manifold is fixed ill put the back of the engine together and start on stripping the front
  11. 03-17-2012 01:23 PM #152
    P
    1996 GLX Windsor Blue....Soon to be STAGE 2 1.8T AWP
    Build Thread
    http://forums.vwvortex.com/showthrea...-AWP-1.8T-Swap
  12. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    95 2.0 turbo, 97 vr6
    03-17-2012 01:51 PM #153
    very nice...keep going
    OG suede
    I survived epic thread 2011 never forget 11/11/11
    Quote Originally Posted by vastxpunk View Post
    You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
  13. 03-17-2012 02:54 PM #154
    Quote Originally Posted by 95jetta17 View Post
    thanks man
  14. Member Andrewrg's Avatar
    Sep 5th, 2010
    Harrisburg Pennsylvania
    2007 Rabbit,97 GTI, 96 Jetta, 01 B5 Wagon
    03-17-2012 03:09 PM #155
    Looks good
  15. Member SloDubbin's Avatar
    Jul 5th, 2011
    Lawrenceville,Ga
    03' 1.8t Gti -DD-,97'vr6 Gti -sold- 95' 2.slo Jetta -Sold-
    03-17-2012 05:06 PM #156
    windsor blue ftmfw looks good i cant wait to see pics with the 1.8t running !
    -sesame street-
  16. 05-02-2012 10:11 PM #157
    love this shot colin...some mk3 love right here
    just a little update got the wire harness completed
    fabbed up the DBW pedal cluster is ready for weld
    picked these up to stiffen things up
    this need to go in soon :
  17. Banned vento86's Avatar
    Oct 13th, 2008
    05-02-2012 10:15 PM #158
  18. Member Jh0104's Avatar
    Jul 15th, 2010
    nazareth, pa
    jetta3 aba
    05-02-2012 11:12 PM #159
    nice build
    phillyscca.com
    J&J autosport
  19. Member mk3jet4life's Avatar
    Oct 17th, 2011
    OR
    95 VW Jetta
    05-02-2012 11:22 PM #160
    from one clean to the next,good job!
  20. 05-03-2012 05:34 AM #161
    Thanks for the positive comments Iam getting really stoked to get this motor finnished
    Build Thread
  21. Member MahTrek=]'s Avatar
    Nov 6th, 2008
    8v Jetta
    05-03-2012 11:23 AM #162
    Great work man! Will be watching
    Quote Originally Posted by 911_fan
    MKIV 2.0's suck, MKIII 2.0's don't suck.
    JettaIII
    8v
  22. Banned vento86's Avatar
    Oct 13th, 2008
    05-03-2012 11:48 AM #163
  23. Member tylerlb's Avatar
    Jun 13th, 2004
    Ottawa, ON
    05-03-2012 11:49 AM #164
    Man do i ever need to find a clean shell
    Well done sir
  24. 05-03-2012 01:33 PM #165
    Best thing I vet did was getting a rust free shell lol
    Build Thread
  25. 11-17-2012 12:54 PM #166
    A few pics from my work
    So I final started the 1.8t swap. when I get back for NFLD in 2 weeks ill focus on getting the 1.8t ready to put in and get the engine bay all cleaned up
    Picked a few non secret goodies
    Build Thread
  26. 11-17-2012 12:57 PM #167
    And the worst job ever rear beam bushing were replaced
    Thanks filmore for the hand!
    Build Thread
  27. 11-19-2012 04:15 PM #168
    So Here's my game plan for the swap .I have decided to wait and go Big Turbo next year and focus on getting this swap up and running right and still be able to afford maintenance parts and get my rims refinished and maybe paint work , and in all honesty this should be very fun to drive when i'm done I also opted to run the 020 with this setup until i can source more parts and convert it next year.
    So I ordered new parts for when i get back from NFLD
    Engine is AWP code (180HP)
    1.Godspeed inter-cooler
    2. Boost piping couplings and all clamps
    3.R1 DV
    3.Race N75
    4.SAI Delete
    5. NGK #6962 or 7e's Plugs
    6.Timing belt kit w/water pump
    7.oil return line
    8.tensioner
    9. stage 2 clutch kit
    10.ECU IMMO Defeat
    11.Stage 2 softwear APR ot Unitronic
    12. Techtonic 2.50 DP(will be upgrading to 3"DP)
    13.Forged tip
    14.Intake Mani Spacer
    15 Custom wiring harness to run stock management on CE2(courtesy of GTD)
  28. Member xxkoadyxx's Avatar
    Mar 18th, 2010
    Nova Scotia.. P.C
    93 volkswagen golf diesel soon TDI (hopfully), 2003 passat 1.8T daily
    11-19-2012 05:11 PM #169
    Its gonna be one hell of a car once this swap is done!
    vw mk3 4dr golf TD soon stg 3 malone Tdi (hopfully if i get all the parts for swap)- Project
    Vw b5.5 passat 1.8t-Daily
  29. 12-16-2012 03:48 PM #170
    Thanks
    Build Thread
  30. 12-28-2012 10:12 PM #171
    Build Thread
  31. Member mk2gtd's Avatar
    Sep 17th, 2007
    Ottawa, ON, Canada
    '96 24v VR6 Golf
    12-29-2012 12:13 AM #172
    you're building up quite the parts collection
  32. 01-03-2013 10:36 PM #173
    well i got a lot sorted out tonight got Deleted SAI , EVAP and N249 Valve, I also will be running a Catch Can ...what to of **** came off!
    SAI Delete
    Some Pictures of the finished product....Really cleans the motor up with these deletes ( test fit boost piping to get an idea when it will run)
  33. Member Andrewrg's Avatar
    Sep 5th, 2010
    01-04-2013 07:59 AM #174
    Thanks for the update! Love your car man. Cant wait to see it finished.
    Instagram: gtimk3
  34. 01-04-2013 01:25 PM #175
    Ordered up one of these courtesy of CO Motorsports
    Build Thread
