VWVortex.com - Build Thread: Victoria, my 1990 Jetta GLI
    Page 7 of 56 FirstFirst ... 3456789101117 ... LastLast
    Results 151 to 175 of 1390
    Thread: Build Thread: Victoria, my 1990 Jetta GLI
    1. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      1990 Golf GL; 1990 Jetta GLI 16VG60
      07-14-2011 06:48 PM #151
      Quote Originally Posted by VDub2625 View Post
      I had the exact same problem as have a lot of people. I've heard that superglue on the red gear to hold it to the rod works (my red gear was cracked).
      No, there is not a way to recalibrate it. The best way I understand how the speedo works is that a magnet is attached to the cable end, and spins and pulls another magnet to lift the needle, and that pull force works against that tiny tiny brass spring you see on top of the main needle shaft. That needle must have different specs for each speedo reading and changing it I believe is what does it. But it's so sensitive that anything you do to it WILL screw it up.
      Ah. Well my problem is not that the red gear pops off the rod persay, but that the WHOLE rod comes out along with the Red gear. The red gear does not move, the rod does.
      Hmmm well that sucks. Well actually, you know that if you move the needle to a different angle it will show a different angle right? Lets say that you make the needle stay stationary at 20 mph by taking it off and rotating it. Well why not do the exact opposite? Put the needle UNDER the litte shelf it has at zero, fasten it, then put it above the shelf? By that way, then the speed should register about 10mph more to match the difference you spoke about. Idk. Crazy but yeah.
      Best 4x100 Thread! Show What You Got!
      Build Thread: Victoria, My 1990 Jetta GLI
      Build Thread: Milan, my 1990 Golf GL
      21 years old and a 16VG60 engine that FINALLY runs & idles. Now onto the next project!
    2. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12 Golf 2.5, 90 Jetta GLI 16v, 99.5 Cabrio Highline, 92 Golf GL
      07-14-2011 06:56 PM #152
      That wouldn't work because the zero mark would move. The mph climbs faster on the 140 speedo so you would have to do something that changes the speed at which the needle climbs (like adjust the spring).
      Just trust me, it won't work. You need to either use the 120mph face or find a 140mph speedo.
    3. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-14-2011 07:14 PM #153
      Dang well in the mean time that I have the 120mph faceplate on, about how much do 16V clusters cost?
    4. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-14-2011 08:10 PM #154
      You can usually just find the speedometer by itself for cheap, about the same as any other. Needs to be from a later style CE2 cluster as I'm sure you know.
      I bought an 85mph speedo from an 82-84 Quantum... I'd love to use it, because the narrow range means it'll be super accurate and who needs over 85 anyway?
    5. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-14-2011 08:19 PM #155
      I don't think there's anyone in the classifieds that would sell just a speedo. And my junkyards don't have any GLI's.
      Hahaha I saw a sparkly green Dasher wagon at the junkyards the other day. Pretty clean and I think it had the 85mph speedo. I would love to see one of them in a Mk2. That'd be pretty cool.
    6. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      07-14-2011 08:37 PM #156
      I have a 140 cluster. It's a CE1 so i dunno if the guts are interchangeable. Can you confirm Jay?
      Everything VR6Turbo & Supercharged The world is ours!!
      Follow us on Instagram @ Everything_VR6turbo_SC
      FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    7. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-14-2011 08:57 PM #157
      mechanically yes, but the voltage regulator mounts differently so you'll have to find a way to secure it. Also the oil pressure system in the CE1 speedo can be removed, it's not needed. CE1 (and early CE2) speedos are marked every 10, while late CE2 speedos are every 20.
    8. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      07-14-2011 10:03 PM #158
      Gotcha
    9. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-14-2011 10:28 PM #159
      Well i'm just going to find someone willing to sell a CE2 16V Cluster. And use it for parts. Thanks Capt.Dreadz for the offer. I appreciate it
    10. Geriatric Member steveo27's Avatar
      Aug 1st, 2005
      Pittsburgh
      2011 TRD Tacoma. Fake GLI. MK2 Unicorn
      07-14-2011 10:38 PM #160
      im pretty sure i have a 120 speedo if you want it
      YOUR STICKER CLUB SUCKS
      Crooked Euros
      - Powered by Pabst and whiskey
      We Do It Big In PA
    11. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      07-14-2011 11:43 PM #161
      Quote Originally Posted by steveo27 View Post
      He needs a 140
    12. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-15-2011 01:34 AM #162
      Quote Originally Posted by Capt.Dreadz View Post
      He needs a 140
      Yep. But thanks Steve
    13. Geriatric Member steveo27's Avatar
      Aug 1st, 2005
      Pittsburgh
      07-15-2011 01:37 AM #163
      swap in the whole 120 unit, its not like the cars gonna ever go 140mph
      Crooked Euros
      We Do It Big In PA
    14. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      07-15-2011 01:42 AM #164
      touche
      When i used mine when i had my 16v, i never went to 140. Not even 120.
    15. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-15-2011 02:27 AM #165
      I'm going for the factory fresh look. And since my car did not come with the 120mph, it won't get a 120mph if I can help it. And when I take it apart I like to make it look like it's going 140mph
    16. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-15-2011 03:07 AM #166
      I can realistically to 120, not 140 :p
      side note, did you know that the stock .91 5th/3.67 fd means that when the 2.0 16v hits redline in 5th (if that was possible), it would JUST be hitting 140. This also means that a european model with the 160mph speedo can't physically go that speed with the stock trans :p
    17. Banned Ajaxpowder's Avatar
      Oct 9th, 2010
      AB, Canada
      1992 Golf GL
      07-15-2011 05:46 AM #167
      Maybe I am crazy but i thought that the Speedo guts where the same However the cable that drove them was different?
    18. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      07-15-2011 01:40 PM #168
      The euro models with 160 speedo have G60's in them
      @Ajax,
      That & the gearing in the cluster. Example...When i installed a 2.0L MK3 cluster in the Coupe awhile back, not only was the speedo way off, so was the tac. A mere tap on the gas relined it. Anything pass 45mph & the needle was dubstep dancin'
    19. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-15-2011 02:16 PM #169
      Haha 'tis true.
      Wow, that's pretty cool! But I mean if someone were to actually hit 140 that would be the once and only time it would happen right?
      Also, I'm not to smart with engine/transmission specs, what do the underlined number mean? Thanks!
    20. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-15-2011 09:11 PM #170
      Quote Originally Posted by Ajaxpowder View Post
      No, it's only the speedo thats different. Cable is always the same. The gear is different on different models to match the final drive, not the speedometer. The speed compensation is only in the speedometer.
      @Ajax,
      The uk 16vs had the 160 speedup too, with the same trans as us. I think the g60s had similar ratio transes too.
      I have NO idea what yore talking about in the second part of this post... I think you had done electrical issues...
      The numbers I posted are the 5th gear ratio and final drive, which together (with the tire size) determine the overall ratio that the engine rpm has to road speed.
    21. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-15-2011 11:20 PM #171
      So Jason, I've heard of better cruising 5th gears that I can swap into my 2Y transmission, what are the details? I want to be able to go on the highway at 70-80 without exiting the car with ringing from the engine/exhaust in my ears.
      Ok so I went out and put my dash back together tonight because the weather had cooled down to a comfortable 95 degrees.
      Pics:
      I still have to put the steering wheel and console on. But I'll do it tomorrow, early in the morning.
      Meanwhile, I am waiting for my 2nd set of all red tail lights to cure. These came out a lot better than my first one. I am just waiting for my U-Pol Clear #1 clearcoat so it won't fade in the sun like my first set is doing.
    22. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-16-2011 02:22 AM #172
      Preyty much your only option for a 2y is the .80 from a mk3. I have one in my car and I love it.
    23. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-16-2011 02:25 AM #173
      What are the upsides? How hard is it to take out of the transmission? There are a couple Mk3s at my local junkyards.
    24. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-16-2011 02:26 AM #174
      What do you mean upsides? Why did you ask? Lol.
      It's something thats easier to do with the trans out of the car and you do need special tools so an experienced helper is a plus.
    25. Member Volkswageneer1990's Avatar
      Dec 18th, 2009
      Dallas, TX
      07-16-2011 02:30 AM #175
      Lol true true. I guess a better question is what is the avg. cruising RPM going 70 on it?
      No yeah, I gotcha, I was planning to just drop the trans out and just take it apart right there and the on the floor. I was hoping it was easy like taking off bolts and stuff.
