Page 3 of 27 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 925
Thread: Build Thread: Victoria, my 1990 Jetta GLI
  1. Member akern2's Avatar
    Sep 20th, 2007
    Gaithersburg, MD
    1991 Gli
    06-21-2011 06:17 PM #71
    So....uh....what are you planning on doing with those clear/red tails?.....
    If your exciter wire, brushes, and what not are all good, keep in mind the age of the alternator belt. I had one that stretched too far and wouldn't let the alternator charge, but it made no squeeling noise.
    Edit: new page bitches.
    Quote Originally Posted by greenraVR6 View Post
    Poke and no low = no bueno fo sho
  2. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    06-21-2011 06:29 PM #72
    Quote Originally Posted by VDub2625 View Post
    The battery light will come on as steveo mentioned, when the key is switched on and the alternator exciter is hooked up properly. If that does come on (and goes out when the car is running), then I'd try changing out the voltage regulator, or at least checking the length of the bushings.
    yep. the charging systems on these cars is stupid, the circuit goes through the cluster, and if the bulb is burned out/not lighting, the system will not charge properly
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  3. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    06-21-2011 06:33 PM #73
    It's not a bulb, it's an LED so it's not likely it'll ever burn out in the car's life, and that's just the indicator light, there are resistors in the cluster that actually put a draw on the exciter wire like is required. but it is a little odd that they're there. Guess it's a safety rhing (require the cluster for the car to run right).
    A2Resource
  4. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    06-21-2011 06:35 PM #74
    LED, bulb, same thing. if it does not light, its not charging :p
    O/R/T
    We Do It Big In PA
  5. Member akern2's Avatar
    Sep 20th, 2007
    Gaithersburg, MD
    1991 Gli
    06-21-2011 06:38 PM #75
    Quote Originally Posted by steveo27 View Post
    Do you freak out when the light comes on? Like check EVERYTHING only to realize the interior lights were on overnight killing the battery slightly.....
  6. Member twinrado's Avatar
    Jun 23rd, 2005
    Roseville (St.Paul)
    Corrado, Audi A6, Passat
    06-21-2011 07:22 PM #76
    whats the size for the upper dash speakers?
    There's no such thing as too much of anything but to little results in the need for more.
  7. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    06-21-2011 07:32 PM #77
    3.5".
    A2Resource
  8. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    1990 Jetta GLI 16V; 1990 Golf GL
    06-21-2011 07:42 PM #78
    when you turn the key to on, does the battery light come on?
    the exciter wire runs from the alternator to A2/02 on the fuseblock, test for continuity between those 2 points
    No, the battery light does not turn on when it is turned to the ON postion.
    So I just connect the positive probe of a multimeter to the blue wire, and the negative probe to the negative on the battery and just see if it is getting any charge?
    and for restoring the paint, give this a good read
    http://forums.vwvortex.com/showthrea...le-stage-paint
    This was an eye-opener! That's crazy how well the paint can look after a good polish!
    Thanks for this
    Quote Originally Posted by Keithcar View Post
    Yeah, i used turtle wax rubbing compound first to get rid of the heavy oxidation, its really aggressive stuff, so use it only on paint that really needs it. then claybar, polish, then wax. I used zymol it seemed to work pretty good. plus it smells like bubble gum. i dont remember if i clayed it before or after the polish, somebody else should be able to chime in with the etiquette. dont go to crazy because there is a thin clearcoat.
    Thanks for the advice. I'll look into this
    As for the AC, that brown wire is just a ground, the green wire (still hooked up) is the signal. So ground that brown wire (or connect it to the brwon wire in the sheath again) and you'll be all set.
    The light does not come on in the ON position. The only bulb is the oil pressure indicator that is blinking.
    Awesome. Looks like I'm gunna have to break out the soldering equipment....
    Quote Originally Posted by akern2 View Post
    Haha I don't really know... PM me an offer for 'em
    Hmmmm good info. Thanks
    ^ This.
    Are you serious?? That is stupid....
    Best 4x100 Thread! Show What You Got!
    Build Thread: Victoria, My 1990 Jetta GLI
    "I'm 17, with a GLI that's 3 years younger than my High School. How's that for survival of the fittest?!"
  9. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    06-21-2011 07:54 PM #79
    The wire from the harness, ground it, the battery light should come on. That will tell you if the wiring from the laternator back through the fuse box to the cluster is ok.
    A2Resource
  10. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-21-2011 08:11 PM #80
    Take the wire from the harness, ground it, the battery light should come on. That will tell you if the wiring from the laternator back through the fuse box to the cluster is ok.
    I think you missed a word... Just kidding. How exactly do you want me to take the wire from the haness and ground it? You want me to de-pin it or something? Electrical stuff is not my strong suit at alllll.....
  11. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    06-21-2011 08:24 PM #81
    Unbolt it from the alt, touch it to ground (or connect it to a jumper wire if it can't reach).
    A2Resource
  12. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-21-2011 08:30 PM #82
    Gotcha.
    And once I do that the light should come on?
  13. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    06-21-2011 08:41 PM #83
    Yep, the battery light should light. if not there's a wiring problem. If it does, the alt is messed up in some way (maybe the voltage reg, check that too).
    A2Resource
  14. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-21-2011 09:39 PM #84
    Great! Thanks again!
  15. Member akern2's Avatar
    Sep 20th, 2007
    Gaithersburg, MD
    1991 Gli
    06-21-2011 11:19 PM #85
    $25 shipped! jk lol
  16. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-21-2011 11:36 PM #86
    $25 shipped! jk lol
  17. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    06-22-2011 12:54 AM #87
    i was experiencing a similar problem with my car after i swapped the 12v into it. turned out the exciter wire was cracked / corroded inside the plug, where you couldnt see it. fixed / replaced the broken wire, and it was gravy
    O/R/T
    We Do It Big In PA
  18. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-28-2011 02:41 PM #88
    Ok, well yesterday I got back from my trip to D.C. and I must say, I loved the weather
    Anyway, it is too hot today to go out and test the alternator wire so I will wait for around 7 PM when it cools down.
    In the meantime, I am estatic about all the stuff I got from the mail today!!
    1/8" Pinstripe for the dash
    NOS Late Rear VW Emblem
    Spare fuses
    Front Euro Plate Tub for when I get my custom licence plate from Sweden
    And my favorite thing....
    NOS rear power window switch surround! With the banana looking clip still attached!
    (close up)
    I also got the suspension refresh kit from WRD. Pretty good stuff.
  19. Member CCRyder's Avatar
    Feb 2nd, 2005
    Longview, Texas
    His-1990 Jetta GLi 2.0L 16V- Hers-2010 Passat
    06-29-2011 12:13 AM #89
    Quote Originally Posted by ratdub View Post
    i'm not feeling the red ra's...i like the stock silver look of them on any color mk2...
    ditto on the red center wheels.......
    You drove 1400 miles to Virginia, I'm getting ready to fly to San Diego ( 1400 miles) and drive back to Longview Texas in a 1990 GLI ! Hard to find Mk2 Jetta's in Texas ....but no trouble finding nice looking pick up trucks ! LOL
    1991 Jetta GL 1.8-sold-1997 Jetta GLX VR6-sold 2003 Passat 1.8T-sold
    2010 Passat 2.0T
  20. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-29-2011 12:28 AM #90
    Quote Originally Posted by CCRyder View Post
    Well we flew to Virginia and drove back but yeah 1400 miles! Haha no way! Trust me, if the car makes it back in one piece like mine, you are going to love the drive.
    When you get it, post some pictures so we can see it! It's always awesome to see another person in Texas with a Mk2! The only ones I've seen in the DFW area are 2 Golfs. No Jettas! You're right about that! And personally, I think bone stock F-150's are nice looking trucks. My friend has one of them and it's pretty nice
  21. Member akern2's Avatar
    Sep 20th, 2007
    Gaithersburg, MD
    1991 Gli
    06-29-2011 12:32 AM #91
    You were in D.C (I'm assuming our nation's capital) and didn't tell me! I'm like 45 mins away!
  22. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-29-2011 01:00 AM #92
    Hahahaha sorrryy! I didn't bring the tails though... What else were you planning to meet for?
  23. Member twinrado's Avatar
    Jun 23rd, 2005
    Roseville (St.Paul)
    06-29-2011 10:35 AM #93
    When do you plan on giving and car a buff then wax job? I started doing mine and I must say it makes a whole lot of a difference and also how much did you spend on the whole suspension refresh kit?
  24. Member akern2's Avatar
    Sep 20th, 2007
    Gaithersburg, MD
    1991 Gli
    06-29-2011 11:42 AM #94
    Quote Originally Posted by Volkswageneer1990 View Post
    I dunno. Show you my car?
  25. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-29-2011 11:50 AM #95
    Quote Originally Posted by twinrado View Post
    Whenever the low temp here in Dallas decides to dip under 90 degrees.... It's too hot to do it during the day!
    I spend $69.XX Shipped (I don't remember the cents). It is on sale right now:
    http://forums.vwvortex.com/showthrea...ENDS-June-27th!!
    Haha dang, well maybe next time
  26. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    06-29-2011 11:54 AM #96
    watch out for john. he listens to dave mathews band, plays alotta gamecube, reeks of ax, and drinks natty light
    O/R/T
    We Do It Big In PA
  27. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-29-2011 01:02 PM #97
    Hahahaha! Well "Space Between" is a perfectly acceptable song.....
    All the other things.... thanks for the heads-up Haha just kidding, but gamecube? Those things still exist?!
  28. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-30-2011 03:28 PM #98
    Ok, update time. Well I went out and tested the alternator last night. Turns out, it doesn't work for s**t.
    We tested to see how much voltage the battery had by itself, no jumper, not running, and we got 11.92V
    Then we jumped the car and tested it again, and it was the same, 11.92V. So we have established that the alternator is not working. I am taking it to autozone to see if they can repair it, and for how much.
    On a seperate note, I tested the alternator by unbolting the blue wire and grounding it to see if this happens:
    The light did not turn on. So is it still the alternator? Or should I see if the LED in the cluster still works?
    On a seperate seperate note, I forgot to post a picture of my new favorite thing that will be on my windshield at shows
  29. Member akern2's Avatar
    Sep 20th, 2007
    Gaithersburg, MD
    1991 Gli
    06-30-2011 03:40 PM #99
    Damn! I know you got that off of "greatfox". Nice piece.
  30. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    06-30-2011 03:48 PM #100
    The alternator could still be ok, the exciter wire is what turns it on when the engine is running so if the connection to the cluster is bad, it won't charge. Try groundig at the fuse box end of the cluster harness, and at the point where the exciter wire enters the front end harness from the fuse box. That will tell you if it's the cluster, fuse box, or front end harness.
    A2Resource
  31. Member Volkswageneer1990's Avatar
    Dec 18th, 2009
    Dallas, TX
    06-30-2011 07:48 PM #101
    Ok, ok. So you are saying to take the male end of the reciever of the blue exiter wire from the T1/f single plug near the battery and ground it there?
    Or are you saying to take the A2/01 wire from the fusebox harness and ground it on the grounding plate left of the fusebox using a small jumper cable?
    And will the bulb tell me if it is the cluster, fusebox, or front end harness? Or something?
    I don't understand too well how you want me to ground it, sorry, noob moment.
  32. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    06-30-2011 07:53 PM #102
    Apparently
    Any of those points can help. You need to ground it at different points along the wire until you see the desired result, that will help isolate the problem.
    A2Resource
  33. Member mullenite's Avatar
    Nov 9th, 2010
    Miami, Fl
    92 Golf GL
    06-30-2011 08:35 PM #103
    You can check that the led itself is fine by turning the key to on but leaving the engine off.
  34. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    06-30-2011 08:55 PM #104
    Quote Originally Posted by mullenite View Post
    That is only if it's properly hooked to the alternator. The light is on when you do that becuase the alternator is powered but not charging or spinning. if you unplug the blue wire the LED will never come on.
    A2Resource
  35. Member mullenite's Avatar
    Nov 9th, 2010
    Miami, Fl
    92 Golf GL
    06-30-2011 09:27 PM #105
    So these cars don't have a KOEO circuit in the cluster itself? That seems strange considering my old '82 Chevy C10 did, and every other car ive owned.
