Page 1 of 11 1 2 3 4 5 ... LastLast
Results 1 to 35 of 358
Thread: Part-Out: 2001 S4 Black Auto
  1. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    2006 Audi A3 2.0t DSG
    02-01-2011 07:55 PM #1
    I have an S4 I am looking to part out. Everything is available. It has black exterior and the interior is black with grey alcantara inserts.
    Let me know what you are looking for and I will get back to you as far as pricing, shipping, and everything else.
    I am located near Atlanta GA and I will be updating this with parts as I sell them.
    --Eric
    ITEMS SOLD::::
    INTERIOR ALUMINUM BELTLINE TRIM
    DRIVERS SIDE FENDER
    PASSENGER SIDE FENDER
    DRIVERS FRONT BOSE DOOR SPEAKER
    PASSENGER FRONT BOSE DOOR SPEAKER
    SIDE SKIRTS
    BLACK FELT WEATHERSTRIPPING
    SKID PLATE
    SUN VISOR CLIPS
    REAR BRAKE SETUP (PADS/CALIPERS/CARRIERS/LINES/ROTORS/HARDWARE)
    VANITY LIGHTS ON HEADLINER (UNDER SUN VISORS)
    DRIVERS SIDE REAR DOOR
    DRIVERS SIDE FRONT DOOR
    PASSENGER TAIL LIGHT
    MIRROR GLASS
    FRONT BUMPER
    REAR ABS SENSOR
    ARM REST LID
    HID'S AND BALLASTS
    HEADLIGHT SQUIRTERS / COVERS
    CENTRAL LOCKING PUMP
    WARNING TRIANGLE
    CARGO NET
    BATTERY COVER
    IN-DASH CUP HOLDER
    DRIVERS SIDE FRONT SEAT BELT
    OH S*** HANDLES
    SUNVISORS
    SUNROOF CONTROL / MAP LIGHT
    HOOD
    S4 GRILLE
    HOOD STRUT
    PASSENGER SIDE HEADLIGHT
    PASSENGER SIDE INTERCOOLER
    K&N FILTER
    REAR DECK BOSE SPEAKER
    HVAC CONTROLS
    RADIATOR CORE SUPPORT
    INTERCOOLER SHROUDS
    DRIVERS / PASSENGERS FRONT INNER FENDER LINERS
    TIMING BELT COVERS
    TRIM ON TOP OF STEERING COLUMN
    ALUMINUM PLATES UNDER CAR
    SYMPHONY RADIO
    TCU
    N75 VALVE
    J BOX ECU
    FRONT BRAKE SETUP (PADS/CALIPERS/CARRIERS/LINES/ROTORS/HARDWARE)
    MIRROR CAPS
    ANTENNA DIVERSITY BOX
    HAZARD TRIM
    CIGARETTE LIGHTER ASSEMBLY
    ASHTRAY
    CD CHANGER COMPLETE W/ MOUNTING BRACKET
    AUTO DIM REAR VIEW MIRROR
    GAS CAP
    WIPER BLADES
    GAUGE CLUSTER
    REAR MAP LIGHT CLUSTER
    STEERING WHEEL W/ AIRBAG
    AC CONDENSER FAN
    CENTER VISOR
    AIR BAG MODULE
    OWNERS MANUAL
    AIR BAG CLIPS
    PASSENGER FRONT POWER WINDOW MOTOR
    PASSENGER REAR POWER WINDOW MOTOR
    PASSENGER FRONT WINDOW REGULATOR
    TIPTRONIC CIRCUIT BOARD
    CHROME TIPTRONIC SHIFTER SURROUND
    REAR BUMPER
    ALL FOUR O2 SENSORS
    FLOOR MATS
    AIRBOX
    AIRBOX TO RADIATOR SUPPORT PLASTIC PCS (2)
    FILLER PLATE
    COIL PACKS
    WHEELS AND TIRES
    CENTER VENTS X 3
    MAF SENSOR AND HOUSING
    B-PILLAR COVERS
    C-PILLAR COVERS
    MAP SENSOR
    REAR SEAT BELT SET
    EGT SENSORS
    FAN CLUTCH AND PULLEY
    SNUB MOUNT
    SERP BELT
    CLUSTER PIG TAILS
    FOG LIGHTS
    DRIVERS SIDE AXLE SHIELD
    COMPLETE FUEL PUMP
    FRONT BUMPER BRACKETS
    SNUB MOUNT
    SERP BELT
    CABIN MOTION SENSOR
    POWER / HEATED / AIRBAG PIGTAILS FOR DRIVER & PASSENGER SEATS
    SPORT SEATS (BLACK LEATHER / ALCANTARA INSERTS)
    SPORT DOOR CARDS
    SUNROOF SLIDE COVER
    WASHER FLUID BOTTLE
    HOOD WEATHERSTRIPPING
    HEADLINER
    STRATMOSPHERE DIVERTER VALVES
    POWER STEERING PUMP, BRACKET, AND HARDWARE
    HAZARD SWITCH / RELAY
    PASSENGER FRONT ABS SENSOR
    E-BRAKE CABLES
    TURN SIGNAL PIGTAILS
    FOG LIGHT PIGTAILS
    FRONT SWAY BAR
    REAR SWAY BAR
    BRAKE BOOSTER / BRAKE MASTER CYLINDER / BRAKE RES
    FUEL DOOR
    SIDEMARKERS
    LICENSE PLATE LIGHT BAR
    POWER STEERING COOL LINE
    REAR S4 BADGE OFF OF TRUNK
    FRONT LOWER SPRING PERCHES
    A/C LINES UNDER ENGINE
    APR BI-PIPE
    STEERING COLUMN COVER
    FULL SET OF LUG BOLTS
    ELECTRIC RADIATOR FAN
    CAT-BACK EXHAUST
    FRONT SHOCKS
    FRONT SPRINGS
    POWER STEERING HOSE
    PASSENGER SIDE AIR VENT
    ABS MODULE (PUMP & CONTROL)
    RADIATOR
    FUEL PRESSURE REGULATOR
    ALTERNATOR
    OEM JACK KIT
    SPARE TIRE HOLD DOWN
    TRUNK LID
    TIPTRONIC DOWNPIPES
    VALVE COVERS
    CARPET
    DRIVERS SIDE SUBFRAME MOUNT
    AC CONDENSER
    HORN SET W/ PIGTAILS
    DRIVER SIDE INTERCOOLER
    DRIVER SIDE TURBO OIL RETURN LINE
    POWER STEERING RACK
    MIRROR BASES / MOUNTS
    TURBO MANIFOLDS
    REAR SHOCK MOUNTS
    COMBINATION SWITCH
    DRIVERS SIDE TAIL LIGHT
    COMPLETE FRONT WIPER ASSEMBLY
    C-PILLAR PLASTIC PIECES AROUND WINDOWS
    IGNITION CONTROL MODULES
    PASSENGER FRONT DOOR
    HEATER CONTROL VALVE
    INTAKE MANIFOLD
    MOTOR MOUNTS (FRONT PAIR)
    PASSENGER SIDE SEAT BELT
    KEY FOB
    K03 TURBOS
    RAIN TRAY W/ WEATHERSTRIPPING
    REAR SUBFRAME
    BOSE AMP
    DRIVER SIDE FRONT STEEL UPRIGHT
    TRUNK STRUTS
    FIRST AID KIT
    FUEL RAIL
    THROTTLE BODY
    FOG / ESP BUTTON
    SECONDARY AIR PUMP
    Y-PIPE
    DRIVERS SIDE HEADLIGHT
    REAR STRUTS
    REAR DOOR BOSE SPEAKERS
    ENGINE COVER SET (6 PCS)
    OIL PAN SET (UPPER AND LOWER)
    REAR DIFFERENTIAL
    REAR TRAY SHELF
    REAR SPRINGS
    FUEL INJECTORS
    TRUNK MAT
    DRIVERS SIDE TRUNK INTERIOR CARPET
    PASSENGERS SIDE TRUNK INTERIOR CARPET
    OEM BOOST HOSES
    TURBO INLET PIPES
  2. Junior Member
    Feb 13th, 2010
    Rocky Hill, CT
    2000 Audi S4 Quattro
    02-01-2011 08:06 PM #2
    pm'd
  3. Banned emilgevor's Avatar
    Sep 21st, 2009
    Upstate New York
    2000 Audi S4 GIAC Tuned
    02-01-2011 08:24 PM #3
    Im looking for a Auto Dim Rear view mirror? you got one?
  4. Member JumboBlack1.8's Avatar
    Sep 22nd, 2006
    Boston, MA/ West Hartford, CT
    2000 Audi B5 S6, 1998 E39 528i
    02-01-2011 08:56 PM #4
    PM'd
    Project: 2000 Audi B5 S6 --- 4.2L S6 6speed
    DD: 1998 E39 528i
  5. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-01-2011 09:03 PM #5
    everybody replied to....
  6. Member
    Sep 24th, 2010
    queens NY
    00' a4 tuned
    02-01-2011 09:48 PM #6
    pm'ed
  7. Member mk2dubdriver's Avatar
    Oct 15th, 2003
    Wilkes Barre Pa
    1997 Audi A4 1.8T Quattro
    02-01-2011 10:21 PM #7
    Pics of the front bumper?
  8. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-02-2011 08:58 AM #8
    everyone replied to and will have pics up of the car and everything tonight.
  9. 02-02-2011 09:49 AM #9
    Hi I want to buy the front and rear bumper. If there still available
  10. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-02-2011 10:14 AM #10
    Pm'ed cumbia_s4
  11. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-02-2011 08:03 PM #11
    to the top!
  12. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-03-2011 07:29 AM #12
    bumpity bump
  13. Junior Member
    Jan 27th, 2010
    99 audi a4, 95 jetta 2.0
    02-03-2011 08:48 AM #13
    front bumper pm me
    bro
  14. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-03-2011 09:00 AM #14
    PM'ED -- chriiboy90
  15. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-03-2011 02:52 PM #15
    to the top!
  16. Junior Member cfigs13's Avatar
    Dec 2nd, 2010
    south jersey
    2000 a4
    02-03-2011 03:56 PM #16
    Bumpp pm'd
  17. Junior Member
    Dec 16th, 2010
    Ohio fairfield
    02-04-2011 12:56 AM #17
    whats about the engine???
  18. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-04-2011 09:52 AM #18
    pm's replied to....morning bump!
  19. Junior Member
    Jun 27th, 2010
    98 A4 Avant. Gone but not forgotten.
    02-04-2011 05:27 PM #19
    Side skirts/lower molding to 19192?
  20. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-05-2011 10:28 PM #20
    side skirts are sold.
  21. Member iamderrik's Avatar
    Feb 5th, 2011
    Upstate NY
    84 Rabbit GTi, toyota camry daily driver
    02-05-2011 10:57 PM #21
    Heated leather?
    Dirt.
  22. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-06-2011 12:21 AM #22
    iamderrik - heated seats, sport edition (black with grey alcantara inserts)
  23. 02-06-2011 03:16 AM #23
    are the lower door mouldings/blades still available? if so how much?
  24. Member SpOOkyRollerDisco's Avatar
    Apr 9th, 2003
    Atlanta,Jawjuh! home of southern people
    MKIII trek | 99.5Never lose quattro
    02-06-2011 03:29 AM #24
    any pics of the bumper? im local (vinings)
    how much for the seats?
  25. Member split71's Avatar
    Aug 26th, 2006
    Winston-Salem, NC
    '02 E39 M5, '02 Sonoma ZR2
    02-06-2011 11:00 AM #25
    Can you PM me a price on the visor clip for the drivers side and a rear deck bose speaker?
  26. Member
    Sep 24th, 2010
    queens NY
    00' a4 tuned
    02-06-2011 11:50 PM #26
    any updates when parts will be shipped
  27. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-07-2011 08:21 AM #27
    i am waiting on paypal to deposit some money into my account and i will have all parts headed out. sorry for the delay. my wife's paycheck wasn't what we expected so we had to transfer some around.
  28. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-07-2011 08:23 AM #28
    all pm's replied to
  29. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-07-2011 04:19 PM #29
    bumpity bump
  30. 02-07-2011 05:10 PM #30
    so do you still have the lower door mouldings?
  31. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-07-2011 07:05 PM #31
    pm'ed jdmfairlady21
  32. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-08-2011 07:10 AM #32
    morning bump!
  33. 02-08-2011 09:50 AM #33
    How much for the rear brake calipers/carriers/rotors/pads/lines?
  34. Member lilrdwgn's Avatar
    Aug 15th, 2007
    Acworth GA
    02-08-2011 10:49 AM #34
    pm'ed rumblebug
  35. 02-08-2011 11:47 AM #35
    how much for the front and rear seats shipped to 93101
