VWVortex.com - How to repair your FUBA antenna mast/whip
    Results 1 to 11 of 11
    Thread: How to repair your FUBA antenna mast/whip
    1. 02-04-2011 01:35 AM #1
      If you have cracks in your FUBA antenna you can add years of life to it by adding some heat shrink to it. You will need a heat gun, some pliers, scissors and large dia. heat shrink sleeve.
      Cut the end of the heat shrink square.
      Expand the end so it will fit over the widest part of the mast:
      Rotate and expand the end some more so it will fit over the widest part of the mast:
      Slide the heat shrink over the mast and check the length before cutting:
      Mark the spot for cutting:
      Cut to length:
      Slide the heat shrink over the mast as shown:
      Cut a second heat shrink piece the same size or just a little longer:
      Slide the first piece over the mast:
      Use the heat gun to shrink the material (don't melt the antenna):
      Slide the second piece over the first:
      Use the heat gun to shrink the material:
      You have a repaired FUBA antenna mast/whip.
      TEAM DHE/FAST 76 KARMANN 8V FSP MK1 SILVER SCIROCCO 2X 08,9,10,12,13 & 14 regional champ.
      TEAM DHE/FAST 1980 KARMANN 8V FSP MK1 RED SCIROCCO 04 & 07 regional champ.
      1987 KARMANN 16V MK2 SILVER SCIROCCO
      Parts--> http://www.parts4vws.com Need Wax?--> Mother's
      Dec 16th, 2010
      south jersey
      87 16v rocco
      02-04-2011 09:06 AM #2
      tnx for sharing. good infromative tip.
    3. Member 16vSciroccoFrank's Avatar
      Jan 18th, 2011
      Southern. NH
      1987/VW/Scirocco-1994/VW/Jetta-1998/Chevy/(BedLined)Lumina
      04-07-2011 11:25 PM #3
      That is an Amazing Idea!!!
    4. 04-08-2011 01:10 AM #4
      Quote Originally Posted by 16vSciroccoFrank View Post
    5. Member -camber's Avatar
      Jan 4th, 2001
      CPT
      JettaVI,W203
      04-08-2011 01:16 AM #5
      you're hands look really soft
      bang reggae music
    6. 04-08-2011 01:18 AM #6
      Quote Originally Posted by -camber View Post
      Sorry, I don't want to hold hands.
    7. Member jaysonhadwick's Avatar
      Jan 26th, 2009
      Carson City Nevada
      88 Scirocco 16v, 80 Scirocco soon to be 16v, 80 chevy k-10 1/2" ton pos, 55 buick special, 83 puch
      04-08-2011 01:23 AM #7
      cool idea! cough cough, i just bought a new one, cough, cough but again cool idea!
      A sloth gets robbed by three turtles. The sloth calls the cops and they ask him "so can you tell us about the robbery?" and the sloth say's "I'm not sure.............It all happened so fast......."
    8. 04-26-2011 02:22 AM #8
      More repairs:
      If your antenna has major cracks in it, it can still be saved.
      Fill the gaps:
      wrap with electrical tape:
      After the filler sets remove the tape and cover with a thin layer of silly putty.
      Cover with heat shrink:
    9. Member Falcor's Avatar
      May 26th, 2004
      Sweden
      2003 Golf TDI 130, 964 Carrera 2
      04-26-2011 03:05 AM #9
      wow...
    10. Member microdub98's Avatar
      May 12th, 2007
      York Haven, Pa
      No more VW's
      04-26-2011 09:44 AM #10
      Very very cool , thanks for sharing .
    11. 04-26-2011 12:14 PM #11
      Quote Originally Posted by jaysonhadwick View Post
      Traditionally Scirocco drivers are more clever than wealthy. During the rescission / meltdown we were counting the the change in the sofa but still wanted to make repairs on the cars. This falls in the "saving what you have with stuff you have sitting in your garage" category. It is more fun for folks that like to fix stuff themselves rather than have someone fix it for them. I had 5 antennas sitting in a box that needed some help.
      This one needed a tip:
      It is true that you can just get a new 16" antenna mast for about $7.00 - $ 19.00 but it will fail after about 5 years in the sun. If you put antenna balls on your Fuba it will fail faster. After you use this method for repair you can add an antenna ball if you like. With the 5 bucks you save you can get a foot-long sub at Subway.
