Page 15 of 28 FirstFirst ... 5 11 12 13 14 15 16 17 18 19 25 ... LastLast
Results 491 to 525 of 946
Thread: DarkSideGTI Big Turbo Build Round 2
  1. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-10-2011 11:11 AM #491
    here are a couple pics of the wheel fitment too.
    front
    rear
  2. Member President Lincoln's Avatar
    Jun 27th, 2005
    Kanosh
    83, 85 & 91 Jetta - 87 & 03 GTi - 13 Golf R
    06-10-2011 02:22 PM #492
    Looking good Nick
    1966 Beetle - 83 Jetta Deluxe - 87 VR GTi - 20th AE GTi - 2012 Tiguan (hers)
  3. Member dr. b's Avatar
    Jul 14th, 2005
    motorsport capitol, the world
    i scrape a gt4088R32, she rocks a B8
    06-11-2011 09:24 AM #493
    Looks awesome.
    i like your new sig as well.
    (may get to start mine this weekend....maybe)
    "I'm DrB and I approve this message."
    instagram doktor_b
    projekt oveRhaul - i hate my caR and i hate you too
  4. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-11-2011 10:50 PM #494
    This was today's job.
    brushed and vacuumed out the entire car seats out and all.
  5. Member mdubcajka12's Avatar
    Aug 7th, 2006
    Yinzersville
    .:Ruined, Estate
    06-13-2011 12:49 AM #495
    looks good man. i do that everytime i clean my car. makes it easier to do the interior
  6. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-13-2011 11:07 AM #496
    Is there a way to check my alternator run? I am not sure if my battery is just dead or if the alternator is not charging it back up.
  7. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    06-13-2011 11:26 AM #497
    Quote Originally Posted by DarkSideGTI View Post
    just start you car and put a volt meter on the back of the alt and see if it is putting out a charge
  8. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-13-2011 11:59 AM #498
    hmm, where on the back? my alt is a little hard to get to with the SRI on there.
  9. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    06-13-2011 12:23 PM #499
    oh shoot, didnt think about that...but yes that is where you would test it....
    you could just take the battery to autozone or someplace like that and have them test it....
  10. Member huichox4's Avatar
    Nov 8th, 2004
    83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
    06-13-2011 12:33 PM #500
    Vag-com might tell you how much it is putting out
  11. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    06-13-2011 12:59 PM #501
    My system is weird that way. My alt checker says fail but the car charges fine and no workshop.
  12. 06-14-2011 04:57 PM #502
    What are your final et's with your wheels in this picture?
  13. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-14-2011 05:20 PM #503
    25f 13r.
  14. Junior Member rsougti's Avatar
    Dec 14th, 2007
    Biarritz (F)
    2002 Golf MKIV TDI 130
    06-15-2011 01:36 PM #504
    Very nice car, I like specialy your VMR V710 !
  15. Member JamesO's Avatar
    Apr 13th, 2006
    DFW, Texas
    04 HPA R32T
    06-15-2011 03:37 PM #505
    Quote Originally Posted by arethirdytwo View Post
    The electronic "checkers" are finicky because they have a pre-set parameter built in to say whether a battery or alternator is bad. And those specs are usually determined by the supplier, and can vary, of said checker.
    You must look at several different readings to accurately pinpoint the culprit.
    These step described are using a DMM:
    -Get pad of paper and document readings for "No Load" vs "Load"
    1. Take a battery Voltage reading between pos/neg with Eng on & off (~ +/- 3V difference)
    2. Take alternator output reading, DIRECTLY from Alternator using case as ground - (~ 13-14V)
    3. Then take Voltage Drop tests
    *Positive side - from alt + to battery + post (Should be no more than .05V)This is a common weak spot on MKIV's
    *Negative side - from alt case to battery neg post (Should be no more than .05V)
    This should help you get a quick baseline on the matter and usually uncovers a glaring problem. BUT, there can be other variables such as heat, load and AMP's that will give a more precise look into the charging system.
    I would also advise you to perform all steps with no loads on, THEN turn on anything and EVERYTHING possible and repeat.
    I wrote this up pretty quick, so if this doesn't make sense feel free to ask for clarification...
  16. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-15-2011 03:40 PM #506
    I am replacing the low speed fan tonight so the front end will be pulled forward. It will be a good time to check the alt as well.
  17. 06-15-2011 05:55 PM #507
    Damn, this is one hell of a build thread
  18. Member huichox4's Avatar
    Nov 8th, 2004
    06-21-2011 02:50 PM #508
    Soooooooo
    what happened with the battery and fan projects?? got them all resolved?
  19. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-21-2011 06:06 PM #509
    Quote Originally Posted by huichox4 View Post
    Soooooooo
    yeah, brand new battery in and brand new fan in. Still haven't gotten my license cleared up, so I haven't been driving it though.
  20. Member ski.:R's Avatar
    Aug 21st, 2010
    UT
    E46 M3
    06-21-2011 09:57 PM #510
    This car is amazing. I'm surprised i've never seen you!
  21. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-22-2011 06:34 PM #511
    Quote Originally Posted by ski.:R View Post
    It's been parked for the last 8 months.
  22. Member President Lincoln's Avatar
    Jun 27th, 2005
    Kanosh
    06-22-2011 10:50 PM #512
    How bout that 6 pack you owe me?
    LMK, car is sooo legit.
  23. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-23-2011 11:26 AM #513
    Quote Originally Posted by dOWa242 View Post
    haha, I still remember. I actually think I might have the body shop fix my rear bumper for me. So I can get you that Fusor gun back.
  24. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-24-2011 01:23 PM #514
    this cooling system is going to be the death of me. The filler neck i installed is basically just that. A filler neck. I had to both vent air out of the system at the upper rad hose and by loosening the an fitting on the heater box. hoping I finally got all the air out of the system. I also got a 19 psi radiator cap.
    Will my low speed fan turn on without the A/C installed? It doesn't seem to kick on just by turning on A/C, but then again the pressure switch is not hooked up to anything.
  25. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    06-24-2011 02:34 PM #515
    More than happy to help if you want to call or text. One year, custom setup, no bubbles, no over heating. 105 degrees and the temp stays dead on.
    Take filler neck, buy funnel that seals around it add a hose and a bigger funnel. Support on hood latch and fill with coolant. Keep adding as the bubbles come out. Turn on the car and let it warm up some and add coolant as needed. It will suck in more. Let the thermo open then turn off the car. Let it cool some and check all hoses for air. Add some more to the funnel now. This method cant leave air in their. Physics is on your side 100% here.
    Fan wise, I literally unplugged the front connector to the FCM and both fans work perfect.
    - Only turn on once car has heated up
    - Both run
    - They only stay on for about 3 minutes after a hot drive
    Eventually I will dig up what unplugging that did but it works 100% now.
  26. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-25-2011 11:46 AM #516
    So the last round of bleeding air out of the coolant system must have done the trick. Last night I took the car out around the neighborhood getting it nice and hot. Then when I got home I let it idle in the driveway for like 10 minutes, both fans were working great and the temps never creeped above 190.
    I also decided to test out the new UM launch control. Turn your speakers up.
  27. Member Navydub's Avatar
    Sep 29th, 2006
    Pleasant Prairie, WI
    Saab STi and a Land Rover
    06-25-2011 11:56 PM #517
    Quiet
    If I stood on the 2-step in the driveway my nieghbors down the road would probably call in a noise complaint haha.
    Turbo Unicorn | HS Tuning | 42DD | Cabin Krew
  28. Banned ThatVdub's Avatar
    May 28th, 2010
    Jax, FL
    Golf R
    06-26-2011 12:18 AM #518
    Video http://vimeo.com/25584722
    Cuz, I could not see it on this page, had an error...
  29. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-26-2011 12:45 AM #519
    Quote Originally Posted by Navydub View Post
    Quiet
    I need to put in my test pipe.
  30. Member
    Jul 17th, 2005
    Arlington, VA
    2004 R32t, 2007 Passat 2.0t Wagon, 1991 8v GTi
    06-29-2011 11:50 PM #520
    Last night around 2:30-3:00AM I hooked my laptop up to my Klipsch surround sound and turned the volume around 2/3rds the way it could go up... I played it on mute about a second before you stepped on the 2-step and un-muted it... My bed and bedroom is right on the other side of the wall where my girl was sleeping...
    ...so...
    tonight Im sleeping on the couch where Im typing this from... and also received a 3rd noise violation complaint from the neighbor upstairs... I saw that coming from the stomping on the floor... but i seriously thought sleeping on the couch was something that only happened in movies or television shows... the locked bedroom door says otherwise. who knew?!
  31. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    06-30-2011 03:33 PM #521
    lol, awesome story.
  32. Member huichox4's Avatar
    Nov 8th, 2004
    07-01-2011 03:58 PM #522
    Quote Originally Posted by c0peXXX View Post
    ...so...
    once I read up to that point the Howard Stern PP movie popped up in my head .... LOL "Turn the bass all the way up"
    the end result for you my friend was terrible though haha
  33. Member gmoneyR32's Avatar
    Dec 10th, 2010
    NJ
    04 DBP VW R32T, 2010 Honda Accord Coupe (wifey's car)
    07-01-2011 07:15 PM #523
    i busted a nut hearing this! that makes me wanna get one now..... love ur car dude....
    JDS Motoring | CCW | Linden VW/HPA MotorSports | LosGoonies.com
    It's not just a passion, it's a life style!
  34. Member
    Jul 17th, 2005
    Arlington, VA
    07-02-2011 02:28 AM #524
    lol, awesome story.
    I found out Im moving into another apartment (in my same building but whatever...) so each morning now (yesterday and today so far), Ive left my apartment for work around 630am or so, with this on repeat set to play for 20 minutes and then it shuts off automatically. (I really hate my upstairs neighbor... plus shes the physical therapist for Lady GaGa's dancers) So youre exhaust note is being used for good... Im hoping she'll lose her mind one day when she hears a VR6 drive by.
    haha nah I didnt mind... I have a comfy couch.
  35. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    07-08-2011 08:32 PM #525
    so this popped up today, car has been driving fine. I really doubt the timing is off, it started running kinda rough when these popped up.
    2 Faults Found:
    17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    P1340 - 001 - Upper Limit Exceeded - Intermittent
    17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incor. Correl.
    P1347 - 001 - Upper Limit Exceeded - Intermittent
