Page 2 of 28 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 946
Thread: DarkSideGTI Big Turbo Build Round 2
  1. Member rjdubtuner's Avatar
    Aug 12th, 2007
    N.Y.
    02-14-2011 09:33 PM #36
    looking good. I have a 3.6L crank for sale. Diff pistons is all that is needed. Lmk. I am doing a bunch of stuff to my R right now. I now your pain (big money)
  2. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-14-2011 10:19 PM #37
    I've heard the 3.6 crank doesn't work since the V angle is different. It messes up the firing order.
  3. Member AndyTR32's Avatar
    Jun 4th, 2003
    '01 A6 Avant
    02-15-2011 09:45 AM #38
    I vote for using the 3.2 crank. I'd wait it out for a bit, seems like you've got plenty of other things to keep you busy. Nice looking build you've got here.
  4. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-15-2011 11:06 AM #39
    Quote Originally Posted by AndyTR32 View Post
    Looks like I don't have to wait too long. I found a crank last night. It should be shipping out to me tomorrow thanks to websaabn.
  5. Banned euro.lo's Avatar
    Oct 18th, 2010
    Niagara, Ontario
    mk4 gti, mk3 golf
    02-15-2011 01:05 PM #40
    ^ Good to hear. Even though I'm a noob when it comes to all this crazy engine building and turbo talk, I think having the 3.2 is better, why knock down the displacement to 3.1? Either way, glad to see you found one, following this builld closely, great work, and good luck!
  6. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-15-2011 01:45 PM #41
    Honestly no one would have ever noticed the difference between a 3.1l and a 3.2l, but I am glad I am sticking with R32 parts.
  7. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    02-15-2011 01:50 PM #42
    Quote Originally Posted by DarkSideGTI View Post
    I would have...and you would have
  8. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-15-2011 02:22 PM #43
    i don't think so. it is a pretty small difference.
  9. Member dr. b's Avatar
    Jul 14th, 2005
    motorsport capitol, the world
    i scrape a gt4088R32, she rocks a B8
    02-15-2011 08:35 PM #44
    there is more to how the engine will make power than just a raw displacement.
    a longer stroke will net more torque, whereas the shorter stroke will be happier at high revs.
    you could potentially wrap more rpm with a short stroke and a fatty piston....hell, with the stock bore and shorter stroke the engine would spin up super quick. esp with big boost.
    (think indy car engines. 2.5-2.8L v8's with turbos)
    but there is nothing inexpensive about these damned cars.
    "I'm DrB and I approve this message."
    instagram doktor_b
    projekt oveRhaul - i hate my caR and i hate you too
  10. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-16-2011 11:16 AM #45
    Got my POR15 engine painting kit and my catch can yesterday.
  11. Member itouch's Avatar
    Oct 14th, 2007
    MK5 R32T
    02-16-2011 12:31 PM #46
    Where did you get that catch can from? Looks very nice.
  12. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-16-2011 12:44 PM #47
    Got it from here.
    http://performanceunlimited.com/cobr...thertanks.html
    I might have to change the bracket around to get it to go where I want it.
  13. Member dr. b's Avatar
    Jul 14th, 2005
    02-16-2011 09:05 PM #48
    Got it from here.
    catch can location is something i'm eager to see. i haven't even considered where i am going to stuff one of those buggers. need one, but they don't quite go with my shaved theme...
    instagram doktor_b
  14. Member cleanA3's Avatar
    Jun 22nd, 2007
    AZ and the BAY
    A3 3.2 ..MKV R32 .. MKII 16v
    02-16-2011 09:32 PM #49
    this will be very nice .
  15. Member huichox4's Avatar
    Nov 8th, 2004
    83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
    02-17-2011 10:22 AM #50
    Quote Originally Posted by dr. b View Post
    just use a little filter in the valve cover directly at the shows ..... a shiny chromed one or even color matched to your valve cover would still keep it clean or take the whole thing out all together ...... when you drive it install a catch can if you want
  16. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    02-17-2011 10:25 AM #51
    Mount that ish somewhere on ur motor
  17. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-17-2011 11:46 AM #52
    Before I just had a rubber hose running to the ground. It didn't look too bad.
    I think I am going to install it right behind the passenger side headlight now.
  18. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    02-17-2011 11:48 AM #53
    i was being sarcastic, lol the mere fact "i know what u did this winter"
  19. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-18-2011 12:20 AM #54
    Since I am waiting on the new crank I decided to work on the bumper shaving project.
    First thing I had to do was cut off the brackets on the backside of the bumper that hold the side markers.
    I used a dremel and a wiz with some 80 grit to cut off and smooth the back side
    Then I sanded the paint around the hole on the front side.
    Then I used some paper and a pencil to make a template of the hole.
    I used that template to cut out some plastic I got from a wrecked Jetta.
    Then I used the sanding drum on a dremel to smooth and shape the piece to fit into the opening on the bumper.
    Looks like the piece fits in the opening pretty good. I used this finished piece to create another one for the other side.
    It was a bit too cold to use the fusor tonight so I plan on doing the fusor work this weekend.
  20. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-19-2011 03:21 PM #55
    so some more bad news. Yesterday I picked up the block from the machine shop. They told me they could only find 6 of the main caps in the box I gave them. I thought hmmm maybe I left one out at home. I get home and search around and cannot for the life of me find the last main cap. I remember dropping all of them in a plastic shopping bag along with the bolts as I took them off the block. If the machine shop cannot find it, I am going to be screwed.
  21. Member websaabn's Avatar
    May 23rd, 2003
    Hopkins, sc
    02-19-2011 08:11 PM #56
    that sucks
    The road to riches is paved with Jolly Ranchers!
  22. Member JAVW's Avatar
    May 23rd, 2004
    Montreal
    04 R32 WT
    02-19-2011 08:50 PM #57
    Awesome work continu that way. BTW I approved your 3.2l crank choice compare to the 2.8L. Don't forget boigger bore mean thinner pistons walls and I know that we can crack the walls wit boost. It already append to one of my customers
    And subscribe
  23. Member JAVW's Avatar
    May 23rd, 2004
    Montreal
    04 R32 WT
    02-19-2011 08:54 PM #58
    You just find the best reason since your block is at the machine shop to by yourself the new billet main caps from 034 Motorsport.
    VR6 billet caps
  24. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-19-2011 08:59 PM #59
    Quote Originally Posted by JAVW View Post
    VR6 billet caps
    Yeah I might. Although Integrated Engineering is working on some billet main caps for the 1.8T, maybe we could build some for the R32.
    Made a bit more progress on the bumper today.
    Started off my applying some fusor to the back of the bumper along with some reinforcing mesh.
    Then I spread some fusor on the front side of the bumper.
    Then I took the big leap and cut the front notch out.
    The filler piece I bought from a guy on vortex.
    Here it is all trimmed up. I will try to fusor it in place on Monday.
  25. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    02-21-2011 11:32 AM #60
    Damn dude, that some good stuff!
  26. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-21-2011 07:59 PM #61
    Good news. Machine shop found the missing main cap!
  27. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-21-2011 08:15 PM #62
    Good i am glad to here
    -JAMES-
    Daily Drive /Beaten/Built /UM Turbo R - VR NATION
  28. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-22-2011 11:55 AM #63
    Quote Originally Posted by newcreation View Post
    Yeah that saved me about $350.
    Crank should be here tomorrow and I will drive it out to the machine shop to get cleaned and micro polished. I'll pick up the main cap while there.
  29. Member websaabn's Avatar
    May 23rd, 2003
    Hopkins, sc
    02-22-2011 12:03 PM #64
    awesome, let me know if anything bad happend during shipping
  30. Member dr. b's Avatar
    Jul 14th, 2005
    02-22-2011 05:20 PM #65
    only if you got the 034's. i would've sent you my old ones for cheap.....like shipping or Coke in glass bottles or something like that.
    VR6 billet caps
    (i have my stock main caps b/c i have these^^^^ fully gnarly looking on the engine.)
    instagram doktor_b
  31. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    02-22-2011 05:54 PM #66
    The new caps need to be line honed on the block. Not sure that used ones would work.
  32. Member dr. b's Avatar
    Jul 14th, 2005
    02-22-2011 06:07 PM #67
    that's true. but they wouldn't be that far from spec based on the fact that all the R32's used the same main bearings, caps, and cranks. and none of mine were damaged, so i believe that they would've been ok.
    regardless, i'm glad the shop found your stuff. always makes me worry when machine shops lose things.
    instagram doktor_b
  33. Member Emron's Avatar
    Mar 27th, 2007
    Huntington Beach, CA
    2004 GTI 24v; 2004 Jetta 1.8t
    02-23-2011 01:12 AM #68
    IN
  34. Member BIG DUB's Avatar
    Feb 13th, 2001
    MD/VA/DC Area
    1980 turboed moped
    02-23-2011 01:29 AM #69
    Man I cant wait to do my rods, pistons, cams, h20/meth when I get home
  35. Member boostd12v's Avatar
    Jan 26th, 2009
    Indianapolis
    2.9 big turbo vr6 jetta never going to be finished race car on wide bbs rs/BMW X5
    02-23-2011 05:30 PM #70
    watching
    formerly b2 aka euroflash real name Chantha but you can call me Mr. Thach
    I survived the Illeststance gangbang of 2011
