View Poll Results: Copper or Stainless nuts?
Voters
16. You may not vote on this poll
  • Copper
    13 81.25%
  • Stainless
    3 18.75%
Results 1 to 23 of 23
Thread: Exhaust Manifold nuts - copper or stainless?
  1. Member timman42's Avatar
    May 11th, 2009
    South Amboy, N.J.
    1988 Jetta GL Wolfsburg 8v, 1990 Volvo 240 DL, 1997 Mazda Miata, 1992 BMW 325i
    02-05-2011 11:29 AM #1
    I'm going to replace my single downpipe with a dual DP and manifold. I was wondering if I should use the copper nuts from GAP, or locate some stainless ones?
    Any input is appreciated.
  2. 02-05-2011 11:59 AM #2
    I vote copper nuts on stainless steel studs. I think you might have problems with stainless nuts vibrating loose.
    Sep 18th, 2006
    Austin, TX
    02-05-2011 05:21 PM #3
    I prefer copper nuts and anti seize paste for the studs.
  4. 02-05-2011 06:08 PM #4
    copper will turn green and stick and copper is really soft rusted threads on the studs will file away at the threads in the nuts and make the thread really loose
    stainless will never stick and is much harder so u can reuse them many times and u can get them at home depot for under $5 for the whole set
    as for vibrating loose u can use lock washers and all will be fine
  5. 02-06-2011 09:58 AM #5
    Copper exhaust nuts are not copper through and through, they're steel nuts with a heavy copper plating and the last couple of threads are crimped slightly to grip the stud so they loosen off. I've had these nuts turn green in storage but never while on the car, I think the heat of engine prevents that.
    BTW, these are the nuts and studs I used on my car along with a few other fasteners.
  6. Member timman42's Avatar
    May 11th, 2009
    South Amboy, N.J.
    02-06-2011 10:13 AM #6
    Thanks ABA for the info. I've looked on NGP, ECS, and GAP and didn't find any exhaust stud kits. I'm not aware of anyplace around here that offers studs like that either.
    Hardware is M8x1.25, correct?
  7. Member timman42's Avatar
    May 11th, 2009
    South Amboy, N.J.
    02-06-2011 10:22 AM #7
    So it looks like M8x1.25 by 35mm long. Maybe I can find a hardware store nearby. Im thinking of trying the route using stainless nuts with lock washers, over stainless studs. I'd like to easily remove things if needed, in the future.
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    02-06-2011 10:35 AM #8
    the studs are a standard Dorman item. Any NAPA or Carquest will have them. Stainless studs will actually be weaker than the stock stuff. Stainless also has a tendency to gall.
  9. 02-06-2011 10:41 AM #9
    Yes, it's M8x1.25. I had to call around a fair bit to find stainless studs locally, a couple places could have ordered them for me if I'd buy a full box of 50, Fabory would let be buy as many or as few as I wanted, I didn't go in there looking for copper nuts, they actually had them in a display out front. Fabory was a great place to deal with, they have just about every fastener you could ever need for a VW with the exception of specialty stuff like head or rod bolts, I'm not sure but I think they do mail order too if you don't happen to be close to one of their locations.
    BTW, Those studs are a little longer than they really need to be, if I were to buy another set, I'd get the 8x30mm studs instead.
  10. 02-06-2011 10:48 AM #10
    Quote Originally Posted by antichristonwheels View Post
    I REALLY like my stainless steel studs. As far as I'm concerned, strength isn't an issue with a brand new fasteners and I haven't noticed any galling on my studs, they look very much like they did the day I installed them
  11. Member RandallCunninghamJrIII's Avatar
    Jul 14th, 2010
    IL
    84 gti, lotus bike
    02-07-2011 11:45 AM #11
    Quote Originally Posted by timman42 View Post
    GAP has them. look @ the left column and click on 'hardware'.
    it's not a kit, but they have exhaust studs/nuts in various sizes
  12. Member Eric D's Avatar
    Feb 16th, 1999
    Tragic Kingdom, CA
    1943 Flugkreisel, 1945 VRIL-7
    02-07-2011 01:03 PM #12
    I use BMW shouldered copper exhaust nuts on my 8v.
    I got them from James at http://www.fourseasontuning.com/
    The original Dub and Dubber.
    Manche VWs sind einfach schneller als andere.
  13. Member timman42's Avatar
    May 11th, 2009
    South Amboy, N.J.
    02-07-2011 02:30 PM #13
    You're right Randall, I must have overlooked that. Thanks to all for the comments.
  14. Member Seax_Smith's Avatar
    Jun 1st, 2007
    Not Present.
    Newest, 92 GTi half-swap plus
    02-07-2011 09:56 PM #14
    copper lock nuts and aluminum washers and as much "never seize" as you can squeeze in and run a die down the studs before hand if you are not replacing them.
    Don't for get to order 16 of each (10 for the mani & 6 for the dual pown pipe).
    Thanks for calling. Your call is very important to me. If you would like to reach me by phone now, please hang up now. If you would like to reach me by phone later, please hang up later. If you would like to speak with a person, please press ten. ..... I'm sorry I do not understand one zero. Please hang up now or later if you cannot press ten.
  15. Member Black92EightValve's Avatar
    Oct 23rd, 2003
    Phoenix, AZ
    92 GTI 16V, 88 Scirocco 16V, 20th AE GTI #2269
    02-11-2011 07:36 PM #15
    Quote Originally Posted by shurik06_83 View Post
    Only problem with that is the heat from the exhaust will destroy any wave to any washers you use, rendering them useless as a lock washer, you'd need to use the star design lock washers if you're gonna go that route.
    IMO you're still better off going with a copper nut, if you want to get a shouldered nut, go to your local VW dealer and get part # N 90200201
  16. Member timman42's Avatar
    May 11th, 2009
    South Amboy, N.J.
    02-26-2011 05:47 PM #16
    So I ended up just getting OEM steel studs and copper nuts from GAP. Thanks for all of the input.
  17. Member Brian.G's Avatar
    May 7th, 2010
    West of Ireland
    02 25i Msport
    03-02-2011 08:50 PM #17
    Quote Originally Posted by ABA Scirocco View Post
    Thank god you pointed that out, I was getting edgy reading the posts until I saw yours
    The amount of guys that think they are ''pure copper'' is insane.
    BG
  18. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    03-08-2011 04:46 PM #18
    ARP sells metric stainless bolts that can be used for the exhaust.
  19. Member
    Jul 29th, 2008
    DD 73 square/T4 swap and `squirted,99 TDi, 86 Cabriolet
    10-03-2012 01:32 PM #19
    You can get BRASS 8x1.25 exhaust nuts in 11mm OD, commonly used on acvws with large exhaust pipes for clearance, but they are solid brass hex stock and will not rust, bust or corrode.(OK, maybe lightly corrode, but they stay dry due to exhaust heat)
    Jegs/CB performance and many others sell them, sometimes called header nuts
    SS nuts on SS studs is likely to gall w/o antisneeze, but SS studs with ~anything else probably wont if anyone ever wanted to go that route.
  20. Member
    Jun 14th, 2001
    Music City USA
    10-03-2012 08:50 PM #20
    stainless will be weaker. If you got a stuck stainless stud it will snap off easier than a good hardened steel one
  21. 10-04-2012 03:27 PM #21
    The main reason exhaust fasteners tend to get stuck in the first place is due to corrosion and that's FAR less of an issue with stainless steel fasteners, in my fairly limited experience with them, I've never had a stainless fastener get stuck so breaking them, thus far, has been a non-issue for me.
  22. Member
    Mar 31st, 2008
    PNW - Oregon
    10-06-2012 02:40 PM #22
    STAINLESS IS WEAKER THAN NORMAL STEEL!!
    stainless exhaust hardware just SCREAMS bad idea to me..
    the only time you should use a stainless bolt over a rregular steel bolt, is when you need corrosion protection..
    stainless at the exhaust manifold has got to be the worst idea ive ever heard..
    stainless will gall to stainless, and steel..
    copper nuts will not gall, and almost always come back off..
    copper nuts, and regular steel studs (with copious amounts of high-temp anti-seize) is the way to go..
    the copper plated nuts dont turn green unless you touch them, or leave them exposed to salt air for too long.. when they are on a car, i defy you to tell me that they turn green?
  23. 10-07-2012 06:28 AM #23
    Quote Originally Posted by Glegor View Post
    I would agree with you IF exhaust manifold studs were a highly stressed component but on a street driven car, they're simply not, 8- new M8 fasteners of any grade would be plenty strong enough to secure an exhaust manifold and corrosion is very likely the only thing that would cause them to fail. I'd say stainless steel studs with stainless steel washers and copper plated nuts are an ideal choice to secure the manifold to the cylinder head unless perhaps you happen to be running a turbo with very high boost.
    The studs that hold the down pipe to the exhaust manifold get a LOT more heat and vibration, I'm a little more circumspect about using stainless steel studs there.
