VWVortex.com - low tire pressure light stuck on
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 33
    Thread: low tire pressure light stuck on
    1. 02-05-2011 04:58 PM #1
      is the light supposed to stay on after u replace a flat? it flashes a few times when teh car turns on then stays on steady. all tire pressure is good but im wondering if theirs a reset switch needed?
      formerly TVarmy04 & DUBMANG
      SAPPERS LEAD THE WAY
      Quote Originally Posted by jspirate View Post
      Now, having unprotected sex... thats a whole different beast. There are some crazy hotties out there... whew!
    2. Member Squirrel Nuts's Avatar
      Aug 25th, 2010
      Miami, FL
      2015 Bagged GTI Autobahn l Bagged 2010 GTI (Totaled) l 2007 GLI (Sold)
      02-05-2011 05:06 PM #2
      Quote Originally Posted by DUB_MANGv2 View Post
      It'll go off in a bit. Mine has taken about an hour and sometimes 5 minutes.
    3. Member Mr.Veedubya's Avatar
      Sep 25th, 2004
      SLC, UT
      2017 Q5 3.0T
      02-05-2011 05:28 PM #3
      Make sure all of your tires are within 3 psi of each other, including the spare. Drive it for a bit and it should go away. If that doesn't work, try disconnecting the battery for a few minutes. If that doesn't do the trick than the tire place probably damaged the sensor when they were changing tire.
    4. 02-05-2011 08:28 PM #4
      well the original tire had a nail in it and was losing air. we went in for her first oil change and they rotated the tires and wanted to charge us $50 just to patch it, so i said screw yall and got my oil change and bounced. when i got home i swapped it with the spare and made sure all tires are at 34psi. (this was about a month ago) the spare still has the nail and is sitting in her trunk. but will that still trigger it even if its not even mounted?
      Dec 30th, 2010
      San Francisco Bay Area, CA
      2012 Golf 2.5L
      02-06-2011 06:20 AM #5
      There is a tool that can communicate the TPMS sensor. A tire shop may have similar equipment (I believe Costco use them) to check TPMS.
      It's either the nail knocked out the sensor (not very likely but can happen) or the tire guys knocked out it.
    6. Member
      Feb 18th, 2010
      Southeast Pennsylvania, Downingtown
      2010 Golf TDI
      02-06-2011 07:53 AM #6
      I think you may find the recommended tire pressure is 38 psi. At least it is on my 2010 Golf TDI. Look at the sticker on your door jam. My TPMS would also go on if my tires were at 34 psi. Raise it to 38 psi and I bet it goes off after a few minutes.
      Also, I'm assuming you have a 2010, because the 2011 has a reset in the glove box.
      2010 Golf TDI - Blue (BGM), 4-Dr, 6-Manual, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 wheels, 235/45/17 Michelin Primacy MXM4 tires, P3Cars Digital Interface
      Flickr slideshow of my TDI
    7. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      2016 MkVII e-Golf, 2010 MkVI MT TDI Golf, 2000 B5 4M Passat Wagon
      02-06-2011 08:32 AM #7
      There is also a known issue (programming mistake) at least on a certain series of Golf TDIs from early 2010, where the TPMS warning simply does not reset itself. It is like, the first time a tire goes below the threshold, it resets after all tire pressures are above the factory threshold level; the second time a tire goes below, that level is magically replaced by another constant pulled from some place else (50psi or so).
      Mine has been on for four weeks, and it will be on until I bring it for the 10,000 mile service.
      Apr 19th, 2006
      2010 Golf TDI
      02-06-2011 03:04 PM #8
      Fix the tire and put it back on the car. The car is getting a "flat tire" signal from the tire in the trunk. Plus, you're still driving around on your spare.
      2010 Golf TDI 4 Door Shark Blue. DSG, Sunroof, Dynaudio, Nav, Rear airbags
      Quote Originally Posted by Outie5000 View Post
      And lets be honest, owning a diesel car is nifty.
    9. 02-06-2011 05:38 PM #9
      well i left the spare on because its the same full size 16" that came with the car. its a 2010 golf. ill check the psi to see it might be up near 38 but i said 34 just cuz i knew i set them all in the mid 30s. then finally ill take the spare out with the nail and leave it in the garage.
    10. Member
      Mar 29th, 2000
      2010 Golf TDI, DSG
      02-06-2011 05:48 PM #10
      Chances are really good that you have 4 tires with sensors (and metal stems) and a spare with no sensor and a rubber stem. Check the spare stem and see!!
      Until you fix the "real tire" and get it aired up, the light ain't gonna go away.
    11. n00b greenbeer's Avatar
      Jun 9th, 2010
      fort worth
      '10 Golf 2.5
      02-06-2011 05:57 PM #11
      i had the same issue. I set the pressures to 34 psi using my snap-on air gauge at work and the light was still on. next week brought it in to the dealer to get my 10K mile service done and they said that if i set it a bit higher ~37psi itll go off thats where they set it and its been fine since.
    12. 02-06-2011 06:05 PM #12
      Not sure about your car, but when I was a tech for Mazda and Acura if it shows the pressure in the cluster reading 58psi or flashing there is an issue with a sensor. If the light us on and NOT flashing it is usually just low pressure. Like I said that was for Mazda and Acura though
    13. 02-06-2011 06:06 PM #13
      Quote Originally Posted by John and the GTi View Post
      im putting my money on this!
    14. Member dubbinitmk6's Avatar
      Oct 25th, 2010
      El Paso, TX
      2013 MINI Cooper S, 2013 Audi TT-RS
      02-07-2011 12:24 AM #14
      Mine did that a few times during a period after I bought the car. All tires were properly inflated, and it turned out to be a TPMS malfunction. Took it to the dealer, waited an hour, and it was out and gooooood.
    15. Member mtbmurray's Avatar
      Mar 12th, 2000
      Winchester, VA
      02-07-2011 12:56 AM #15
      There's also a TSB for this very same problem for certain vehicles. Probably best to give the dealer a call. I have to take my GTI in for the same problem.
    16. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      02-07-2011 08:28 AM #16
      Quote Originally Posted by GTINC View Post
      The OP was carrying a flat tire in the truck, which couldwould, of course, give a low pressure signal.
      Sure - yet, the TPMS ECU coding error is real and well-documented - as I posted up there, and as confirmed by mtbmurray.
    17. 02-07-2011 09:12 AM #17
      A flat tire should not give a flashing TPMS light. They usually only flash when there is a malfunction with a sensor.
      The OP was carrying a flat tire in the truck, which would, of course, give a low pressure signal.
    18. Member SoCo1187's Avatar
      Feb 25th, 2007
      CT
      2010 GTI / CSG / 6MT
      02-07-2011 10:48 AM #18
      There's a difference between the two behaviors.
      If it flashes when it turns on, that's the TSB which requires you to take it into the shop (or it's having a "communication problem" with one of the sensors). Regardless, you gotta bring it into the shop if it's flashing. If it doesn't flash at all and there's a "Vehicle Status" message that says "Tire pressures too low", then you just need to add air.
    19. Member Mr.Veedubya's Avatar
      Sep 25th, 2004
      SLC, UT
      2017 Q5 3.0T
      02-07-2011 11:30 PM #19
      Someone let me know if this is true, but I always thought the system only works based on all of the tires being the same pressure or within like 5 psi of each other. It doesn't matter if they are all 10psi or 80psi, as long as they're all the same.
    20. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      02-08-2011 04:05 AM #20
      Quote Originally Posted by Mr.Veedubya View Post
      No, it works off a pressure threshold. Any tire below that threshold (which can be set with VAG-COM or by the dealer) will bring up the TPMS light.
    21. Member phd-12v's Avatar
      Jun 13th, 2001
      pitt, pa
      '10 4dr GTI w/DSG, 2012 Jetta SE 2.5L
      02-08-2011 11:45 AM #21
      mine has been on for 3 days now. i have checked every tire. 40psi all the way around. this is the 5th time it has done this.
      '10 4dr GTI w/DSG, 1989 Wolfsburg Cabriolet
      www.idatalink.com
      www.encoreautomotivesystems.com
    22. Member SoCalMK6GTI's Avatar
      Apr 5th, 2010
      Rancho Cucamonga, CA
      2010 GTI 6MT DBM
      02-08-2011 12:01 PM #22
      Disabling TPMS using VAGCOM eliminates all issues! You just have to remember to check your tire pressure regularly.
    23. Member phd-12v's Avatar
      Jun 13th, 2001
      pitt, pa
      02-08-2011 12:04 PM #23
      Quote Originally Posted by SoCalMK6GTI View Post
      yeah, i just have this whole money issue with needing to buy vagcom, needing to buy projectors, need to buy a second set of lights, needing to buy a computer flash, needing to buy etc etc etc......
      that and then i have 3 kids which are 13,12,and 7.
      damn these kids are expensive
      www.idatalink.com
    24. Member SoCalMK6GTI's Avatar
      Apr 5th, 2010
      2010 GTI 6MT DBM
      02-08-2011 12:13 PM #24
      Quote Originally Posted by phd-12v View Post
      Well there are plenty of people in SoCal with VCDS. I don't have one which is why I went on the regional forums and found someone who would do some VAG work for a 12 pack of diet coke. There's usually someone at the local GTG's that has one too. I didn't transfer over my TPMS sensors on the new wheels/tires so I just disabled it.
    25. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      02-08-2011 09:25 PM #25
      I feel with you, but your dealer should be able to fix the TPMS light with an ECU update - for free.
