VWVortex.com - 12v power source at cigarette lighter not working, no blown fuses. Any ideas?
    Results 1 to 17 of 17
    Thread: 12v power source at cigarette lighter not working, no blown fuses. Any ideas?
    1. Member Steve Zissou's Avatar
      Feb 21st, 2008
      Pasadena, MD
      92 Monty 1.8T, Bagged 2010 CC
      02-06-2011 05:50 PM #1
      Hey guys, helping my mom out here with her Passat. The 12v cigarette lighter just stopped working in her car this morning.
      My immediate thought was a fuse. Checked the owners manual which says its fuse 35 on the passenger side of the car, opened up the fuse panel and saw nothing in spot 35 . Searched under "cigarette lighter" and came up with a few threads saying it was a different fuse in a different spot. Checked all fuses and none were blown.
      Any other ideas what it could be?? thanks in advance for the help guys!!!
    2. Member Track5tar's Avatar
      Feb 16th, 2010
      Salt Lake City, UT and Las Vegas, NV
      Mine: 2010 Passat Hers: 2012 B8 A4
      02-06-2011 10:19 PM #2
      Quote Originally Posted by Steve Zissou View Post
      if the fuses are good then try pulling out the part and check the plug on the back to see if its loose or even getting power. did you use a test light to check the fuse?
      Unitronic > APR Switched from APR to UNI and never looking back
      CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
    3. Member Steve Zissou's Avatar
      Feb 21st, 2008
      Pasadena, MD
      02-07-2011 07:32 AM #3
      Quote Originally Posted by Track5tar View Post
      We were thinking that might be our next step, just wanted to check for a simple fix we may have looked past before taking it apart.
      I didn't check the fuses with a test light, just a visual inspection to see if the connection in the center had broken. Should i check with a test light as well?
    4. Member pq46er's Avatar
      Aug 22nd, 2007
      Ottawa
      2007 Passat wagen
      02-07-2011 08:06 AM #4
      No your fuse is blown! The diagram in the manual is wrong.
      The fuse diagram in the manual is a generic print out , our cars are anything but. You should get a fuse tester (around $5).
      I am going from memory here so I could be wrong but it is definitely on the driver’s side and it is a yellow fuse, #46 I think.
    5. Member AE2058's Avatar
      Dec 30th, 2003
      Bruchmuhlbach
      08 Audi RS4
      02-07-2011 10:09 AM #5
      Just change mine out last week, due to a cheap phone charger. Driver side bottom row #20 yellow fuse
    6. Member Track5tar's Avatar
      Feb 16th, 2010
      02-07-2011 10:27 AM #6
      Yes get the test light. Your eyes could've missed it. All u have to do with a test light is ground the wire then just tap the metal part on top of each fuse. If the light comes on then it's good. Just do that until you find the blown fuse, seems like location is different in our cars
    7. Member Steve Zissou's Avatar
      Feb 21st, 2008
      Pasadena, MD
      02-07-2011 01:53 PM #7
      I completely agree, seems strange that they are all in different places
      thanks for the help guys! we'll take a look on the drivers side today and get it figured out.
    8. 02-17-2011 09:54 AM #8
      I can confirm that they are all different!!!!
      My lighters went out in my'06 Passat. Of course the manual was wrong. I checked every 20A fuse on the driver side, all were good.
      I found the bad one on the passenger side in slot 34, not slot 35 as was listed in one of the diagrams I found.
    9. n00b
      Jan 18th, 2009
      Bucharest, Romania
      06 Passat 2.0T
      02-18-2011 01:09 AM #9
      yes, I fixed mine last week... blown it with an air compressor.
      I confirm passenger side, fuse #34, 20A.
    10. Member
      Aug 2nd, 2002
      San Diego, CA
      B6 Passat SportWagon 2.0T, E46 3.0L vert
      12-02-2012 06:28 PM #10
      My front and rear cigarette lighters are out. Trunk outlet is working. Used fuse tester (with light) on all fuses on driver and passenger side fuse panels and they are all working.
      Any ideas?
    11. Member DBVeeDB's Avatar
      Aug 2nd, 2007
      Des Plaines, IL
      His: 8V A3 Hers: '10 CC Sport 6MT + '03 GTI 1.8T/5MT
      12-03-2012 09:14 AM #11
      just had this issue as well
      manual said one location, that location was empty, Used a multimeter to find which slot lead to the cigarette lighter, and then found my blown fuse.
      GL!
      (mine was also bottom row, 20A fuse, dont remember the location #) year: 2008
    12. Member MP3DUB's Avatar
      Jan 26th, 2002
      Chicagoland, IL
      2016 GTI Autobahn w/ PP, 2006 Passat 2.0T, 1993 Passat GLX
      12-03-2012 11:02 AM #12
      Quote Originally Posted by DBVeeDB View Post
      GL!
      You told me yours was in spot 41
      Mine's in driver's side spot 38, and it's a 15 amp fuse (2006 2.0T Manual Package 0).
      -Nick
      __________________
      Since when is insanity a bad thing?
      Chicago Volkswagen Organization
    13. Member DBVeeDB's Avatar
      Aug 2nd, 2007
      Des Plaines, IL
      12-03-2012 11:38 AM #13
      Quote Originally Posted by MP3DUB View Post
      haha thanks Nick. Been a bit spacey lately.
    14. Member
      Aug 2nd, 2002
      San Diego, CA
      12-03-2012 12:55 PM #14
      any ideas what a next step would be (other than dealer) when all the fuses on passenger and driver panels test normal with fuse tester? Are there hidden fuses? both of my cigarette lighters have no power.
      -Rob
    15. Member DBVeeDB's Avatar
      Aug 2nd, 2007
      Des Plaines, IL
      12-06-2012 07:37 PM #15
      yeah, check the ones on the driver side too
    16. 12-18-2012 05:37 PM #16
      I checked ALL 20a Fuses on BOTH Driver & Passanger side. all 3 of the 12V outlets are out on my 2006 Passat. I used a light tester, what else can I check? I am wondering if maybe they used something larger than 20a???
    17. Member MP3DUB's Avatar
      Jan 26th, 2002
      Chicagoland, IL
      12-18-2012 06:23 PM #17
      Quote Originally Posted by jester_ag View Post
      Mine was a 15A fuse.
      -Nick
      __________________
