VWVortex.com - 1982 MK1 Rabbit Convertable Fuse Block Help
    Results 1 to 3 of 3
    Thread: 1982 MK1 Rabbit Convertable Fuse Block Help
    1. 02-07-2011 09:53 AM #1
      I am having fuse block problems. My windshield is leaking. I have no available voltage to the majority of my fuses. I do have voltage to 6-9 if I recall. So with that being said I will be installing a fuse block soon. This is my current method of repair, if I am still having problems, then wire poking shall begin. So....
      What I am looking for is a picture of someones MK1 Rabbit Convertible fuse block with some kind of diagram of what is what. I have looked on alldata and of course mine looks just a bit different, though it could be correct. I have looked a the MK1 golf diagram on another forum(I can't remember the name), but again mine looks slightly different. Any help would be greatly appreciated. If at all necessary I can post a picture of mine.
      My rabbit has very few power options, but does have:
      -A/C
      -Rear Defroster
      -Radio
      My car was swapped to carburetor.
      Thanks guys!
    2. Banned
      May 26th, 2005
      o HI o
      84 coupe, 90 b3 td wagon, 81 coupe, BURNT TOAST
      02-07-2011 05:52 PM #2
      82 was the last year of ceramic fuses in german made vw.. aka cabbie and jetta.. in 83 they went to ce1..
      so that fuse box set up is 75-82 german.. 81 westy is completly different and 83 is ce1 which is different then pa/westy and what you got..
      bad news is the new fuse box like you will require is more then $200...
      so i suggest a ce2 swap.. this is 88+ german/mexican.. be carefull some 88 westy golf is still odd ball.. but stick to jetta nd life good..
      ce2 will allow simple engine swaps.. its used till 99.5 aaka mk4.. so vr6/1.8t/16v/tdi so on are direct plug in..
    3. 02-07-2011 07:13 PM #3
      Quote Originally Posted by crsmp5 View Post
      Is the ce2 a direct plug in for my stock harness?
