VWVortex.com - Vacuum Pump leak
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 45
    Thread: Vacuum Pump leak
    1. Member Mxkmster's Avatar
      Dec 7th, 2010
      Orange County
      02-07-2011 06:21 PM #1
      So one day you walk out move the car back run inside to get something and see an oil drop on the ground what could it be. A real comment sight to see is the vacuum pump leak. The vacuum pump for the brake booster is on the transaxle side. The seals go bad and there is no reseal kit. If you happen to have a manual tranaxle this is no big deal but on the auto transaxle side there is a nice short cut to get the pump out without taking the trans out.
      Fist step is to get a few tools, sockets, xyz 12 point and a few ratchets.
      Next pull the battery and battery tray out, then remove holding bracket on starter 13mm hexnut.
      Then get under the car and take the torque converter nuts out, this will allow fow some free play. After that take the 16mm bolts for the trans-engine bolts and loosen them. Do not remove only loosen. Once all are loose disconnect the pendulam mount from the engine.
      Get a block of wood and a floor jack. Push the center where the engine and trans meet up. If you did not loosen the bolts for the trans enough you can loosen a little more but remember do not remove. This will allow the vacuum pump to be removed.
      Dont shade tree it...
    2. Member Nothing5's Avatar
      Feb 27th, 2010
      N44 55 W93 10
      2010/VW/MKVI
      02-07-2011 06:36 PM #2
    3. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The BRO C
      2016 VW GTI 4DR CSG
      02-07-2011 06:53 PM #3
      when reading op's post i read it in ben stein's voice
    4. Member SoCalMK6GTI's Avatar
      Apr 4th, 2010
      Rancho Cucamonga, CA
      2010 GTI 6MT DBM
      02-07-2011 07:10 PM #4
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      02-07-2011 09:45 PM #5
      Quote Originally Posted by Mxkmster View Post
      I understand what you are talking about but I have seen this done though.
    6. Member Mxkmster's Avatar
      Dec 7th, 2010
      Orange County
      02-07-2011 11:19 PM #6
      Do we need pictures?
    7. Member wh4l3salad's Avatar
      Jun 20th, 2010
      Great Falls, VA
      Candy White '10 GTI 6M
      02-08-2011 01:48 AM #7
      Whatever you do, don't shade tree your vacuum pump.
      EVE's Build Thread • APR Stage II / BSH RACE / B&B 3" / DG S6 / B&G RS2 / MOTUL / VMR
      facebook twitter wheelflip • PM me for VAGCOM in NoVA
    8. Member Mxkmster's Avatar
      Dec 7th, 2010
      Orange County
      02-08-2011 10:29 PM #8
      Well its not shade tree it is a legit way to do it. I learned the trick from a master tech. If you were to do it the way the repair manual says you have to take the transmission out all the way. I have got the job down to roughly 2hrs. Its not hard it just sounds wierd. I though the same thing...I have to see it first. I took a few pics before my phone died of some stuff. What it comes down to is just doing half the steps. I've lost track of how many I've done. If anyone needs a full detail of every step I can explain in detail.
    9. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      A mullet, a cracked piston, and an Espresso.
      02-09-2011 01:08 AM #9
      What the hell is this thread about? Vacuum pump seal leak??? Do you have a MKIV?
      Edit: Read through your posts, and I assume that you have a MKVI. Why didn't you go to the dealer? And what is up with the randomness/ lack of introduction?
    10. Member toasters's Avatar
      Sep 17th, 2001
      Livermore, CA
      2016 VW e-Golf SE DCFC
      02-09-2011 02:42 AM #10
      Quote Originally Posted by Aonarch View Post
      x2
    11. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      2016 MkVII e-Golf, 2010 MkVI MT TDI Golf, 2000 B5 4M Passat Wagon
      02-09-2011 04:43 AM #11
      I thought he was talking about a MkIV...
    12. Member robkore's Avatar
      Dec 26th, 2004
      Houston, TX
      2011 GTI
      02-09-2011 05:00 PM #12
      I'm sorry, maybe I'm getting old and tragically unhip, but what do you mean by shade tree? Is it doing something shoddily?
      Edit: never mind, urban dictionary comes through again.
    13. Member Mxkmster's Avatar
      Dec 7th, 2010
      Orange County
      02-10-2011 12:02 AM #13
      Well long story short I actually do work at the dealer. This is a trade trick that might be use full to someone. Here the deal the pump cost 12 dollars. The labor is 700. So unless you would like to pay guy like me that can bang you for 2.5 hours of work and pocket the rest its an idea to keep in mind. I share to help out, I like the fact that if some one can help they should.
    14. Member hilfloskind's Avatar
      Oct 31st, 2010
      2011 GTI CSG 4d 6s
      02-10-2011 12:59 AM #14
      Why would I pay you to bang me for 2.5 hours?
      2011 GTI - Carbon Steel Grey, 4 door, 6 spd MT, 35% tint, OEM sunroof deflector, BSH Race Intake, Magnaflow CB, Uber-Stealth Orion 12" sub, Kenwood 1000 watt amp. GTI seat handle inserts, red footwell lighting, Koni coilovers, Ultimate Racing non-res/metal cat DP, APR Stage 2
    15. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      68 chevelle, 98 GTI VR6 S/C, 00 hombre, 02 1.8t jetta wagon, Haro Mirra 540 Air
      02-23-2011 11:34 PM #15
      2.50 hours to replace a vacuum pump on a 5cylinder auto jetta...
      not to be condescending but that is terrible time for flat rate. i understand your description of removal of the pump by loosening the trans, however that souds like a terrible idea.
      if you would like to know how to remove the vacuum pump is 25 minutes (taking you time) PM me, ill walk you through.
    16. Member Mxkmster's Avatar
      Dec 7th, 2010
      Orange County
      02-25-2011 03:13 PM #16
      The time is for the pump replaced on warranty is over 4 hours. This action is due to the multi function range selector on the automatic transaxle. The selector shaft is in the way so it cant be taken out with out either doing it my way or doing as vw says and remove the transmission
    17. Member Mxkmster's Avatar
      Dec 7th, 2010
      Orange County
      02-25-2011 03:15 PM #17
      Id love to see you try to do one on a automatic transaxle in 25 minutes
    18. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      02-25-2011 09:57 PM #18
      i know the warranty time for pump replacement. i know what the procedure for pump replacement on a 5 cylinder automatic trans is.
      ooohhh snaps.. a tech challenge. what dealer do you work for?
    19. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The BRO C
      2016 VW GTI 4DR CSG
      02-25-2011 10:41 PM #19
      Mxkmster, your posts trip me out
    20. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      02-25-2011 10:52 PM #20
    21. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The BRO C
      2016 VW GTI 4DR CSG
      02-25-2011 10:58 PM #21
    22. 05-02-2011 04:14 PM #22
      Does this work around also apply to a 2006 Jetta 2.5 with auto? I assume it does but just want to make sure because my vacuum pump is leaking (weeping according to dealership). Still has powertrain warranty, but I dont think it will cover this.
      Thanks...
    23. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      05-02-2011 07:24 PM #23
      yes it does. all mk5 jetta/golf with the 2.5L 09G auto trans.
      however the way mxkmaster describes to perform this reapir is a little bit much.
    24. 05-02-2011 10:28 PM #24
      Quote Originally Posted by vortexpert. View Post
      So you recommend the Bentley instructions which call for complete removal of the Transmission? The dealership will want 750 to 1k to install this 9 dollar part assuming it is not covered by the powertrain warranty which I doubt it is.
      Or is there an easier way?
    25. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      05-03-2011 08:25 PM #25
      are you replacing the metal gasket between the head and the vacuum pump?
