VWVortex.com - My EPC light keeps coming on and puts my Jetta in limp mode
    Results 1 to 7 of 7
    Thread: My EPC light keeps coming on and puts my Jetta in limp mode
    1. 02-07-2011 06:34 PM #1
      My mechanic says he can't find anything wrong with my 2001 Jetta vr6. The car loses power. When I am on the gas pedal it starts pulsing/jerking around.
      Anyone have any ideas?
    2. 02-07-2011 06:59 PM #2
      scan with vag com, reset throttle (TBA) if doenst solve
      might be your pedal or you throttle that is F'ed up
      OR
      u might have fried your ECU (shorting the 02 sensor will cause this)
      and
      some have replaced the crank position sensor with sucess it fixed the problem but i cant see where this would relate to the EPC...
      good luck
      and search is you friend it is well documented in many VW audi forums (google is you friend)
      Quote Originally Posted by iTech
      Good point but then you have a car that weighs as much as the planet Neptune and handles like a beached sperm whale
      Custom Center Pieces
    3. Member vwooom's Avatar
      Aug 23rd, 2005
      New Brunswick, Canada
      '84 GLI/'01 Wolf
      02-07-2011 07:15 PM #3
      my engine is not a VR6, but my car behaved exactly like this when my MAF needed replacing. I was afraid to pull out and pass on a 2 laner because it would buck and surge. just sayin
      The prob is if the
      - MAF is going the computer doesn't know exactly how much fuel to give along with the air going into the engine. This is what caused the bucking around for me. I popped in a new MAF and it ran like Secretariat in the 73 Belmont Stakes
    4. 02-22-2011 04:58 PM #4
      I took it the the VW dealership and it turned out to be the throttle body. Cost me $1,450. UGH
      NOW the check engine light is on. Went to O'Reiley's and used their scanner. The code was P0240 bank 1. The parts store said that was my o2 sensor but more research on the issue tells me it's the catalytic converter ($1,100 to replace). Going back to the dealership today to get an accurate diagnosis.
      Is this what I have to look forward to with a VW? I am so dissappointed.
    5. Member vwmuscle's Avatar
      Apr 9th, 2007
      The 509
      '86 Golf wolfie (wrecked) '91 Jetta Carat (sold) '06 Rabbit (sold) '88 325iX (sold) '04 24v GLI
      02-22-2011 05:20 PM #5
      just like in an airplane, place head between knees, and kiss a** goodbye.
      \O8\==GLI===VW========/8O/.:VRSociety #242
      N00bies, read my Broke status thread. Start to a decent looking car on a low budget. http://forums.vwvortex.com/showthrea...othing-special
    6. Member
      Dec 24th, 2003
      penna
      2001 TT 225 Q
      02-22-2011 05:53 PM #6
      THAT STEALER took you to the cleaners !!!! my 2001 TB JOB WAS $575 two years ago
    7. Member MTVolks's Avatar
      Feb 11th, 2007
      Montreal
      337, Bagged Cabby
      02-22-2011 05:58 PM #7
      MAF
      Had this in my old Jetta, spent all kinds of money on sensors, new intake side of the turbo...
      Ended up being a dead MAF
