Results 71 to 105 of 120
Thread: Journal Bearing Precision VRT guys - Are you running an oil restrictor
  1. Member dub_slug's Avatar
    May 12th, 2008
    Chromed out mansion in paradise in the sky
    97 Gti VRT, Blue Boost, 01 JTI 12v Daily, ...?
    04-21-2011 10:13 AM #71
    Back on topic...
    If my seals were blown due to excessive oil pressure; would the car be smoking all the time? My buddy says I don't smoke at all while in WOT and full boost it does smoke a little on warm up and decel
  2. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    Mk3 VRT, Mk4 VRT, Mk4 VR
    04-21-2011 10:22 AM #72
    Quote Originally Posted by dub_slug View Post
    That's exactly what mine did when the seals were blown. James Bond all over the ****ing place.
    It might be a function of EGT & flow, ie for the volume of oil leaking (volume being constant since this particular turbo had a restrictor), if the temp exceeds a certain level the rate of burn and gas flow is so rapid that you don't "see" the smoke plume (but oil is still being burned). When you slow down the oil burns slower and the overall rate of exhaust gas is less (the smoke stagnates and you see it).
    "OP sounds like a MKIV guy"
  3. Member dub_slug's Avatar
    May 12th, 2008
    04-21-2011 10:35 AM #73
    Hmm that's very interesting. Where would I go about getting an inline oil pressure gauge so that I can make sure I'm not doing something wrong?
    Or can I log oil pressure through VAG-COM?
  4. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    04-21-2011 10:47 AM #74
    If your oil pressure sender is tapped off the oil filter housing (which I assume is where you are running your oil feed line from) then the pressure will be identical (assuming no additional restriction in your oil line itself).
    If your oil feed is from someplace other than the filter housing then your concern is valid and you might need to monitor pressure literally from the line itself (uncommon).
    Never checked oil pressure in Vag-Com but who knows, might be possible?
  5. Member dub_slug's Avatar
    May 12th, 2008
    04-22-2011 10:01 PM #75
    I'll be doing some logs via vag-com to see what pressures I'm running. But for now the gti will be back off the road since I stripped 3rd gear at 22psi...gonna save up for the aptuning gforce setup
  6. Member
    Dec 22nd, 2002
    CT
    04-23-2011 01:58 AM #76
    ^ this is what i did after my 2nd stock trans with a quaife broke 3rd gear... i love the straight cut 3rd and 4th!!! I want to get another set and build a back up trans
    2010 MB GLK350 4matic
    2009 Gti 2.0t powered by APR (Sold! last VW purchase!)
    2001 Gti 1.8t powered by Dalhback (sold and will be missed :') )
    1988 Jetta Carat Vr6 powered by www.LugTronic.com (99.9% done!!! )
    1987 Scirocco 16v w/t3t4 57trim powered by SDS (sold but never forgotten)
  7. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    05-13-2011 10:00 AM #77
    So.... a friend installed a "kit" last weekend from Kinetic on his 1.8T with a Precision JB and it was interesting to note that it came with a restrictor supplied. Is Kinetic covering their azz given the problems that people have been having with Precision JB units or do they know something that the general users/installers are not being told by Precision? I'm not sure on the specs of the feed & drain supplied with the said kit.
    Just thought I'd stir the pot a little. FWIW, still not using a restrictor on mine and not having problems (~25,000 miles on mine now).
  8. Member SVTDanny's Avatar
    Aug 7th, 2005
    Winchester, VA
    2010 GT500
    05-13-2011 10:06 AM #78
    I have a good 3,000 miles on my 6262 journal bearing, no restrictor, no problems.
  9. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    05-13-2011 11:46 AM #79
    Quote Originally Posted by djsheijkdfj View Post
    Good to hear but rack up a few more thousand on it. I should be around 30K within another couple of months (~2) or so. That being said people have had failures at your mileage or less. Perhaps you posted already but what is the spec on your feed line? It seems as if the "issue installations" are the ones with a -4 feed/-10 return. I think the failures with the -3 feed on the Precision JB are less common. What I'm seeing is that the guys with the -4 feed lines either are running a restrictor and/or a larger drain as people in this thread have already suggested.
  10. Member SVTDanny's Avatar
    Aug 7th, 2005
    Winchester, VA
    2010 GT500
    05-13-2011 01:36 PM #80
    -4/-10 here.
    I think it's -4 anyway, whatever comes with the Kinetic kit. I know it's a -10 drain because I just swapped to a braided line last week.
    EDIT - I should also mention, I'm running 5w30, and not some retardedly thick oil that everyone likes to pimp out for the VR's. Journal bearing turbo with no restrictor, 5w30 oil, 9.5:1 compression on a turbo motor.... by Vortex definition, my car should have blown up long by now.
  11. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    05-13-2011 02:13 PM #81
    -4/-10 here.
    I run -4/-10 also.
    I have been meaning to increase the -10 return on my Mk3 for a long time but it keeps falling to the bottom of my priority list. I think -10 is acceptable but in a minimal form. I'd really like Kinetic et al to start supplying larger return lines. Ultimately I will probably go with a -12.
    Lol, you are correct!
    I don't even want to start the compression and oil topics up.
  12. Member DubmyRUCA's Avatar
    May 22nd, 2007
    Pittsburgh, PA
    91' VRT GLI... 12' Golf TDI
    06-08-2011 03:49 PM #82
  13. Member SVTDanny's Avatar
    Aug 7th, 2005
    Winchester, VA
    2010 GT500
    12-10-2011 03:55 PM #83
    Found oil in my intercooler pipes today, pretty sure it's pushing it out on the turbine side as well.
    Another 6262 killed by a VR. Will be running a restrictor next time whether Precision says OK or not.
  14. Member
    Dec 22nd, 2002
    CT
    12-10-2011 05:50 PM #84
    Will be running a restrictor on my JBearing 6766 soon i used a restrictor on my old Pt 61 turbo and it was still good when i sold it 3years later
  15. Member
    Mar 15th, 2003
    London Ontario Canada
    12-10-2011 08:15 PM #85
    i started this thread last year, i have been running a restrictor all season and have had 0 problems
  16. Member SVTDanny's Avatar
    Aug 7th, 2005
    Winchester, VA
    2010 GT500
    12-11-2011 07:56 PM #86
    I might try just sticking a restrictor on mine and seeing if that resolves the problem rather than having to take it off and be without the car for who knows how long while Precision tries fervently to find a reason why it's my fault....
  17. 12-11-2011 08:57 PM #87
    It's sad, but true.
    On my setup I bought an undrilled oil inlet flange and then drilled it to a size I wanted, which was a slightly larger than the standard oil restrictor most people use. 0.065" seemed a bit small. No problems thus far on a -4 / -10 setup... not many miles on it yet though.
  18. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    12-12-2011 03:56 PM #88
    I might try just sticking a restrictor on mine and seeing if that resolves the problem.
    It should.
  19. Member Stangy's Avatar
    Mar 15th, 2007
    Toronto Canada
    1993 Cabriolet Classic 2.0 16vt on MS1 v2.2
    12-13-2011 03:14 PM #89
    Precision 6031 w/restrictor. It was reccomended by Precision as they stated without the restrictor the excess oil would bleed through the oil seals. Meh.
  20. Member SVTDanny's Avatar
    Aug 7th, 2005
    Winchester, VA
    2010 GT500
    12-13-2011 04:37 PM #90
    Quote Originally Posted by Stangy View Post
    They told you to use a restrictor?!?!?! Sounds like they've changed their tune.
  21. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    12-13-2011 06:40 PM #91
    Lol, yep cuz they have always been adamant not to run a restrictor unless you have abnormally high oil pressure.
  22. Member Stangy's Avatar
    Mar 15th, 2007
    Toronto Canada
    12-13-2011 11:05 PM #92
    Straight from horses mouth haha. Nik from cts Turbo! If I am not mistaken he says he reccomends it for all t3/t4 turbos. This was months ago so I may be off.
  23. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    12-14-2011 01:20 AM #93
    Quote Originally Posted by V-dubbulyuh View Post
    It should.
    Quote Originally Posted by optiks View Post
    LOL i guess restrictors do work after all everytime i mention it 900 people swear their turbos were destroyed by running them lol
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  24. Member
    Dec 22nd, 2002
    CT
    12-14-2011 06:23 AM #94
    Quote Originally Posted by Big_Tom View Post
    Good job on confusing everyone again to restrictor or not to restrictor a Precision turbo
  25. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    12-14-2011 08:07 AM #95
    Hold a sec, that is misleading... CTS/Nick is not Precision Turbo. Entirely two different sources. I am yet to hear Precision themselves agree to restrictor usage. I spoke to them in August (2011) about one of my turbos that I sent in.
    That being said despite Precision on multiple times telling me not to use a restrictor (unless you have what they determine "high oil pressure") I think we have proven that on Vrs if you are using the -4/-10AN combination you will run into issue on their JB turbos.
  26. Member Stangy's Avatar
    Mar 15th, 2007
    Toronto Canada
    12-14-2011 09:42 AM #96
    Im going to make this more confusing...i am running it on a 16vt . I suck at reading the titles haha
  27. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    12-14-2011 10:50 AM #97
    What do you 16vt guys see for oil pressure at idle?
    What do you 16vt guys see for oil pressure at cruise?
    Unless you are very confident in your return system, ie large drain (> -10 AN) on a VR you might be better suited to running a restrictor despite Precision's advice. I have had good results without a restrictor but given how many failures we have on the JB turbos it is probably the wise thing to do.
  28. Member BklynVeeDub's Avatar
    Oct 6th, 2005
    Brooklyn, NY
    05 GTI 1.8t
    12-14-2011 12:48 PM #98
    Not a VR owner but have had problems with my PTE BB5557 JB turbo. Here's a cool story:
    1 year into the turbo with about 5K miles. Running with no restrictor -4an feed and -10an return. I have another car for daily driver. Ran the car at the track twice with a total of 5 runs at 30psi on race fuel. When driven off the track it sees about 20-24psi depending on my mood. Good chunk of the 5K mileage came from driving to North Carolina from NYC and back.
    About a month after my warranty expires, the car starts smoking. Checked the IC piping.. all were clean and dry. Checked the tailpipe and nothing but oil on the inside. Took off the vband on the downpipe and dry. I'm thinking at this point the oil is just spitting towards the back of the exhaust.
    Turbo is off the car and everything looks fine and dandy. Take off the back housing and voila.. bad seals and oil leaking from everywhere. Sent it back to Precision, told me there was damage internally and that this was not manufacturer defect. Pay to rebuild and change seals or upgrade to BB.
    I've read and heard personally from my shop that the journals have issues. Precision does clearly state not to use a restrictor. Stand by your product or dont sell it. Hopefully this ball bearing unit holds up.
    Got Boost?
  29. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    12-14-2011 01:33 PM #99
    Quote Originally Posted by BklynVeeDub View Post
    The BB will hold up as it is internally restricted (can't see that they will use a different oil seal on the BB product-maybe they do and I'm ignorant to it but my suspicion is otherwise). I've never had an issue with their BB turbos, the JB is another story. Not that the JB are "unreliable" but they are certainly not as bulletproof as the BB (oil issues on one JB but never on a BB). If they were not asking ~$800-1000 to upgrade each JB to BB spec I would go ahead an have the upgrade done on everything. For now it is more cost effective to run a larger drain and then a restrictor if oil is still present.
  30. Member BklynVeeDub's Avatar
    Oct 6th, 2005
    Brooklyn, NY
    05 GTI 1.8t
    12-14-2011 01:56 PM #100
    When the idea of putting a restrictor on was bought up, the argument was that it would starve the turbo. Didnt they run the proper tests for oil pressure on the JB turbos? I wasnt very happy with the idea of having to up a lot of money to upgrade it to BB to avoid this problem again but I am happy with the new found spool up time.
    I just hope that Precision will come up with a fix for these issues.
    Got Boost?
  31. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    12-14-2011 03:42 PM #101
    Yep, their BB are great (I also agree with you on spool time). JB are kinda iffy for daily drivers if your configuration is not right. With respect to your question on starvation, all restrictors are not created equal. You can get blank restrictors of which you drill to your own spec or if you think that the pre-drilled restrictor is too restrictive then you can increase the bore.
  32. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    12-15-2011 05:12 PM #102
    On my 16vt I see about 12 psi at idle, and 60psi or so at 6k rpm. That's using valvoline vr1 20w-50w on a tired motor.
    Id still be suspicious of a precision jb turbo, its not just vw's/vr's that are having issues, there was a pretty decently sized thread on dsm tuners as well.
  33. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    12-15-2011 07:15 PM #103
    Quote Originally Posted by Dave926 View Post
    ^^^ yup, i seen problems on multiple forums
  34. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    12-15-2011 07:30 PM #104
    Toasted a 6262 journal bearing turbo in 6 weeks with a restrictor. Precision says not to run a restrictor because the oil pressure in the VR6 isn't considered high.
    Quote Originally Posted by ..Derek.. View Post
    Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    Tucson Forced Induction
  35. Member
    Dec 22nd, 2002
    CT
    12-15-2011 08:00 PM #105
    Ok now idk what to do with my journal bearing 6766 lol
