Page 4 of 4 FirstFirst 1 2 3 4
Results 106 to 120 of 120
Thread: Journal Bearing Precision VRT guys - Are you running an oil restrictor
    Mar 15th, 2003
    London Ontario Canada
    12-15-2011 08:26 PM #106
    restrictor
  2. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    Mk3 VRT, Mk4 VRT, Mk4 VR
    12-15-2011 10:18 PM #107
    Quote Originally Posted by KubotaPowered View Post
    Toasted a 6262 journal bearing turbo in 6 weeks with a restrictor. Precision says not to run a restrictor because the oil pressure in the VR6 isn't considered high.
    I personally do not run a restrictor... unless it starts to seep oil and enlarging the drain does not remedy the problem. I also agree with what you stated about the Vr not being considered high pressure.
    "OP sounds like a MKIV guy"
  3. Member turbo mike's Avatar
    Dec 7th, 2005
    Wharton, NJ
    97 Turbo GLX
    12-20-2011 10:10 PM #108
    what type of oil pressures are you guys seeing at idle when warm?
    Mike
    supercharged glx - 12.0 @ 113mph (12psi)
    turbocharged glx - 12.7 @ 108mph (7psi), 11's coming soon
    S362 .88 a/r
  4. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    12-21-2011 07:19 AM #109
    Quote Originally Posted by turbo mike View Post
    idle warm: 25-30 psi
    cruise vacuum: 50-60 psi
    cruise boost (hard): 75 psi
    These are pretty average values on most of my setups however I have a car that can run as much as +10 psi beyond the values just listed.
    Dec 22nd, 2002
    CT
    12-25-2011 12:43 AM #110
    ok so which fitting should I use for my Precision JB 6766 turbo???
    arnold at pagparts made me the (man-made) restrictor for a JB turbo
    2010 MB GLK350 4matic
    2009 Gti 2.0t powered by APR (Sold! last VW purchase!)
    2001 Gti 1.8t powered by Dalhback (sold and will be missed :') )
    1988 Jetta Carat Vr6 powered by www.LugTronic.com (99.9% done!!! )
    1987 Scirocco 16v w/t3t4 57trim powered by SDS (sold but never forgotten)
  6. Member
    Mar 15th, 2003
    12-25-2011 12:47 AM #111
    i use the top one and everything has been great from 0-12 000km
  7. Member CorradoFuhrer's Avatar
    Mar 21st, 2002
    Aalen, Germany
    1997 GTI VR6T DE
    12-25-2011 01:10 AM #112
    Quote Originally Posted by One Gray GLI View Post
    -4 feed, -10 return, journal bearing billet 6262 on a 24v, no restrictor, no problems thus far..5-6k on this particular kit.
    same setup on my 12v.
  8. Member turbo mike's Avatar
    Dec 7th, 2005
    Wharton, NJ
    97 Turbo GLX
    12-25-2011 02:48 PM #113
    Quote Originally Posted by V-dubbulyuh View Post
    I'm seeing about 12psi at idle warm, and around 75 when driving. I think the bentley says oil pressure at idle should be around what I'm seeing. Anyone else?
    Sent from my ADR6350 using Tapatalk
    Mike
    S362 .88 a/r
  9. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    12-26-2011 05:13 PM #114
    12 is way below spec (and if accurate, your motor shouldnt be driven as is). smashed oil pan perhaps?
  10. Member turbo mike's Avatar
    Dec 7th, 2005
    Wharton, NJ
    97 Turbo GLX
    12-28-2011 06:10 PM #115
    freshly built motor. used oil pump...might replace that and see whats up.
    Mike
    S362 .88 a/r
  11. Member turbo mike's Avatar
    Dec 7th, 2005
    Wharton, NJ
    97 Turbo GLX
    12-29-2011 03:51 PM #116
    bentley states a fully warm motor:
    @2000RPM, should see atleast 29psi
    higher engine speeds should result in close to 101psi(max)
    im seeing ~37psi at 2000rpm and a tad over 75psi at 6000rpm. anyone have more information about pressure at idle? bentley doesnt state anything from what i could find.
    Mike
    S362 .88 a/r
  12. Member 24vGTiVR6's Avatar
    Sep 13th, 2010
    24v VRT
    04-28-2012 12:24 AM #117
    I know this is bringing back an old thread.... but I have recent actual experience that could help others.
    I remember reading this before I started building my VRT, and ultimately decided to go without a restrictor - I made my choice mainly from the advice I received from Kinetic. 6-7 months later.... thick smoke poured out the exhaust. Took everything apart and there's oil in the DP, intake, etc...... seal died.
    I've come to the conclusion that a 24v VRT running a JB needs a restrictor - OR - a shut off valve + gauge setup in-line to regulate correct pressure (which is what I run now).
    -4AN feed / -10AN drain (0.625 ID)
    Oil pressure (at 200F):
    @ idle - 12psi
    @ 2k RPM - 26psi
    @ 7k RPM - 84psi
  13. Member MRosier's Avatar
    Sep 17th, 2006
    '96 Cabrio VRT, '97 Jetta VRT (rip)
    04-28-2012 10:00 AM #118
    Heres my experience...I have the PTE JB unit on my 12v that came with my kinetics kit. I forget the actual model #. Anyway, I bought the kit new, overboosted unknowingly due to precisions retarded wastegate having 3 vaccuum ports and no warning in the owners manual to cap off the extra boost signal port off...long story short melted 2 pistons sending piston and ring bits everywhere in the oil. Sent my 5k mile old turbo into precision for them to tell me it was not a manufacturer defect and the bearings and back housing were toast.
    Now I can sort of see where they were coming from with the whole "cut your oil filter open I bet youll find metal" (even though I never told them I melted pistons) Even still, the feed line is filtered oil correct?? Despite that I just wanted the turbo back so I Paid to have it rebuilt..meanwhile drove the car without the turbo kit and fresh internals with no smoking whatsoever. Reinstall the newly rebuilt turbo and drove to H2O with zero reported smoking. Fast forward to now and now I have really random smoking problems again yet no oil in the IC pipes or anything that could be seen with the downpipe off.
    I've been running the supplied restrictor from the kinetics kit since day one. -4an feed/-10an drain. No smoke ever on cold starts. Sometimes I get a cloud of smoke on start up when the engine is hot. Sometimes it randomly smokes at a warm idle for a few seconds then goes away. I never see any behind me while cruising but who knows what its doing. Don't even want to bother sending it in again for them to tell me its my fault and make me pay to rebuild their pos turbo for it to happen again. And to add, compression is on point, virtually no cyl leakage after performing a leakdown test..and the car is fast as **** so I do not have a worn motor issue here.
  14. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    04-28-2012 04:24 PM #119
    I'm still running my restrictor with no problems at all.
    Chosen Life Clothing. Streetwear for the car culture. Launch Party coming very soon!!
    Meet Long Island The place if you're looking for a euro GTG in the Long Isl./New York City area.
    FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    Kicks...Clothes...Cars...Ho's...THINGS I DO BEST!
  15. Member
    Dec 22nd, 2002
    CT
    04-28-2012 04:48 PM #120
    my restrictor is a little bigger than the normal .065 restrictor (almost .080) and my JB billet precision is still good
