VWVortex.com - *Liquid Intercooling* Bolt-on Methanol Injection Packages from BSH
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: *Liquid Intercooling* Bolt-on Methanol Injection Packages from BSH
    1. 02-10-2011 02:09 PM #1
      BSH & Snow Performance Boost Cooler Combo Pack
      BSH has joined forces with Snow Performance to provide you with the perfect one stop shop to suit your water/methanol injection needs.
      We will be offering special pricing on combination packs of any arrangement of parts you may need to complete your project.
      BSH/Snow Performance TSI Combo Pack 1
      Every Purchase of a Snow Performance stage 2 Boost Cooler Kit comes with a FREE Boost tap!
      Individually priced, this setup would cost $469.99. Bought as a package through BSH this costs $419.99.
      BSH/Snow Performance TSI Combo Pack 2
      To get your hands on a Snow Performance Stage 2 kit, Boost tap, & a BSH Throttle Pipe you would normally have to spend $650.
      You can now get the most complete and easy to install package at a savings of $82! Bought as a package through BSH, you pay $579.99!
      If you have questions we have answers! You can reach us by E-Mail at sales@bshspeedshop.com
      Ordering:
      To place an order for the any of these products follow the link to our secure website. You will receive notifications from processing to completion on the status of your order. We accept all major credit cards, Paypal, money orders and wire transfers.
      Don't hesitate to call. Our trained staff is always standing by to help you place your order or answer any questions you may have.
      ***WHY METHANOL INJECTION***
      Performance:
      No intercooler, factory or upgraded can lower inlet temps like methanol injection. This combined with methanol's increased resistance to detonation gives you race gas performance at pump gas prices! Our in house dyno testing has proven 22whp on a 2.0T!
      22 whp gained on a stage 1 car!
      Reliability & Support:
      We have been using methanol injection on our in house 2.0t and our personal vehicles for years in the US and have sold thousands of kits to customers all across the world. To date we have not gotten a single contact other then to tell us how much the customer was enjoying the product.
      We work directly with our Manufacturers to make sure your satisfaction continues after the sale and into the ownership process. We run these kits on our shop cars and have first hand experience in tuning and installing them.
      All in all this is by far one of the biggest bang for the buck modifications you can do to your FSI or TSI equipped vehicle.
      Snow Performance Stage 2 Boost cooler
      Get better IAT reduction and detonation control with the Stage 2 2.0T Boost Cooler kit . This kit uses manifold boost pressure to determine when and how much fluid to inject. Proportionally injecting according to boost pressure gives the most accurate delivery of water-methanol and allows the most cooling and performance improvement over the widest range. This offers accurate injection for small, quick spooling turbos. Enjoy more power over a wide range with smooth, seamless delivery. For higher boost applications (over 25psi), the controller can be upgraded to Snow's VC100 unit. Now with Lifetime Warranty - please call for details.
      Kit includes:
      • UHO (Ultra High Output) 250 psi Pump
      • 3 Quart Reservoir
      • Digital Variable Controller
      • 3 Nozzles To Cover a Wide Range of Horsepower
      • All Required Hardware Needed For Installation
      • Comprehensive Instructions
      Benefits of running the Snow Performance Methanol Injection Kit:
      • Lowers inlet temperatures between 50-150 degrees
      • Increases the octane of 93 octane gas to roughly 112
      • Allows you to run race gas programs without the expense
      • Lowers Exhaust Gas Temperatures
      • Steam Cleans the Inside of the Engine
      BSH 2.0T FSI Integrated Throttle Body Pipe
      Featuring a reduction in bends and no diameter changes this addition to your intercooler system will prevent added turbulence to the incoming air to the engine providing smoother power delivery and greater top end potential. Integrated into our throttle pipe system is a pair of our CNC machined *next generation* water methanol injection bungs and a CNC machined noise pipe/dv relocation port. These options set you up to seamlessly integrate any and all options (including full noise pipe delete!) without needing to fabricate your own solutions.
      Benefits:
      • Improved Throttle Response
      • Decreased Turbo 'Lag'
      • Enhanced Sound of engine
      • Installs in an Hour
      • Maintains All Factory Emissions Components
      • Fits Both Manual and Automatic (DSG) Transmissions for most applications
      Includes:
      • BSH Integrated Throttle Pipe
      • BSH Silicone Hose Kit
      • Two Methanol Bung block off plugs
      • O-Ring Sealed DV port block off
      • Hose Clamps
      • MAP Sensor Hardware
      BSH Billet Boost Tap
      Nothing says "almost there" like a bunch of t'd off lines cluttering your engine bay. BSH helps you tidy up your lines and provide a proper signal for your components with use of its billet boost tap for your FSI or TSI equipped vehicle. Utilizing CAD drawing and CNC Lathe machining this part is a perfect fit every time. The BSH boost tap comes with two ports so you can run your boost gauge, dv, methanol injection, or any other part you may want that requires a boost or vacuum signal to function.
      In Stock:
      These products are considered a normal stock item and will typically ship the same day as ordered. If there is a delay in your order you will be emailed promptly with a lead time and options.
      Ordering:
      To place an order for the any of these products follow the link to our secure website. You will receive notifications from processing to completion on the status of your order. We accept VISA, Master Card, AMEX, Discover, Pay-Pal, money orders and wire transfers.
      Shipping:
      All orders will be shipped FedEX.
      International shipping is available through our online store. For multi piece orders please contact us for shipping quotes.
      Hours of Operations:
      Monday - Friday from 9AM to 5 PM
      Saturday and Sunday we stay home but http://www.bshspeedshop.com is never closed!
      Contact info:
      Phone: 602-606-7973
      E-Mail: sales@bshspeedshop.com
      AIM: BSHSoeedShop
    2. Former Advertiser
      Sep 10th, 2001
      02-15-2011 03:55 PM #2
      BSH was one of the first companies to bring this system mainstream and we stand by it. If you have questions, we have answers and we are happy to educate the community on this great setup.
      Personally, this is one of my all time favorite modifications. It was one of those things I want back and forth on a bunch until I tried it, almost 5 years later and I'm still all about it.
    3. Former Advertiser
      Apr 10th, 2009
      02-17-2011 07:06 PM #3
    4. Former Advertiser
      Apr 10th, 2009
      02-18-2011 03:42 PM #4
    5. Former Advertiser
      Apr 10th, 2009
      02-22-2011 06:17 PM #5
    6. Former Advertiser
      Apr 10th, 2009
      03-03-2011 02:13 PM #6
    7. Former Advertiser
      Apr 10th, 2009
      03-14-2011 07:15 PM #7
    8. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      03-17-2011 05:36 PM #8
      Random question, there was a little bit of talk a month or so ago about BSH making a custom w/m pump bracket/shield that would protect the pump from the elements for those that want to use the open fog grills.
      Is this still on the radar?
      :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K. :Porsche 17Z BBK
      :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
      :Eurojet -Ceramic Coated TBE :DEFI :Unibrace :Tyrolsport :Bildon :Hawk :034
      TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
    9. Former Advertiser
      Apr 10th, 2009
      03-17-2011 05:44 PM #9
      Phil had mentioned that if there was a desire we would look into it.
      there hasn't been any work on it yet but we are glad to start if there are enough people interested.
    10. Former Advertiser
      Apr 10th, 2009
      03-30-2011 07:52 PM #10
    11. Former Advertiser
      Apr 10th, 2009
      04-04-2011 06:40 PM #11
    12. Former Advertiser
      Apr 10th, 2009
      04-08-2011 05:57 PM #12
    13. Member Aguilar's Avatar
      Jan 28th, 2006
      VA
      2.7tt F150, Mk7 GTI
      04-12-2011 08:51 AM #13
      Are the FSI and TSI throttle pipes the same?
    14. Former Advertiser
      Apr 10th, 2009
      04-13-2011 02:13 PM #14
    15. Former Advertiser
      Apr 10th, 2009
      04-13-2011 02:23 PM #15
    16. Former Advertiser
      Apr 10th, 2009
      04-13-2011 02:25 PM #16
      Quote Originally Posted by Aguilar View Post
      They are different. The plumbing for the noise pipes are different.
    17. Former Advertiser
      Apr 10th, 2009
      04-15-2011 04:36 PM #17
    18. Former Advertiser
      Apr 10th, 2009
      04-19-2011 05:50 PM #18
    19. Former Advertiser
      Apr 10th, 2009
      04-22-2011 07:05 PM #19
    20. Former Advertiser
      Apr 10th, 2009
      04-26-2011 02:44 PM #20
    21. Former Advertiser
      Apr 10th, 2009
      04-28-2011 07:23 PM #21
    22. Former Advertiser
      Apr 10th, 2009
      05-04-2011 07:15 PM #22
    23. Former Advertiser
      Apr 10th, 2009
      05-06-2011 05:53 PM #23
    24. Former Advertiser
      Apr 10th, 2009
      05-10-2011 04:04 PM #24
    25. Former Advertiser
      Apr 10th, 2009
      05-19-2011 06:32 PM #25
