Results 1 to 9 of 9
Thread: HOW TO: Fix the sloppy door handles
  1. Member iamdagerman's Avatar
    Feb 18th, 2006
    ga
    1 70 bug, 2 71 supers,89 Cabby, 72 Ghia (FS)
    02-11-2011 01:18 PM #1
    Parts list:
    1. 4-40 button head screw
    2. washer
    3. 4-40 tap
    4. correct size drill bit
    Step 1 Drill your hole
    Uploaded with ImageShack.us
    Step 2 Tap hole
    Step 3 Take screw and washer and install
    Now your finished!!!! It sure made my door pop right open with the sqeeze of the botton!
    Feb 26th, 2010
    Lake Tahoe, CA
    '78 Scirocco
    02-11-2011 04:07 PM #2
    Step .5: View images from orbit.
  3. Member RoccoRacer's Avatar
    Oct 22nd, 2001
    Logan, UT
    88 Scirocco 16v
    02-11-2011 06:21 PM #3
    Quote Originally Posted by gelandegolf View Post
    They look great on my iMac.
    Check to see if your camera has a "macro" setting, though. Use it for taking pictures of things close up.
    Ben
    '88 Scirocco 16v
    (][__][_]===W===[_][__][)
  4. Member Iroczgirl's Avatar
    Feb 17th, 2007
    Bend, OR
    '55 Ford 351C, '80 Rabbit AAZ
    02-12-2011 12:11 AM #4
    Pretty cool. I've never thought of doing that.
  5. Member A1peopleS2wagons's Avatar
    Dec 1st, 2010
    AZ.
    84 parts junker,85 legends turbo,76 scirocco,83 killed wolfsburg,and a chopped up and gone 82.
    02-12-2011 08:01 AM #5
    I got pissed at mine and accidently RIPPED the door handle off.
    Good write up.
    So if you need it thiiner just file it down,also use some loctite on the screw.
  6. Member iamdagerman's Avatar
    Feb 18th, 2006
    ga
    02-12-2011 10:18 AM #6
    You can use a counter sunk screw if you wanted it thinner
  7. 04-23-2012 08:03 PM #7
    Would this fix also apply to mk2 g/j handles?
    Mabe even Porsche 924 handles?
  8. Member iamdagerman's Avatar
    Feb 18th, 2006
    ga
    04-27-2012 04:57 PM #8
    Yes
  9. Member Eistreiber's Avatar
    Dec 10th, 2006
    Northern Colorado, USA
    5x Mk1 Sciroccos, and a ('91) Toy Twuck
    04-27-2012 07:20 PM #9
    Nice write-up, thanks!!
    I'd suggest finish with a light filing and make nice and smooth, and some grease; not to get personal but some slippery helps, usually.
    When a man tells you that he got rich through hard work, ask him: 'Whose?' -Don Marquis
