Results 71 to 105 of 106
Thread: My Brilliant Timeline
    Feb 3rd, 2011
    Lombard, IL
    99.5 A4 1.8TQM
    03-21-2012 01:19 PM #71
    Throw a piece of vacuum line around that hole so the hole doesn't accidentally cut a wire or anything.
    Alex
    Strictly Pleasure/Zero Clearance/Stretch Your Legs IX
  2. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    03-21-2012 01:26 PM #72
    Im actually using part of the old boot that the harness was in coming from the ecu, through the false firewall. Im going to wait to put it around the harness in the hole until I get the motor back in, and everything hooked up.
    1998.5 A4 1.8TQM / FrankenTurbo F4H-L / C2 Motorsports Tuning / 440cc Injectors / C2 Billet 3" MAF Housing / Cat Delete / Vibrant Muffler
    Feb 3rd, 2011
    Lombard, IL
    99.5 A4 1.8TQM
    03-21-2012 02:09 PM #73
    Quote Originally Posted by xdewaynex View Post
    That's what I am going to do! I have a full spare harness that I'm going to cut up and use to extend wires and keep oem wire wrap on the harness.
    Alex
  4. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    03-22-2012 11:23 AM #74
    Ive got to get some heat resistant wrap, as Ive cut away some of the factory heat shrink/wrap. There is no way, Ill be able to get heat shrink over the plugs to recover it.
  5. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-08-2012 08:21 AM #75
    Got all my gaskets Friday to start putting the motor back together. Im going to spray the valve cover and intake manifold black, before I put them on. Everything else is bolted back up except for those 2. Ive still got a couple fittings Ive got to order so I can install all of my oil and coolant lines. Im going to try and tackle the engine bay today, get all the holes welded up, smoothed out and ready for paint.
  6. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-19-2012 07:54 PM #76
    Just a quick update. Got the rest of my fittings except for the 2 oil flange adapters I need for the turbo and oil pan. Everything else is bolted back up to the motor, except for the clutch and transmission. I reinstalled my clutch fan, as Ive ran out of money to even think about picking up an electric fan, and since the transmission in my A6 is on its way out, I need to cut some things out and finish the A4. I plan to bust ass this weekend, and get the car back together. Im going to try my best to get the holes in the firewall welded up tomorrow, and get it ready for paint. Im crossing my fingers, and hoping to have it all back together by Sunday.
  7. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-22-2012 04:23 PM #77
    Had a good friend come and weld up the firewall for me this morning. Got all my lines finally routed for the oil and coolant. Only thing left for the motor is bolt the clutch and trans up. Going to work on cleaning up the welds on the firewall tomorrow and get it ready for paint.
    Just hanging around...
    Feb 3rd, 2011
    Lombard, IL
    99.5 A4 1.8TQM
    04-22-2012 04:42 PM #78
    Any pics of the bay so far?
    Alex
  9. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-22-2012 04:48 PM #79
    No new pics of the bay just yet. I need to clean up the welds on the filler plates, which will most likely be done tomorrow.
  10. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-23-2012 02:03 PM #80
    Got the flywheel, clutch and pressure plate all bolted up. I ran around trying to find a star bit to fit the flywheel bolts that ECS had sent, since the head was round and not 6 sided. Also got my oil return line cut down shorter and ran as straight as possible to the pan.
  11. Member
    Dec 19th, 2011
    92646 (Orange County, CA)
    1998.5 Audi A4 1.8TM
    04-23-2012 03:14 PM #81
    I like your coolant return line! If/when I do stainless coolant lines I'd like to copy you on that
    As for your oil drain line, will you be running AC? My PSi Concepts line hits the AC compressor. I've spaced the AC compressor out by about 4mm and still need to find an appropriately longer belt.
    98.5 A4 1.8TM (FWD): VAG-COM, FrankenTurbo F4H-L, United Motorsport 630cc/3bar, 70mm ID MAF in stock airbox with aFE dry filter, CXRacing 28x7.5x2.5 FMIC, 3" HFC, custom 2.5" Magnaflow exhaust, ICM delete, 2.0TSI coilpacks, E-fan, catch can, relocated DV, Bilstein sport/Tein, Neuspeed F/R sway bars, A8/TT brakes, single mass flywheel, JHM short shifter/linkage upgrades, custom sound system, 2-pc. Depos w/ Bixenon projectors
  12. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-23-2012 03:27 PM #82
    Thanks. All of my lines are just copies from PSI Concepts. I will be running my AC as well. I honestly didnt think about the line hitting the compressor. Hope it isnt too big of a problem when I go to reinstall it.
  13. Member
    Dec 19th, 2011
    04-23-2012 04:39 PM #83
    From my setup, the oil drain line by PSi concepts is pretty much straight without the AC compressor there. It gets stretched slightly as the compressor is tightened into place.
  14. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-25-2012 10:03 AM #84
    Got the transmission and starter bolted up the the block yesterday. Just got in from grinding down the welds on the firewall. Im going to work with what I got, as I dont want to chance grinding through the welds, and having to get someone to come back over and do it again. Also smoothed down some spots where I had cut off some of the factory studs.
  15. Member
    Sep 24th, 2010
    queens NY
    00' a4 tuned
    04-25-2012 09:31 PM #85
    How the hell did you run a catch can and delete the pcv system??? ive been trying to figure it out for the past months and cant grasp what goes where
    Flickr +00 A4 ATW,Giac Chipped,Ko4-15,St Coilovers,Borla V2 exhaust,Labree testpipe,Misc S4 exterior parts with cupra R lip, EVOMotorsport FMIC... my blog -->http://strictlyeur0.blogspot.com/ http://www.facebook.com/MarkM.Photography
  16. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-26-2012 01:23 AM #86
    Quote Originally Posted by SmokeTheRear View Post
    The hard pipe that goes behind the engine, around to the turbo. Practically everything attached to it, I deleted. Bought 034's block breather adapter, got a fitting for it and ran the line to the inlet of the catch can. I deleted most of the vacuum lines as well. There should be a few threads on here, and even Audizine that have a thorough description on everything.
  17. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-26-2012 03:26 PM #87
    Firewall is painted! Thinking of taking tomorrow night off work, and getting the motor sat in and done.
  18. Member
    Feb 3rd, 2011
    Lombard, IL
    99.5 A4 1.8TQM
    04-26-2012 04:17 PM #88
    Looks pretty damn good. Not going to move the abs?
    Alex
  19. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-27-2012 12:11 AM #89
    Thanks. Nope ABS is staying where its at. I didnt want to mess with relocating the battery and everything else involved.
  20. Member
    Feb 3rd, 2011
    Lombard, IL
    99.5 A4 1.8TQM
    04-27-2012 02:19 AM #90
    It's really not bad at all. e36 battery cable works, fullsize battery fits in the trunk, and all the brake lines are fairly simple to bend and install.
    Alex
  21. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-27-2012 06:01 AM #91
    I may do it later on down the road. But I have got to make room in the trunk, as my stereo system takes up the majority of the trunk for now. Im just in a hurry to get it back on the road, so I can park the A6 and try and salvage the transmission.
  22. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    04-30-2012 12:27 PM #92
    Car is back together finally. It starts up and runs, but idles roughly around 400-500rpms, and the clutch doesnt feel likes its fully disengaging, so going into gear is extremely hard. Im having a friend come over this weekend and hook up a laptop to it, so he can adjust the throttle body so the car can idle right, and hopefully figure out my clutch issue.
  23. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    05-05-2012 03:07 PM #93
    Had a guy come over and run vagcom on my car. Got the throttle body adaptation done, and put the headlights back in. Car runs, and the clutch for some reason isnt too hard to go into gear now, but Im still thinking of having the system completely flushed.
    *dont mind the tape on the coil packs*
  24. Member fbm93's Avatar
    Mar 25th, 2008
    Rhode Island
    2001 Audi a4T(Sold), 1.8 gli(Sold), b4 vr wagon
    05-05-2012 03:36 PM #94
    That looks fresh dude. Did you have to extend any wires? (sry if you mentioned that already)
    -Wes
    What was this!? A car show for ants!? Those cars need to be a least...3 times that big!
    germansdoitbetter.com
  25. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    05-05-2012 05:03 PM #95
    Thanks man. I did actually have to extend the wire going to the bottom of the coolant tank.
  26. Member doored454's Avatar
    Sep 6th, 2009
    Lehigh Valley/Hatebelt, Jawnsylvania
    DE ginster, 04 wrx, 90 454SS dragging doors, 02 duramax dually
    05-06-2012 08:49 AM #96
    Looks awesome broski, the black bay looks great with the yellow. Come up and do mine now.
  27. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    05-06-2012 09:14 AM #97
    Too far away, lol. Its going to be a long 500 city miles to break this damn clutch in. Im ready to just romp on it and go, its been too long.
  28. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    07-04-2012 01:15 PM #98
    Black and Yellow, Black and Yellow...... My stock bumper was trashed and I picked this black bumper up a long with a new fender and door, and got tired of the bumper sitting around. I reused the reinforcement bar from the yellow one and stuck the black one to it. I kept most of the center connectors so I can use the center grille. I think it turned out alright.
  29. Member
    Feb 3rd, 2011
    Lombard, IL
    99.5 A4 1.8TQM
    07-04-2012 06:41 PM #99
    Car looks like Imola!
    I really like your pass side of the engine bay, I need to get on that
    Alex
  30. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    07-04-2012 07:10 PM #100
    Thanks. Yea the Brilliant Yellow is really hard to capture in the right light. If its slightly off, it comes out looking Imola.
  31. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    12-02-2012 11:39 PM #101
    Reading back through this thread made me depressed, lol. Im still running without a bumper, as I had my intercooler pipes modified to fit better, new silicone couplers, removed the a/c system, and thats it. Car is spiking 25lbs of boost like a boss and pulls hard as hell.
  32. Member Ozzker's Avatar
    Jun 4th, 2010
    Guelph, ON, Canada
    2001.5 Audi S4 6spd Quattro Stage 3
    12-04-2012 07:09 PM #102
    Great Build!
  33. Semi-n00b
    Nov 30th, 2012
    Phoenix, AZ
    98 A4 1.8T Quattro
    12-04-2012 10:15 PM #103
    Awesome job. Can't wait to get to work on mine
    1989 Mercury Grand Marquis (deceased)
    1998 A4 1.8T Quattro (current)
    K04 turbo/2.5" Scorpion Exhaust
  34. Member
    Oct 24th, 2009
    NEPA
    1996 Audi A4 Quattro
    12-04-2012 11:23 PM #104
    I remember seeing you post the start of this over on BMX-Forums, glad to see you made some progress. Your B5 was one of the first I saw that gave me the itch to want one.
  35. Member xdewaynex's Avatar
    May 25th, 2009
    Danville, Ky
    98.5 Audi A4 1.8TQM
    03-09-2013 04:27 PM #105
    Just installed 034 Motorsports Motorsport Motor Mounts today. The car feels soo different now, without all of the engine slope. The vibrations arent nearly what I was expecting, and bearable for a daily. I highly recommend these to anyone, looking to lock down their engine.
