VWVortex.com - What wheel bolt pattern is my 03 TT? 5x100 or 112?
    Results 1 to 4 of 4
    Thread: What wheel bolt pattern is my 03 TT? 5x100 or 112?
    1. Member karna's Avatar
      Mar 19th, 2006
      Alberta, Canada
      02-17-2011 06:14 PM #1
      Like the tittle says im looking for wheels for my 03 tt quattro and im getting confused. First i heard that the bolt pattern is 5x112 no that i do more research it comes out its 5x100, i still see people running 5x112 tho.
      Can someone tell me what the actual bolt pattern is?
      Thank you
    2. Member SoloGLI's Avatar
      Jan 19th, 2005
      Woodland Hills, CA
      2002 Audi TT ALMS
      02-17-2011 07:01 PM #2
      5x100
    3. Member ILLA NOIZ's Avatar
      Jul 1st, 2007
      Charlotte, NC
      2001 Audi S8
      02-17-2011 07:10 PM #3
      As stated above 5x100. You cab run adapters in order to run wheels with different PCDs (bolt patterns)
      2001 AUDI TT 225 QUATTRO - APR93 | FORGE DV | K&N DROP IN | 42DD 3" DP W/ HIGH FLOW CAT | BFI STAGE 1 MOTOR MOUNTS | BFI STAGE 2 DOGBONE| HALDEX BLUE | B&M SS KIT | FORGE SS KIT | MANTIS ALUMINUM GAUGE POD | ADJUSTABLE REAR LCA'S | VMAXX COIL OVERS | 17MM SPACERS REAR | 18X8 TSW CROFTS | FULL VOTEX (REAR NOT INSTALLED) | BADGELESS GRILL | DE BADGED
    4. Member Doooglasss's Avatar
      Aug 28th, 2009
      Long Island NY
      Mk1 TT 2.0T/PTE-5857/E85 & 04' B6 A4 & 01' SV650S
      02-18-2011 05:16 PM #4
      You might be getting confused because MK2 TT's are now 5x112 and most other Audi's (older and newer) are 5x112. All MK1 TT's are 5x100.
      Older 4 lug VW's are 4x100 while Audi had to use 4x108
      Ridiculous.
      -Doug
