Results 1 to 3 of 3
Thread: P2187????
  1. n00b
    Jan 25th, 2011
    long island, n.y.
    2004 Beetle convertable, 2003 GTI 5spd auto, 2003 Chey Cavilier 2.2 Auto
    02-18-2011 10:37 AM #1
    Greetings.
    2004 Beetle
    BEV 2.0 liter
    6 spd auto
    Check engine light. Code: P2187?. Vehicle runs and starts normally. Quick check shows
    no noticable vacuum leaks. Clearing code and restating will trip light at around 185 degrees F. and low rpm about 20 mph road speed.
    Any ideas, common failures or direction I can follow???
    Thanks
    Chuck
  2. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    02-18-2011 12:29 PM #2
    18619/P2187/008583 - Bank 1; System too Lean at Idle
    Possible Causes
    * Injectors leak/blocked
    * Air Intake Leak (after MAF)
    * Exhaust Leak
    Possible Solutions
    * Check Mass Air Flow Sensor (G70)
    * Check Injector(s)
    * Check Fuel Pump
    * Check Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    That's the info on that code. Though you said the car is running fine? With a MAF problem and the like, you should notice some differences in drivability I would imagine.
  3. n00b
    Jan 25th, 2011
    long island, n.y.
    02-19-2011 10:28 AM #3
    Thank you for your reply...........I will give it a check.
    Chuck
