Well crap. So I got alot of work done to the radiator setup today. About ready to install it and I decided I needed a few parts before doing so. Was heading to the parts store about 6:30 pm tonight and some moron decided it was OK to drive right into us.So were OK, my right leg is giving me some pain though. Car might be totaled since it is older, guess we'll find out monday or tuesday.
I'll post tomorrow if I can still walk.![]()
on that one,an expanded metal cage across the front & at least a little past the rad's front cap if not the whole length on both sides all the way up to the floor.
With antifreeze now in the cooling system instead of water(never put antifreeze in for your first start up unless you like throwing money and antifreeze away. You are always bound to have leaks/issues on the first try) the fans now come on at 195 and go out at 145 in less than 30 seconds. The combination of the dual fans and the fan shroud make this system very efficient.
No, I'm not going to put a subaru motor in it. I have a subaru motor and it is going in my baja bug.
