VWVortex.com - Heated seat not working
    Results 1 to 9 of 9
    Thread: Heated seat not working
    1. Junior Member
      Feb 4th, 2008
      2006 Audi A4
      02-19-2011 06:57 PM #1
      We bought an b5.5 and the passenger seat is not heating. What and where to check? Or is it like a heating core or something under the seat?
    2. 02-19-2011 07:03 PM #2
      Quote Originally Posted by rlyon View Post
      Fuse (listed on fuse panel cover).
      Switch failure or wirin loose.
      Plug under seat dislodged or burnt.
      Actual heating element in seat burnt or broken due to someones knee in the seat.
    3. Junior Member
      Feb 4th, 2008
      2006 Audi A4
      02-19-2011 08:29 PM #3
      Awesome, thanks for the check list. I'll go and start poking around.
    4. 02-20-2011 01:37 PM #4
      the knees in the seat .......never thought about that as a diagnoses for faulty heated
      seats.......A friend of mines has a 2002 A8L and his passenger side front and rear
      heated seats dont work...but after reading this, he does have two children 4 and 5.....
      MK2 Jetta/Golf with a 2.Slo swap and a diesel 5th sounds good for MPG's.....Inflating gas prices make my beloved VR6 less desirable for DD....
    5. Member Zookie's Avatar
      Jan 5th, 2004
      Toronto, Bombay, Kuwait & Dubai
      Porsche 996 C4S, Audi B8.5 A4 Sedan & VW Jetta VI Sedan
      02-23-2011 12:25 PM #5
      there was a Recall on this... i had the same issue, mine turned out to be the Switch Only... Got one of ebay and swaped it and it worked fine
      I dont remember if i did this but i think i Swaped the Switch from Driver side to Passenger side to see if it worked...
      Quote Originally Posted by silverd2 View Post
      this happend in my porsche, but it was covered under cpo warranty
      Zook – Simply Tire
    6. Junior Member
      Feb 4th, 2008
      2006 Audi A4
      02-23-2011 12:32 PM #6
      ^good info. I'll check the switch and recall tip.
    7. Member Zookie's Avatar
      Jan 5th, 2004
      02-23-2011 01:50 PM #7
      yea call your dealer with your Vin number... it was Recall M2 (Driver Side) Which involved some Zip Ties and Wiring and M3 (Pass Side) which involved the Heat Switch (Tumbler by which you control the 5 level of heat) to be replace with a Superseeded Part Number, mine was done in DEC 2005
      Zook – Simply Tire
    8. Member Zookie's Avatar
      Jan 5th, 2004
      03-07-2011 12:32 PM #8
      well did you get this Sorted?
      Zook – Simply Tire
    9. Junior Member
      Feb 4th, 2008
      2006 Audi A4
      03-12-2011 01:22 PM #9
      I couldn't find a fuse for the seats, so no idea there. I'm gonna try flipping the switches to see if the one is bad.
