Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 106 to 140 of 311
Thread: The Bachelor Bunny
  1. 02-08-2012 07:14 PM #106
    Today: spent the afternoon sanding and respraying the bay. I was able to shave a few more brackets off the firewall, so I wanted to get those filled and painted in hopes of keeping the momentum going.
    I went back out for a bit tonight and wrestled with that passenger rear brake line some more. After seeing how easy the Autozone pre-made lines are to use, I ended up just cutting it out.
    Finally, I routed the rear lines to the master cylinder and cleaned the over spray off of them.
    During my adventures under the car though, I found a third line that routes along with the fuel lines. It was wrapped up underneath the car, but looks like it's meant to come through the same opening. Any idea what this little guy is for?
  2. Member MattRad's Avatar
    Feb 13th, 2007
    PA
    1980 Sh*trocco, 1988 Trooper II
    02-08-2012 07:33 PM #107
    Hey man that's a vacuum line that runs back to the fuel tank. I'm not sure if you'll need it or not but for my aba swap I removed the whole line and capped the bung on the tank. Getting the cap on sucked but is doable. as for your fuel lines, I'm not sure if you can see them in the picture but I took matt's advice on placement and used a tubing cutter to cut them down.
    IronTrap - Death Machine and Man in Love
    Wing it Engineering.
    Another MK1 Saved - The SH*TROCCO Project
  3. 02-10-2012 10:48 PM #108
    Thanks, Matt. I'll likely do the same then. Can I borrow your tubing cutter some time?
    Tonight: FINALLY finished rebuilding the braking system. Using 2 pre-made Autozone lines and a union, I pieced together the rear passenger line and bent it into place. With the lines secured and snug, I greased the wheel bearings and slid the drums back on. Weeks ago I had hit them with some Chassis Black which really helped bring them back to life.
    Did the nuts up, popped in some new cotter pins, and adjusted the parking brake. Wow, did that all just happen? Actual results? Now I just need to wait for an unsuspecting soul to wander into the garage to help me bleed the system.
    With time left in the evening, I pulled the valve cover off the motor to replace the leaky gasket.
    Everything looks ok in the head, but one spot on the cam has me a little concerned. Is this something to worry about or no big deal?
    Anyway, I cleaned off the old gasket and put the new one in place along with the plastic cover.
    While the valve cover is off, I also cleaned it out, sanded, and primed. Looking forward to having more fun with paint tomorrow
  4. Member MattRad's Avatar
    Feb 13th, 2007
    PA
    02-10-2012 11:42 PM #109
    Yes sir you can borrow my tubing cutter. Good work on the bunny hoping we will have both of our cars done for spring time
  5. Member gti1977's Avatar
    Oct 1st, 2008
    Poland
    Golf mk1 GTI`77,Golf mk1 LD`77,Golf mk1 GX`83,Golf mk2`88 16V G60 project
    02-11-2012 01:44 PM #110
    use sandpaper number 600 with some oil
    if rust is deep you should change camshaft
    if only surface you can use it still
  6. 02-16-2012 09:04 PM #112
    A few exciting (to me at least) updates with the car.
    Ever since I installed the new manual steering rack, I've been pulling my hair out trying to figure out why the steering column joint would no longer reach the knob on the rack. For months I thought it was because I am using an early westy steering column with a late westy steering rack. After searching and searching for a longer U-Joint, I finally typed in the correct query terms here and found that my shaft could be collapsed.
    I found the it's meant to be 22" long and after pulling everything apart again, my shaft came up a little short
    Got that sorted and performed a quick zip-tie remedy for the lower bearing, and we're now able to turn the car!
    This was the last piece of the puzzle that was keeping us from dropping the motor in. Hopefully I can source enough orange soda to convince Jamie to stop by with the engine lift sometime this weekend.
    While I was in the garage I also started some other project areas that I've been putting off. I'm planning on having heat in the car, so tonight I cleaned up the blower, added a new strip of foam to seal it, and installed it into place.
    Question: I picked up a used heater core a few months ago, but I'm not sure if I have the right size. How tight should it squeeze into the rectangular opening of the blower box thing? Right now, my heater core seems like it's too small... I'll grab a photo next time I'm out there.
    Finally, I pulled the headlights out of the bucket to start bringing them back to life. They had some pretty gnarly surface rust, but luckily they are still solid enough to use. They cleaned up ok after some wire wheel action, but I'd still like to spray them with rust converter once I pick up another can.
  7. Moderator the brit's Avatar
    Jun 23rd, 2003
    Pottstown, PA
    VW Fox 16v
    02-16-2012 09:22 PM #113
    Quote Originally Posted by benjaminobscene View Post
    You should have said earlier that Orange Soda was involved.
    On the heater core:
    1. It should have a 1/2" of foam wrapped the whole way around it. Maybe that would fill the space?
    2. Why are you using a used heatercore? They go bad, and a PITA to replace once everything's installed. I just checked and was surprised how much they cost (my cost is just under $50) but it's so easy to do it right at the moment. Maybe someone has a link to a cheaper source??
    | œ Orchid Euro Importation œ |
    Currently driving or working on...
    | '93 Fox 16v - PVW| '03 Sprinter - Build Thread | '99 Polo Greenland Polo - Build Thread | '85 Scirocco Storm RHD - Thread | '85 Polo RHD | '75 Swallowtail - Build Thread |
    | '99 Lupo 1.4TDI-S | '82 Caddy | '90 Jetta 8v | '96 Volkswagen LT35D | '02 GTI 337 | '03 GTI 20v |
    | '09 Aprilia RS125 | '81 Kawasaki AR80 | '78 Honda CB125 | '59 NSU Quickly | '64 Honda Cub C65 | '65 Honda Cub C105 |
    | Trek Madone 6.9 |
  8. 02-16-2012 09:40 PM #114
    The used one was mega cheap and I think I bundled it with the brake calipers and some other parts. GAP charges $65 which is what I was comparing against.
  9. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    '50 Dodge Pilot-House, '52 DKW 125W, '76 Rabbit Ocean Bleu X2,EA Cabriolet,'77 Scirocco
    02-17-2012 08:27 AM #115
    The opening between OE A/C equipped cars and non-a/c is different. A/C cars had a larger opening. If your car was originally an A/C equipped car (2 big square holes in the raintray one in the center and one on the passenger side) you'd need to make filler plate that screws into the large A/C opening, but has the opening for the Non-A/C box if you want it to fit properly.
  10. 02-19-2012 11:06 AM #116
    Big day yesterday.
    The motor went in surprisingly carefree. While Jamie was over we also tried to bleed the brakes, but with a completely empty system it was taking forever so we moved on to the motor. I also snapped off a bleeder valve which keeps things fun.
    For now, all the other valves are open and gravity is doing its job.
  11. 02-23-2012 08:53 AM #117
    Not much going on lately. I started cleaning up a bumper and ordered a bunch of maintenance parts.
  12. 02-29-2012 08:39 AM #118
    Quick question:
    I'm confused about the clutch cable grommet at the firewall. I think I have it figured out, but would greatly appreciate some reassurance.
    In digging through my box of grommets, I pulled out a grommet with "clutch cable" scribbled on it. It looks exactly like item 34B. This grommet, however, is both too small to fit in the firewall hole and too small to slide over the end of the clutch cable.
    After seeing this diagram, my hypothesis is that 34B is the grommet for an automatic transmission car (which my car was) and 34A is the appropriate grommet for the manual transmission cable.
    Is the simple solution to just order a 34A?
    Thanks!
  13. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    02-29-2012 08:49 AM #119
    yessir, sounds like you are missing the correct one. Any A1 manual trans car should have the same bushing. Could try one of the Mk1's at one of the local yards? Not sure if that part is obsolete or not
  14. Member aeffertz's Avatar
    Dec 6th, 2009
    Ladysmith, WI
    '79 Rabbit, '84 Rabbit, 2012 GTI
    02-29-2012 08:51 AM #120
    Big day yesterday.
    The motor went in surprisingly care free.
    Looks good man!
    You install in through the top or bottom?
  15. 02-29-2012 09:17 AM #121
    Quote Originally Posted by saddest6day66 View Post
    Thanks, Matt. I found the part here: http://www.jimellisvwparts.com/produ...171721380.html for only $6. Shortys has been disappointing in the mk1 supply lately
  16. 02-29-2012 09:17 AM #122
    Quote Originally Posted by aeffertz View Post
    Looks good man!
    Thanks! Very carefully in through the top.
  17. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    02-29-2012 09:18 AM #123
    Oh nice! I need to stock up on some haha
  18. 03-11-2012 07:28 PM #125
    I didn't have a whole lot of time this weekend, but tried to get as much done as possible in between yard work and running errands. Saturday morning, I added a few walls to the "paint booth" to try and minimize the mini blue dots accumulating on everything in the garage.
    Also, while the sun was out warming everything up I laid out the nice new brown carpet courtesy of saddest6day66 to try and loosen it up after being folded in a cardboard box for years.
    Back inside, I spent a lot of time sanding and cleaning out the rear part of the interior for some baby blue treatment. While that was drying, I got a little ahead of myself and test fit the carpet.
    Fast forward to today, the paint was dry so pushed the car out into the sun and laid down some chassis black in the spare tire area. I'm very pleased with how this turned out. Almost looks like the black is there on purpose. Once that was dry, I started messing around with the battery location kit I ordered from Summit.
    I then started to arrange some of the wiring but quickly got overwhelmed with that and decided to install the new driveshafts. Passenger side went in nice and smooth, but unfortunately I was unable to get the nut off the drivers side. The car has been rolling around on cut shafts so it's really hard to keep the wheel steady as I throw all 135lbs into the breaker bar..
    Stuck again, I decided to fit the headlight buckets and threw the grill on for fun before wheeling it back into the garage for the day.
  19. 03-11-2012 09:21 PM #126
    Great build, very inspiring and keep it going! Mind if I ask, what wheels are those? And what size are they?
  20. 03-11-2012 10:40 PM #127
    Quote Originally Posted by 82vwRabbit View Post
    Thanks. They are maserati biturbo wheels. 14x6" et6 with 165/55/14.
  21. 04-08-2012 08:30 PM #128
    Update: the car is finally one color small victories lol
    Up next: figure out how to connect my battery relocation and get this baby wired up.
  22. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    04-09-2012 09:05 AM #129
    Are you using junkyard bits for the battery relocation or what? I've found BMW E34 and E36 cables and power distribution boxes work perfectly for doing the conversion. Then just buy a cheap battery box and you are set
  23. 04-09-2012 09:53 AM #130
    I bought the fancy kit from summit but still need to raid a mk4 for a distribution block
  24. 04-09-2012 10:22 AM #131
    also if you and/or Mr. Rad would want to stop by sometime and give me a crash course in MK1 wiring I would be resplendent and fully stocked with palmers and pbr
  25. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    04-09-2012 10:42 AM #132
    Haha I'd be down sometime, just need to find the damn time to peel myself away from my own garage!
  26. Member aeffertz's Avatar
    Dec 6th, 2009
    Ladysmith, WI
    04-09-2012 03:13 PM #133
    Quote Originally Posted by MattRad View Post
    I always thought you needed it to vent the tank. even if you don't run it to the canister in the passenger wheel well, I just thought it would cause your tank to burp fuel back at your while trying to pump it. But I'm not positive.
  27. 04-11-2012 10:50 AM #134
    A couple quick pictures from last weekend:
    and back into the freshly cleaned out garage:
  28. Member Rockmonky's Avatar
    Nov 7th, 2003
    boulder co
    1979 Rabbit 4-door
    04-11-2012 11:00 AM #135
    rattlecan!
    how's the paint looking?
  29. 04-11-2012 11:53 AM #136
    Quote Originally Posted by Rockmonky View Post
    rattlecan!
    Amazingly the baby blue rustoleum lays really nice and smooth. I'm awful with bodywork and painting though so eventually I'd like to clean up some of my bodywork and respray the car. As you can see from the pics though there's really not much to complain about from 5ft.
  30. 04-13-2012 08:10 AM #137
    Frustrated after last night..
    I scored a pressure bleeder on clearance from HF and set up to try bleeding the brakes again. It is a vacuum type setup so I filled an empty bottle with brake fluid and connected it to the open bleeder screw on the cylinder/caliper then disconnected the brake line from the master cylinder.
    Popped the clear vacuum hose onto the open brake line and let the master cylinder gravity bleed a bit.
    1. If fluid drips out of the MC ports that's a good sign it's "bench" bled right?
    So then I proceeded to pump up the vacuum to 15-20psi and let the suction pull brake fluid from the bottle up to through the line. When the hose showed all fluid, it released the pressure and reconnected the line. Repeat x2.
    I say x2 because the bleeder screw is broken on my passenger front caliper. For this line I just disconnected the brake line from the caliper and stuck that into the fluid bottle to draw the fluid up through the line.
    2. Anyone sitting on an extra passenger front caliper?
    After making a royal mess I reconnected everything and went to test the system. The pedal has some resistance and returns to the up position, but I couldn't get it to actually activate any kind of braking.
    Going to try the old fashion way again this afternoon if I can recruit a pedal pusher.
  31. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    04-13-2012 09:14 AM #138
    I have some calipers laying around I think. Not sure if any of them are the style you need.
    I am willing to bet money you just need to spend a bit more time the "old fashioned way" jumping around the car bleeding to get the air out. I've had cars that took an hour or so of jumping around the brakes to finally get a remotely firm pedal.. Rad's car being one of them
  32. Member
    Feb 13th, 2011
    Colorado
    '92 Passat G60 Syncro, '81 Scirocco
    04-13-2012 10:05 AM #139
    When you get the brakes all bled and they hold the car, just have somebody stand on the brakes while you break the axle nut loose. That is if you hadn't found some other way already. Progress is looking good!
  33. 04-13-2012 12:08 PM #140
    Quote Originally Posted by crehner View Post
    Weirdly enough, that's my main motivation to get the brakes bled. I tried to brace the hub last night with a giant screwdriver through two lug bolts.
    The screwdriver sprung out and shot across the garage and now I have crooked screwdriver
