VWVortex.com - use only g12 coolant?
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 112
    Thread: use only g12 coolant?
    1. Junior Member 00vr6doyle's Avatar
      Jan 20th, 2011
      mass
      2008 passat 2.0tfsi
      02-24-2011 04:03 PM #1
      should i only run g12? if i dont have to im not trying to pay 28 bucks a gallon from my local vw dealership...if not what should i run?
    2. Junior Member
      Dec 21st, 2009
      97 jetta vr6 300100 miles
      02-24-2011 06:30 PM #2
      Use only g12 or g12 plus!!!!!!! Other coolants will cause pitting in your cylinder head. Buy from either ECS Tunibg or MJM Autohaus for much better prices than the stealership.
      97 jetta vr6 386,000 and no repairs to engine or tranny (original chains and tentioners). TOTALED by my brother 1/1/13
      00 jetta vr6 119,200 and no repairs yet. Both exclude reg maint. SOLD 5/1/11 for 02 allroad.
    3. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Rhode Island
      2001 Baltic Green Jetta GLX, 2003 W8 Passat Wagon 6speed, 1982 Mk1 Caddy ABA, 2008 4.2 A8
      02-25-2011 12:25 PM #3
      OMG yes there is a reason that they say use G12 only
      My car before i had it was runing conventional coolent for most of its life and bam at about 100k Anything that was related to coolent had to be replaced. The bitchies of them all being the Heater core, Unless you fancy ripping apart your whole dash to replace your heatercore run G12
    4. Member ricardo's Avatar
      Feb 19th, 1999
      CA Bay Area
      1995 mulberry GTi VR6 RIP, 1988 BMW E30 SETA, 2004 A4 B6
      02-26-2011 03:23 PM #4
      replacing your heater core is going to happen anyways regardless of what coolant you use...as long as there is no mixup of coolant (geling could occur) just get a compatible coolant
      "Public transportation......because you're poor"
      done everything that's cheap....broke the most expensive parts....
      having cooling problems? check this out http://the-corrado.net/forum/viewtopic.php?f=1&t=68720
    5. Member vr6pilot's Avatar
      Jul 5th, 2000
      ABQ
      2000 GTI, 2009 CC, 1969 Barracuda Slickback
      02-26-2011 08:30 PM #5
      only??? Bentley sez "G12 or equivalent". Page 19-11.
      Cheers, yo.
    6. Member
      Feb 11th, 2011
      Seattle, WA
      02-26-2011 10:36 PM #6
      it really doesn't matter. the reason they say "G12 only" is because, if you MIX it with other coolants it forms a nasty brown sludge. however, if you do a complete replacement (no g12 left at all, and flush it with pure water in between) then you can run whatever you want since it won't be mixing. that being said, i use only g12 and it can be found for $9 here: http://www.germanautoparts.com/Chemicals/Coolants/Hepu
    7. Member vr6pilot's Avatar
      Jul 5th, 2000
      ABQ
      02-26-2011 10:50 PM #7
      Quote Originally Posted by 206VR6 View Post
      Don't you mean $22.80 plus shipping? If you want a full gallon, that is, so we can talk apples to apples.
      You're right about not mixing but that has been well-established.
      Cheers, yo.
      Feb 11th, 2011
      Seattle, WA
      02-27-2011 12:15 AM #8
      Quote Originally Posted by vr6pilot View Post
      mm yeah good catch. i'll be honest its saturday night and im fairly drunk, i didnt really read the OP's post at all lol
    9. Member EuroSportChicago's Avatar
      Jun 8th, 2010
      Chicago
      GTI VR6 MK3
      02-27-2011 11:10 PM #9
      IF you don't wanna buy the G12 just buy a honda
      Quote Originally Posted by aphythiate View Post
      I don't understand what you said. I'm guessing you did a "dump'n'go" minus the go.
      Quote Originally Posted by RayMkIIIvdub View Post
      where are the muffler bearings and is that something i can change myself
    10. Member vr6pilot's Avatar
      Jul 5th, 2000
      ABQ
      02-27-2011 11:42 PM #10
      Or I could buy a mk3, yeh? Cheap as dirt since the resale value is practically non-existent and I can use the G11 that the brilliant German engineers came up with......and then abandoned. Thanks for your contribution.
      Cheers, yo.
    11. Member Bryan127's Avatar
      Oct 29th, 2004
      Latrobe
      '94 Golf, '98 GLX, '96 GTi VR6
      03-03-2011 11:36 AM #11
      You can regualr coolant as long as COMPLETELY flush out the system. I ran Prestone in my Jetta with regular flushes for 3 years with no problems...an no pitting of my cyl. head G12 is more corrosion resistant though...all depends on how often you want to flush/fill.
    12. Member vr6pilot's Avatar
      Jul 5th, 2000
      ABQ
      03-03-2011 12:16 PM #12
      Curious...do you mean you ran regular old school Prestone or the "Extended Life, All Makes ~ All Models" Prestone?
      note...they are both the same yellow/green color.
      Cheers, yo.
    13. Member Bryan127's Avatar
      Oct 29th, 2004
      Latrobe
      03-03-2011 12:22 PM #13
      just the standard Prestone...the cheapest they sell
    14. Junior Member
      Dec 21st, 2009
      03-03-2011 12:45 PM #14
      Google "vr6 head pitting" and you will find out why VW developed g12.
    15. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      03-03-2011 01:16 PM #15
      Lots of doomsday advice floats around here on VW/German fluids...... what, are VW heads made out of some uber-aluminum compound that no other manufacturer can get their hands on? VW seals are withered in days when used with non- German lubricants?
      Run whatever coolant you want, as long as you aren't mixing. That's when you get problems.
      Quote Originally Posted by jettavr681 View Post
      I see 5 (five) results mentioning pitting. Image search turns up nothing. VW developed G12 coolant for 5 people?
    16. Member EuroSportChicago's Avatar
      Jun 8th, 2010
      Chicago
      GTI VR6 MK3
      03-03-2011 05:26 PM #16
      Or we could just stick to what works best.
      Thanks for the contribution.
    17. Member vr6pilot's Avatar
      Jul 5th, 2000
      ABQ
      03-03-2011 08:29 PM #17
      You don't know if/why it works best. You continue to speak from the anus and contribute nil.
      You suggest that a VW is a high-end, premium automobile and should therefore receive only the most lavish care products money can buy. I, on the other hand, dispute such claim because your Mk3 values at $2,965 Kelley Blue Book value (excellent condition, VR6, Leather). Yeah, that's kinda dumb.
      Cheers, yo.
    18. Member Das Borgen's Avatar
      Sep 10th, 2008
      Columbus, OH
      1995 M3, 1999 740i "Short" Sport, 2000 Ducati 748
      03-04-2011 08:06 AM #18
      Quote Originally Posted by 00vr6doyle View Post
      what you're failing to recognize is that it's not that much more expensive than any other coolant you can get from autozone or whatnot.
      you pay that 28 bucks and you get 100% pure coolant. t 10-15bucks coolant from any auto parts place will be 50%coolant50%water mix. Addindg the fact that distilled water is around 80cents per gallon, you pay pretty much exactly the same price effectively
      What should be important to note is that G12 or G12+ is what VW specs because the stuff is low phosphate. Any non-phosphate coolant will work fine. phosphates do nasty stuff to aluminum components.
      FWIW, in my VR6, I ran BMW coolant because the dealer had that stuff at 21 bucks per gallon....100%pure coolant
      Quote Originally Posted by Das Borgen
      VR6s should sound like Chewbacca getting raped
      Dazzle Surprise - Team My Little Pony
    19. Member ricardo's Avatar
      Feb 19th, 1999
      CA Bay Area
      03-04-2011 01:22 PM #19
      yes VW found out that their G11 formula caused pitting so they change it to G12
    20. Member vr6pilot's Avatar
      Jul 5th, 2000
      ABQ
      03-04-2011 11:40 PM #20
      Quote Originally Posted by Das Borgen View Post
      Wrong. Prestone comes in your choice of premixed or straight. One gallon of straight is $10. Therefore, the distilled water factor is moot because you'll use the same amount and pay the same amount for it regardless of coolant used.
      I don't care how you slice it, the green stuff is cheaper by at least half and far more readily available than G12. Neither of which, by the way, are low-phosphate...they are no-phosphate. (referring to extended life Prestone).
      The truth will set you free.
      Cheers, yo.
    21. Member EuroSportChicago's Avatar
      Jun 8th, 2010
      Chicago
      GTI VR6 MK3
      03-05-2011 03:54 PM #21
      So If I buy a 70k BMW 7 series and 8 years later when the kbb is 5000, I should just stop taking care of it and put shi**y parts in it? that makes sense. If it required G12 when it came out in 1997, it requires it now as well.
      I don't know the chemistry and the reactions of the chemicals that are used in G12, which you probably do not know. I Do know that different chemicals are used in different types of coolants.
      Wrong chemicals = Bad
      Correct chemicals = Good
      That is why you put it in.
    22. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      68 chevelle, 98 GTI VR6 S/C, 00 hombre, 02 1.8t jetta wagon, Haro Mirra 540 Air
      03-05-2011 05:37 PM #22
      what caused this?
    23. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      03-05-2011 05:44 PM #23
      also...
      there is a VW technical bulletin (19-10-03) that goes over coolant, identifying and mixing. good bathroom material....
    24. Member vr6pilot's Avatar
      Jul 5th, 2000
      ABQ
      03-05-2011 09:42 PM #24
      [QUOTE=EuroSportChicago;70342375]If it required G12 when it came out in 1997, it requires it now as well.
      QUOTE]
      If it required G11 you still gonna run that?
      Bottom line is any OAT based coolant that is both phosphate and silicate free can be run in these engines. You just have to paint your face black and white and shake 3 chicken bones while dancing around a fire sprinkling nutmeg.
      Cheers, yo.
    25. Member EuroSportChicago's Avatar
      Jun 8th, 2010
      Chicago
      GTI VR6 MK3
      03-06-2011 03:32 AM #25
      [QUOTE=vr6pilot;70346501]
      Quote Originally Posted by EuroSportChicago View Post
      QUOTE]
      I just said that I don't know the exact reasons that make G11 G11 and G12 G12. I just know that your supposed to put the type of coolant in the car that the manufacturer specifies. If it ain't broke, don't fix it.
