I like those wheels!!!
#353
MK6 shifter arrived
Im going to wait and just mount the wheels on new tires, don't want to mount and then remount again in a month![]()
Official OG '08 .:R32 Owners Club Member
#354
I will be putting up my Modshack intake up for sale soon, waiting on my Forge intake to arrive. So anyone interested in it let me know![]()
#355
hmm nice shifter, so who was that guy in the classifieds you got it from again?![]()
#356
Sore shoulder and many curse words after... installed
#357
R32/939
#358
If your gas cap light comes on even if you think you tightened the cap, try pulling on the cap as you tighten it. Worked for me.
Help us with suspension specs!
Vag Evolution: MkI Rabbit -> MkII 16v GTI -> B5 S4/MkV .:R32
#359
#360
#361
That looks great![]()
#362
#365
you will love them, seriously. sticky.. fun.. rubber.
as for the shifter. mine is still in the batcave.
I think ( At least in my case ) its a much cheaper alternative than buying a new OEM MKV shifter surround.
#366
Yeah much cheaper, and I sure do like it more than stock. Just a heads up for when you install yours. I reused the stock plastic part from the stock shifter on the new shifter (the part the metal rod goes into). I noticed the stock one is much shorter, and I was having a hard time with longer part of the MKVI shifter.
#368
#370
Reversing camera...cool![]()
MKV R32, DPB, Manual, DieselGeeks Sigma6 Short Shifter, Neuspeed Induction Kit, Miltek Non-Res Exhaust, H&R Sway Bars.
SOON TO COME: 20th Ani HPA Turbo Kit!! - 390HP, 390 lb/ft!! Bring it on!
#371
Finally received and installed my Forge intake
Can't reach a stupid nut to remove the noise pipe
Anyone know what can be adjusted to move the intake a bit lower? its hitting my hood![]()
#372
You can pinch the clip to remove the tube running transversely across the engine bay at least.
As for hitting the hood, do you have the liner removed (if I remembered right you do as I see the modshack-esque trim piece)? I would adjust the way the hose connects at the throttle body...pull it towards the driver side some (don't be afraid to expose a little of the aluminum TB, the hose will still create a seal around the lip. This allows you to push down on the elbow portion of the intake and retighten the TB clamp when you get a little bit more clearance for the hood.
I didn't have this issue installing my intake but a few others seem to be seeing this "rubbing" right after install but quickly finding such adjustments to the alignment to fix this permanently.
#373
Yeah but there's still 2 nuts holding it against the firewall. I removed one and but the other I can't reach, doesn't help that I can't find my ratchet set too
Yup, no hood liner. I already tried to get a bit lower by lowering the air scoop down a bit. Thanks for the tip Beta, I will try and tinker with it some more![]()
#374
Oooo yeah. I just left the firewall portion and the short tube attached where it is for now. You need the block off kit from the A3 to block the hole once you do that...and I haven't gotten around to buying one.
If you still have issues, let me know. The silicon hoses allow for some adjustment...just be brave about it...doesn't have to sit perfectly flush, just need a good seal with the hose clamps.
#375
Pulled it out a bit from the top of the throttle body, managed to bring down the canister a few mm.
This is how its attached to the air scoop, If I make it sit flush it just sits up too high.
#376
Yeah. Looks about right. Everything seals up nicely still.
#377
#378
#379
Install begins!
My uncle helping me out with the cutting
Yeah, yeah I know...get those wheels on![]()
#380
What are we installing? Rear camera?
Sent from my HTC Vision using Tapatalk 2
#381
#382
Running all the wiring...fun
#383
#384
Holy Milltek.
Tarmacs cut it close.
Miami Vase
Cams A Make Her Dance
#385
Had to remove and re-run the coaxial cable, the connector was too big to pass through the rear passenger trim panel![]()
Almost done though![]()
