Page 17 of 25 FirstFirst ... 7 13 14 15 16 17 18 19 20 21 ... LastLast
Results 561 to 595 of 875
Thread: The ask a stupid question thread
  1. 04-12-2012 10:21 AM #561
    Quote Originally Posted by SoCalMK6GTI View Post
    Foot pushes brake pedal, which applies pressure through hydraulic lines from the master cylinder to the brake piston hence applying your brakes. Where does the booster fit into this? And why?
    The booster applies "boosts" the pressure that your foot gives without letting you feel it, making the effort to push all that fluid much easier. If you run without one, or are coasting with the car off, you will notice how freaking solid the pedal is and how much effort it takes to get any sort of braking power with just your limb.
    The booster effectively takes the throw of your foot on the pedal and adds a bunch of force behind it, so the pedal moves easily and you don't really feel the strain of having to push a few liters of fluid through tiny lines around the car.
    Think of it like a beer bong. If you just had a tube of beer and tried to drink it without using gravity (which is effectively a negative pressure sucking the beer into your gut from the bottom of the hose) you would be stuck drinking like you would out of a glass, but move it into a vertical plane and allow the pressure to do it's work, and you've got a beer in 2 seconds forcing it's way into your gut.
    Manual brakes = normal drinking beer, takes time
    Power Assisted Brakes = Beer Bong, instant beer
    Quote Originally Posted by TechEd View Post
    Long-story-short: Outie5000 is right on all accounts.
  2. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    SYDNEY, NEW SOUTH WALES, AUSTRALIA, OCEANIA, AKA UPSIDE-DOWN LAND
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    04-12-2012 11:15 AM #562
    Quote Originally Posted by Outie5000 View Post
    You should teach at a University.
    President @ ARD
  3. Junior Member theharleyquin's Avatar
    Mar 15th, 2011
    Orlando, FL
    '10 GTI DSG
    04-12-2012 11:20 AM #563
    So enter a stupid DSG question. So I understand that the diverter valve lets off the boost pressure when the throttle body is closed. But when you upshift in a DSG theoretically the throttle body is never closed (foot is always on the gas) but the gear changes. Is there any "venting" of boost pressure when a DSG upshifts? If there is, is this venting while upshifting the DSG Fart sound?
  4. 04-12-2012 12:56 PM #564
    Quote Originally Posted by Aonarch View Post
    I was trying to think of something that everyone would understand, and that was sadly the first thing that came to mind.
    I guess I could have compared it to a power steering pump vs manual rack...
  5. Member Env1ousVI's Avatar
    Dec 6th, 2011
    Irvine, CA
    2011 UG MK6 GTI
    04-12-2012 03:16 PM #565
    Quote Originally Posted by theharleyquin View Post
    I don't know if there is any venting when up shifting, I do know the farts are from the car shifting so fast it makes an air pocket and which results in the beautiful fart we all hear and love
  6. Member Wastegate13's Avatar
    May 3rd, 2006
    SoFl
    2011 VW GTI
    04-12-2012 03:21 PM #566
    For those of you who have done the OEM hid retrofit on a factory halogen car, what bulbs and ballasts are you using? I don't want to believe that everyone is using the expensive OEM parts after paying an arm and a leg for the lights themselves.
  7. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    04-12-2012 03:23 PM #567
    Pumps and racks??
  8. Member wasim12's Avatar
    Aug 6th, 2011
    Chatsworth, CA
    2011 MKVI DSG GTI
    04-12-2012 10:46 PM #568
    Why is that about 30 seconds after a cold start the rpm drops a little on the GTI, as if the engine has settled?
    And does this apply to TDIs/Golfs too?
    2011 DEEP BLACK 4DR DSG AUTOBAHN GTI
    Most chicks that drive Escapes have a rug that needs trimming.
    Check this site out for free stuff!
  9. Member SoCalMK6GTI's Avatar
    Apr 4th, 2010
    Rancho Cucamonga, CA
    2010 GTI 6MT DBM
    04-12-2012 11:45 PM #569
    Quote Originally Posted by wasim12 View Post
    Every car I've ever owned has done this.
  10. 04-13-2012 08:44 AM #570
    I just bought a new set of wheels and tires for my 2012 Golf. My question is, if the tires and wheels come with the old TPMS sensors installed (metal valve stems) will it screw anything up if I keep them on there even though the TPMS sensor for mine is in the wheel well and doesn't use the stem sensors? Also, since I am upgrading from the 15" steelies with 195 tires to a 17 inch wheel with 225 tires how much will my speedometer be off? Is there anyway I can change it myself without a VAG COM? I know about the option in the MFI for snow tires but I am looking for a way to permanently calibrate without having to bring it to a dealer. Thanks.
  11. 04-13-2012 10:14 AM #571
    Quote Originally Posted by Squirrel Nuts View Post
    Pumps and racks??
    Do not question my authrotah.
  12. 04-27-2012 05:14 PM #572
    I am coming from the world of a lifted jeep so bear with me, on my TJ I had to pull up pretty far and hard on my hand brake handle to get it to not roll when I parked it (always left in gear as well). On my new gti from my testing it seems 3 to 4 clicks is normal and it just takes a light pull. About what is normal for these cars? Thank you for any clarification you may be able to provide.
  13. 04-27-2012 05:18 PM #573
    Quote Originally Posted by 12VWGTI View Post
    Fresh from the factory, they come with the brake cable overtightened, to allow it to stretch with use over the first few months of ownership.
    It's normal for it to be real easy to keep it from going anywhere, but it's still a good idea to pull it up somewhat to hold it in place and give that cable the stretch it is intended to experience, otherwise you might end up with rear pads that drag and you'll go through a set every 10k.
  14. Member resilientsoma's Avatar
    May 31st, 2011
    NEPA
    11' GTI
    04-27-2012 05:52 PM #574
    What shocks should I get with my Neuspeed sport springs to achieve a nice and not so bumpy ride and have the same dropped ride height?
    GIAC | APR | AWE | Magnaflow | SouthBend | FK Automotive | Tyrol | Forge | OEM | 3SDM | ETC
    IG : resilientsoma
  15. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    04-28-2012 12:05 AM #575
    Asking this for a friend that just got a 2012 GTI. Will 18x9.5 wheels fit on the fronts?
    Quote Originally Posted by VincewagenR32 View Post
    Torque is a motherf***er
  16. Member SoCalMK6GTI's Avatar
    Apr 4th, 2010
    2010 GTI 6MT DBM
    04-28-2012 12:12 AM #576
    So I should be pulling harder? Rears are dragging.
  17. 04-28-2012 12:29 AM #577
    Quote Originally Posted by resilientsoma View Post
    what shocks does NS pair them with in the kit? Use those.
  18. 04-28-2012 12:30 AM #578
    Generally speaking, it's better to give it a nice firm tug to really put tension on the cable and hold the car. If you're on level ground, no worries, but if you're on a hill, it's smart. And as the cable stretches, you'll need to go higher and higher with the pull to keep it at a firm clamping force until it stretches to it's limit.
  19. Member SoCalMK6GTI's Avatar
    Apr 4th, 2010
    2010 GTI 6MT DBM
    04-28-2012 12:36 AM #579
    Thanks!
  20. Member Mr.Alex's Avatar
    May 27th, 2010
    New York
    CW MK6 | Guard Red 964
    04-28-2012 10:02 PM #580
  21. Member resilientsoma's Avatar
    May 31st, 2011
    NEPA
    11' GTI
    04-29-2012 10:31 PM #581
    what's a good way to plant the power to the ground and not slip all the time? and yes I have new tires.
    IG : resilientsoma
  22. 05-01-2012 12:21 PM #582
    I believe people have had good luck with the dogbone inserts and transmission mounts.
    It's really just a matter of having the proper amount of flex in your drivetrain (that includes suspension) to deal with it.
    But if you're slipping around in the middle of gears (other than 1-2 and not on wet pavement) then you should probably learn how to drive properly within the powerband.
    The throttle is not an on off switch.
  23. Member oviewankenobi's Avatar
    Nov 8th, 2009
    Baltimore
    '10 GTI DSG, '11 GTI 6MT
    05-02-2012 12:25 PM #583
    Anyone know where to pick up a lug cap removal tool.
    Not sure if you can use the factory one that comes with the car to get these off..
    Thanks!
  24. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-02-2012 12:26 PM #584
    Not sure what the factory one looks like on the new GTI's but it should work.
  25. Banned
    May 1st, 2012
    2012 GTI
    05-02-2012 12:32 PM #585
    To those people with mk6 golf/gti with the RNS-315 satnav and steering wheel control buttons, do your steering wheel radio control buttons work when the car is off to change station/track on the stereo? I ask because mine do not, which isn't that big a deal unless they're supposed to.
  26. Member oviewankenobi's Avatar
    Nov 8th, 2009
    Baltimore
    05-02-2012 12:40 PM #586
    The factory dust caps have the hole in the middle and the tool that comes with the GTI is the little coat hanger thing that you put inside and pull off. Since the above caps don't have a hole for the coat hanger, was wondering if there was a tweeter like tool to grab the cap? I didn't see anything on ECS.
  27. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-02-2012 12:47 PM #587
    I know the new Audi's have these tweezer type things. Check under there.
  28. Member oviewankenobi's Avatar
    Nov 8th, 2009
    Baltimore
    05-02-2012 02:11 PM #588
    FWIW, Found the tool and more importantly the part #..
    8D0012244A
  29. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-02-2012 02:14 PM #589
    Quote Originally Posted by oviewankenobi View Post
    8D0012244A
  30. Member DasMkVI's Avatar
    Apr 10th, 2012
    Redding, CA
    2012 GTI 4-Door DSG / 2002 Jetta 1.8T
    05-02-2012 02:23 PM #590
    If I had to guess I would say that is the run time of your secondary air injection system and there may be a larger electrical load on the system while that pump is running. Once it shuts off, the car like you said, "settles down".
  31. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-02-2012 02:31 PM #591
    I always wait for the RPM's to drop after a cold start. Necessary?
  32. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    05-02-2012 02:32 PM #592
    Yes that is the motor building oil pressure.
    However, when it is 90F I wait only a few seconds and then drive softly till it is up to temp.
    President @ ARD
  33. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    05-02-2012 02:43 PM #593
    I wait either way.
  34. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    05-02-2012 02:45 PM #594
    Quote Originally Posted by Der_Igel View Post
    I've got RCD-510 with the MFSW and nothing works on the steering wheel when the car is off.
    2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
    2007 CW Rabbit 6AT 2DR - Bone stock
  35. Banned
    May 1st, 2012
    2012 GTI
    05-02-2012 03:22 PM #595
    Quote Originally Posted by sfpegasus View Post
    Thanks! You've put my mind at ease.
