Page 2 of 25 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 875
Thread: The ask a stupid question thread
  1. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    02-25-2011 02:44 PM #36
    Quote Originally Posted by alexkball View Post
    Everyone (it seems) on Vortex talks about lowering, dropping, bagging, etc. etc. etc. in an attempt to get nice and cozy with the ground.
    My stupid question is a two-parter:
    1. Has anyone ever attempted to lift their golf/gti, etc. Esp. an MKVI?
    2. Would I be allowed back to Vortex if I did such a thing?
    The question has been asked. I think there is a lift kit for the MKV/MKVI but I can't be sure.
    ECSTUNING | GO APR
  2. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    02-25-2011 02:51 PM #37
    Ok, I can finally use this stupid question thread. What happens if I install this Euroswitch instead of the other one everyone seems to use?? I know the difference is it has the coming home feature but I also notice the auto setting. Does this mean I can switch the DRL's on and off without having to use VAGCOM (they are currently disabled in anticipation of this purchase)? Thanks!
    http://www.ecstuning.com/Volkswagen-...tch/ES1897090/
  3. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    02-25-2011 02:51 PM #38
    Quote Originally Posted by Aonarch View Post
    I think (hope) he was joking.
  4. Member evosky's Avatar
    Feb 13th, 2010
    noVA / DE
    a van
    02-25-2011 03:01 PM #39
    actually i'd imagine it would be of interest to handicapped folks who need wheelchairs
    Apr 9th, 2007
    DC
    Too many to list here
    02-25-2011 03:08 PM #40
    Quote Originally Posted by oneethree View Post
    No, the coming home feature is run through the cecm, not through the switch. The "auto" switch does nothing on that switch. It will act just like a normal euro switch when clicked.
    Follow my MK1 build on Instagram. User name: jkrew or http://ink361.com/#/users/322773/photos
  6. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    02-25-2011 03:11 PM #41
    Quote Originally Posted by Joey Russo View Post
    Okay, and has anyone ACTUALLY found some good LED's for the city lights that won't throw codes and match the stock Bi-Xenons?? I'm told these are the ones but the guy who has em has a TDI so it may be it didn't throw a code for that model but it will for a GTI. I have these same LED's inside in red.
    http://www.ledwholesalers.com/store/...&productId=337
  7. Junior Member
    Apr 24th, 2010
    Boston, MA
    2010 GOLF 2.5L
    02-27-2011 08:53 PM #42
    nice thread OP
    does gti real valance fit 2.5 golf, i seen a couple of you did a retrofit on the TDIs so im assuming its the same?
  8. Member whitepepper's Avatar
    Feb 10th, 2009
    TEXair
    switch hitter
    02-27-2011 08:55 PM #43
    Quote Originally Posted by Yugoslavia1988 View Post
    nice thread OP
    same
    DorbritzDesigns | DBC | BagRiders
    Quote Originally Posted by LowerThanZimmy View Post
    Texas itself seems to have it all taken care from what i see.....lol
  9. Junior Member
    Apr 24th, 2010
    Boston, MA
    2010 GOLF 2.5L
    02-27-2011 08:57 PM #44
    Quote Originally Posted by whitepepper View Post
    same
  10. Member Feyd's Avatar
    Apr 1st, 2002
    Chicago
    1997 Golf GL, 2005.5 Jetta V, 2003 BMW Z4 (RIP), 2008 BMW 135i, 2011 Golf TDI, 2012 Touareg TDI
    02-28-2011 09:47 AM #45
    I know for the mk3/mk4 there was actually a body-lift kit that was available. For the Mk6 the ONLY thing I've seen is a spring kit (I think made by H&R). Essentially the same length springs, but they are stiffer (so they don't droop as much) and only give something like a .5" lift.
    Give it time.. someone will do it. The car is just too new right now.
  11. Member
    Jan 23rd, 2011
    Ohio
    2011 GTI w/Sunroof - Carbon Steel Gray
    02-28-2011 10:09 AM #46
    Here's my stupid question:
    If I get 17" wheels instead of the stock 18" wheels do I have to worry about recalibrating the speedometer or anything?
    (You said this was for STUPID questions and I'm pretty sure that qualifies. Sorry!)
  12. Member Feyd's Avatar
    Apr 1st, 2002
    Chicago
    02-28-2011 10:11 AM #47
    No.... if your new car comes with 17" there is no need to recalibrate. If you are talking about getting some track/winter wheels tires, as long as you stay with the recommended sizes (IE not too tall/too short of a sidewall) you should be fine.
    On my MFI there is an option for snow tires where I can increase/decrease the speeds shown on the spedo to accomodate for slightly taller or shorter tires.
  13. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    02-28-2011 10:11 AM #48
    Quote Originally Posted by LAnderson View Post
    You'll be fine.
  14. Member
    Jan 23rd, 2011
    Ohio
    02-28-2011 10:19 AM #49
    Quote Originally Posted by Feyd View Post
    No, it came with 18"s. For next winter I think I will buy 17"'s.
  15. 02-28-2011 10:23 AM #50
    WRONG
    The only thing that setting does is give you a chime warning when you reach the speed you set it at.
  16. Member Feyd's Avatar
    Apr 1st, 2002
    Chicago
    02-28-2011 12:22 PM #51
    Really? That's lame....
    Honestly I just got my car and haven't messed with it other than scroll through the menu, but alludes that you can adjust the speedo.
    I stand corrected.
    Well since the MFI thing won't work, as mentioned stick to a tire size that's in proportion and you'll be cool.
    If you really want to get technical, you can check this out. http://www.miata.net/garage/tirecalc.html
  17. Member ThreadBomber's Avatar
    Feb 4th, 2007
    Vancouver
    2011 GTI 2dr 6M
    02-28-2011 12:32 PM #52
    If you use either a 225/45R17, or 205/50R17, you will have no problems.
    Teefy Buna
    Quote Originally Posted by Sump View Post
    I'm sure a lot of these guys went home after the carwash and played a little hans solo.
  18. Member
    Apr 9th, 2007
    DC
    02-28-2011 12:56 PM #53
    Shouldn't be an issue... TDI and a GTI are the same in terms of electronics. I recently bought a set off of ebay and they threw codes on my TDI with HID's so I will try these out and report back
  19. Member KeithVH's Avatar
    Mar 25th, 1999
    Wisconsin
    '11 Golf, '03 Legacy SE, '01 Diahatsu Hijet, '08 NB. Mk1, 2 and 3 Golfs now gone.
    02-28-2011 01:57 PM #54
    Quote Originally Posted by RedRabidRabbit View Post
    ...and since skinnier is better for a snow tire, stick to the 205/50R17
    Good thread. Everyone play nice.
  20. Junior Member Stagger-Lee's Avatar
    Dec 8th, 2010
    Tangletown
    02-28-2011 09:06 PM #55
    trying to remove the valve stems on my flat fives but they keep spinning on me. any tips on how to get them out?
    KvLT
  21. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    02-28-2011 09:17 PM #56
    Quote Originally Posted by KeithVH View Post
    Everyone play nice.
    Don't we always?
  22. Member Smrtypants44's Avatar
    Jul 30th, 2010
    Norman, OK
    2010 UG 2Dr GTI "Gus"
    02-28-2011 09:40 PM #57
    Quote Originally Posted by jettaguy88 View Post
    WRONG
    Isnt that the speed warning? In my MFI the snow tires option has +/- and then numbers which correspond to percentages not mph.
  23. Member acdelco's Avatar
    Nov 2nd, 2006
    GB WI
    10' GTI, 03' GTI 24v VR6, 82' soft top Rabbit
    02-28-2011 09:59 PM #58
    this is the perfect thread for a guy with no suspension experience.
    will it be too un-sightly to slap a set of spacers on the GTI before I drop?
  24. 02-28-2011 10:24 PM #59
    Quote Originally Posted by Smrtypants44 View Post
  25. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    02-28-2011 10:38 PM #60
    Quote Originally Posted by acdelco View Post
    What wheels are you running?
  26. Member acdelco's Avatar
    Nov 2nd, 2006
    GB WI
    02-28-2011 10:52 PM #61
    Stock Denvers for now, but will be upgrading to something 18" OEM in the next month or so.
  27. Member ThreadBomber's Avatar
    Feb 4th, 2007
    Vancouver
    2011 GTI 2dr 6M
    03-01-2011 01:14 AM #62
    Quote Originally Posted by Stagger-Lee View Post
    Are they rubber?
    Easiest way is to cut the bottom part off where it meets the wheel and then pull it out the front.
    Teefy Buna
  28. Member robkore's Avatar
    Dec 26th, 2004
    Houston, TX
    2011 GTI
    03-10-2011 11:47 AM #63
    Here's a stupid question for you guys: Is it possible to put a steering wheel with paddle shifters on a manual transmission car and wire or vagcom the shifters to do anything else, like cruise control speed incrementing or basic stereo controls like volume? Remember, no flaming, this is the stupid question thread!
  29. Member
    Apr 9th, 2007
    DC
    03-10-2011 12:25 PM #64
    sure. But it wouldn't be through vagcom. It's basic electronics. The paddles perform a function via a switch (I'm generalizing here), as do your volume controls on the steering wheel.
    It's gonna be a pain in the ass though hahaha
  30. Member Pete W.'s Avatar
    Feb 13th, 2005
    Festus, MO
    2010 2.5 2 door Golf
    03-10-2011 12:46 PM #65
    I this thread
    Is it possible to post a question on the tex without getting flamed for not searching first?
  31. Member robkore's Avatar
    Dec 26th, 2004
    Houston, TX
    2011 GTI
    03-10-2011 12:53 PM #66
    Quote Originally Posted by Pete W. View Post
    I this thread
    Ugh, try searching, I'm sure that's been answered! (I'd put some sort of smiley face here to show my sarcastic intent, but emoticons make me angry.)
  32. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    03-10-2011 01:03 PM #67
    Quote Originally Posted by robkore View Post
  33. Member robkore's Avatar
    Dec 26th, 2004
    Houston, TX
    2011 GTI
    03-10-2011 01:18 PM #68
    I just had a seizure, I hope you're happy!
  34. Banned .panda.'s Avatar
    Dec 7th, 2007
    Queens, NY
    2011 CW GTI 4-Dr
    03-10-2011 01:19 PM #69
    amateur....
  35. Member boobert's Avatar
    Aug 10th, 2001
    Long Island
    2011 CSG GTI, 2012 Pilot
    03-10-2011 01:47 PM #70
    How does the mkvi horn compare to the mkiv horn?
    I like the horn in my mkiv. Makes the car sound bigger than it is. I forgot to try
    the horn on my test drive :-/
