VWVortex.com - oil leaking into turbo(mk4 jetta 1.8t)
    Results 1 to 4 of 4
    Thread: oil leaking into turbo(mk4 jetta 1.8t)
    1. Junior Member
      Sep 5th, 2008
      NJ
      e30 M20/mk4 1.8t
      02-27-2011 03:44 AM #1
      Ugh!! I got my engine last week the mechanic installed it he calls me and says engine run great but turbo is leaking oil. Now i did a little research on the rebuild kit will this turbo rebuild kit from G pop shop.com stop this oil leak im having with turbo? let me as soon as possible on what i should do so i could get this jetta moving thanks.
      Jan 4th, 2007
      MA
      2004 Jetta GLS 1.8T
      02-28-2011 01:23 PM #2
      try to replace your Pressure regulator valve first before you assume it's the turbo.
      Quote Originally Posted by euro e30s View Post
    3. Member jeffs789's Avatar
      May 22nd, 2007
      Canton, CT
      2015 GTi Pure White
      02-28-2011 07:23 PM #3
      its probably the pcv system. I have the same thing and it think my pcv system is clogged or the pcv valve is gone
    4. Junior Member
      Sep 5th, 2008
      NJ
      e30 M20/mk4 1.8t
      03-01-2011 02:19 AM #4
      Okay I'll take a look at them tomorrow and let u know what happens.
