VWVortex.com - Disconnected the battery and now the antislip light is on....help!
    Results 1 to 12 of 12
    Thread: Disconnected the battery and now the antislip light is on....help!
    1. Member JetProfet's Avatar
      Feb 3rd, 2011
      New York, NY
      2015 Audi A3 2.0 (Current), 2009 VW GTI (Current), 2010 VW Jetta 2.5 (Sold), 1999 VW Passat (Gifted)
      02-27-2011 07:44 PM #1
      Hey guys,
      So I disconnected the negative terminal on my car battery because I had to install my new Hella LED tails. The install was fine, but now my dash shoes the antislip light. The install isn't quite complete on the lights since I'm having someone fix the coding in VAG Com tomorrow. The antislip was working 100% fine before I disconnected the battery. Is this common when the battery is disconnected? Does the antislip have to be fixed in VAG Com too? Any suggestions guys?
    2. 02-27-2011 07:46 PM #2
      Have you tried driving around for a while because when i disconnected mine it stayed on for a little bit then it turned off by its self
    3. Member Turbo Turkey's Avatar
      Sep 7th, 2009
      Rockville MD
      02-27-2011 07:49 PM #3
      Drive your car forward and turn the wheel lock to lock while driving, then drive in a straight line under 25mph. That sets basic settings for the steering angle sensor and you should be good
    4. Member JetProfet's Avatar
      Feb 3rd, 2011
      New York, NY
      02-27-2011 07:53 PM #4
      Thanks guys. I appreciate the quick responses. I'll try that first thing tomorrow.
    5. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      1k-m-cbta-02q-PTE5858
      02-27-2011 08:03 PM #5
      dude, anytime you disconect the battery, you have to re adapt the auto windows and some other basic functions.
    6. 09-10-2011 10:10 PM #6
      Quote Originally Posted by Turbo Turkey View Post
      I tried to do like this in a big parking lot. but the anti-slip light is still on.
      Turn to the end of left and the end of right, drive forward for a while. right?
      Also try to hit the ARS button but it doesn't let me switch off. any idea?
    7. Member rocketdub144's Avatar
      Oct 14th, 2010
      NNJ
      06 GLI
      09-11-2011 12:51 AM #7
      Quote Originally Posted by thygreyt View Post
      same happened with me. automatic windows worked after a few hours and the esp light finally turned off after a few minutes.
      Instagram: @subdubbin
    8. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      09-11-2011 03:11 AM #8
      ppl, just drive it.
    9. Member $$Rich$$'s Avatar
      Oct 14th, 2005
      Sioux Falls SD
      12 GTi Autobahn, 06 A3 3.2 s-line
      09-11-2011 12:55 PM #9
      ppl, just drive it.
    10. Member Turkeywrap's Avatar
      Jun 26th, 2011
      SFL.
      Bagged|Jetta
      09-12-2011 10:55 PM #10
      I disconnected my battery yesterday and now my dash lights won't turn on, but my CEL went away
    11. Member bryangb's Avatar
      Jun 16th, 2010
      Hanover, PA
      '08 GTI, '15 Golf TDI, '14 Ram Cummins
      09-12-2011 11:55 PM #11
      Quote Originally Posted by Turkeywrap View Post
      Disconnecting the battery resets the ECU which will get rid of a CEL. It will come back
      Instagram: @bryangb
      bags and wheels = build thread
    12. Member Turbo Turkey's Avatar
      Sep 7th, 2009
      Rockville MD
      09-14-2011 10:39 PM #12
      Quote Originally Posted by rockbirdcth View Post
      What faults are you getting?
