Results 1 to 26 of 26
Thread: New Motor, Rebuilt, No oil Pressure. Help
  1. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    03-03-2011 12:10 AM #1
    okay, so i may just be paranoid but I was trying to prime my oil system after my rebuild. So disconnected the ignition coils, the injectors and took out the fuel pump fuse.
    Now it cranks over nice but about 15 cranks in i get the Oil pressure light... Take the oil feed line off of the turbo, bone dry. Any ideas?
    Also new oil pump and down tube deal.
    Car in question
    "Hey you get off my cloud, See me get raw with my southpaw style" 3o1 KIDS Gonzo Tuning and EVAC
    57 trim garrett, hardparker, polished, garage slut, on Raderwerks.
    My Never Ending Build
  2. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    03-03-2011 10:20 AM #2
    Kind of messy/sloppy but take the oil filter off and have someone crank the engine over. If oil is coming through the oil filter housing then remove the oil filter housing (held in by (4) M7 bolts - will need 10mm socket) and change the check valve. (oil feed for turbocharger comes from filtered side of oil filter).
    If oil does NOT come through then pull the oil pan and see if the oil pump gear on the crankshaft is just spinning. I have yet to see a failed 1.8T oil pump but there is a first time for everything.
    Of course check and see if an the oil pump pick up tube is not clogged.
    Let us know
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  3. Member Blackfin's Avatar
    Mar 9th, 2006
    Ontario
    2002 GTI 1.8T, 2002 Mustang GT (Kenne Bell S/C)
    03-03-2011 10:55 AM #3
    Did you "prime" the pump before installation?
    Gerotor pumps can be tricky to get going if they are "dry". It's common to pack them with petroleum jelly to act as a priming agent.
    Can you back-feed oil through the oil filter outlet to try to get some into the pump itself?
  4. 03-03-2011 10:58 AM #4
    Not much can be wrong here. When i did my rod install i didnt pre-lube the pump and everything worked out. I checked to make sure oil was coming out of the oil feed line first, did the pre-crank steps and it fired right up. You may have forgotten to tighten the oil pump gear or something. Its all mechanical.
  5. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    03-03-2011 11:58 AM #5
    Quote Originally Posted by Blackfin View Post
    Not necessary on a 1.8T.
    Email | Facebook
  6. Member Blackfin's Avatar
    Mar 9th, 2006
    Ontario
    03-03-2011 12:35 PM #6
    Quote Originally Posted by INA View Post
    :shrug: It's a gerotor pump and if they are dry, they may not properly self-prime.
    This guy:
    http://www.passatworld.com/forums/sh...d.php?t=232743
    mentions priming the pump before installation.
    Let's put it this way: Priming a gerotor pump before installation is not a [u]bad[/i] idea, even if the majority self-prime just fine. It certainly can't hurt anything at any rate...
  7. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    03-03-2011 01:50 PM #7
    Well I know for a fact that the gear is on there and tightened.
    The pump was no primed, i was thinking if i hiccuped the oil filter it might be a good idea but wasn't sure.
    I had taken the oil filter housing off to be cleaned as well as the oil cooler is brand new. so everything is BONE dry.
  8. Member veedub-less's Avatar
    Dec 17th, 2007
    Monroe Township, NJ
    2003 GTI 1.8t
    03-03-2011 01:52 PM #8
    This guy:
    yes but the pump is in the oil pan. the path for the oil to travel to get to the pump is so minimal and so quick that is shouldn't have any issue picking up the oil.
  9. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    03-03-2011 02:00 PM #9
    may be a bit of a dumb question, but I bought an oil pressure gauge for this, should i be getting a reading during crank? if so about where should it be.
    On idle what should it be at? Sai/everything deleted.
    While moving what should my oil pressure be. I'll attempt to search these now but since I've got some guru's in here, figured some of you might know off the top of your head.
  10. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    03-03-2011 02:20 PM #10
    This guy:
    I am saying there is no need for it. Unlike other makes /manufactuers...the 06A/06B oil pump is actually submerged a fair portion (assuming you have left your engine sitting for a while) into the oil in the oil pan. The ratio of gear pressure : engine cranking is almost minimal so a few cranks and pressure would have allready been limited @ the pump.
    Email | Facebook
  11. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    337 PTE5857 DBB, Volvo C70
    03-03-2011 04:16 PM #11
    Quote Originally Posted by LouieTHEkid View Post
    you're not going to get a reading until it starts.
    i would check the gear.
  12. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    03-05-2011 12:59 PM #12
    Ended up burping the oil filter and everythings fine thanks guys!
  13. Member lrgskate's Avatar
    Mar 9th, 2009
    Canada, eh
    That's so Raven Diesel
    03-06-2011 10:28 PM #13
    Let us know
  14. Member Pg-Getta1.8's Avatar
    Jun 27th, 2006
    Long Island
    2003 Getta 20v
    03-06-2011 10:41 PM #14
    Listen to this then.... I broke my oil pan, and went to change it. when i pulled the pan off i found the oil pump chain tensionor and 2 teeth to the oil pump drive gear in the pan. Found the caused to be a seized oil pump 110k
    2003 Jetta 20v big turbo, FFE mini me turbo kit w/ Precision 5557 Ceramic Ball Bearing Turbo, tile WG, UNI 630 file with 630 injectors, walbro inline fuel pump, Precision 650 front mount w/ 2.5in alum. Piping, Wisco pistons (9:1), AEB head, IE rods, o2m Trans, South Bend stg 3 endurance clutch kit, deleted AC, SAI, PS... Semi tucked wiring harness. More to come
  15. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    03-07-2011 10:25 PM #15
    pretty big fail in this picture broski.... lower left hand side of the picture... under the frame rail.... yea... you know it
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
  16. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    03-07-2011 11:09 PM #16
    I've had my car jacked up on the frame rail many times over the past 7 months. Care to explain why this is a fail? Seeing as it has not failed once
    and if you are refering to the widow maker, its not a vw brand one. so it actually can support a big more weight
  17. Banned
    Feb 15th, 2010
    '03 1.8T Jetta
    03-07-2011 11:30 PM #17
    Widow-Maker in da Hizzouse!!!!!!
  18. Member Pg-Getta1.8's Avatar
    Jun 27th, 2006
    Long Island
    2003 Getta 20v
    03-07-2011 11:42 PM #18
    Quote Originally Posted by Powdered Toast Man View Post
  19. 03-07-2011 11:45 PM #19
    the jack you used for the frame rail is very dangerous and is called the widow maker because it kills people.
  20. Member waabaah's Avatar
    Jun 24th, 2006
    Fairbanks, Alaska
    04 .:R32; 20th a.e.;87 rattled black Toyo;94 AWD caravan;97 Gti Vr6T;82 924 porsche
    03-08-2011 12:58 AM #20
    widow maker, nice! good thing he has more support then that.
    car wont get oil pressure until it starts. you mention you only crank it 15 times. did the engine ever start once you put your fuses back in?
    get the car running for a short period and see if that helps. really not much can go wrong for no oil after a build like that.
  21. Member ALLGORIMSHOW's Avatar
    Jul 1st, 2002
    Kawarthas
    03-08-2011 02:31 AM #21
    Quote Originally Posted by Dub-Nub View Post
    No, ignorance and lack of common sense is what kills people, not the jack... Scissor jacks work great for lowered cars, it lifts them up enough to get a larger jack under. They also work great when you get a flat tire and I'm guess thats why VW puts them in the trunk/hatch along with a reinforced lift point on the frame rail. I'm not picking on your post, just sayin.
    FUITCK
    Quote Originally Posted by DAN16VG60 View Post
    Give. Me youre phone number. Him from. Montréal. Daniel. Hi havé question
  22. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    03-08-2011 01:56 PM #22
    Well if you look closely people who contributed nothing, it's actually not even under the car in this picture. Look closer. its held up by the SUV jack under the front of the car.
    I've done this much work, and as stated, its not the vw jack
    Scissor jack, yes. Piece of ****? Not so much.
    Car runs fine now. Oil pressure is great. Burped the oil filter and since then only had some minor problems to sort out. Appears as though my crank seal is leaking
  23. Member Pg-Getta1.8's Avatar
    Jun 27th, 2006
    Long Island
    2003 Getta 20v
    03-08-2011 03:53 PM #23
    Quote Originally Posted by ALLGORIMSHOW View Post
    i used the widow maker onece on my slammed jetta, the car broke it before i could get it off the ground. Went to sears and got a 2ton floor jack in a travel case for 50$ (on sale). I keep that in my trunk now. But if u ever jacked up a car, and had the front and rear tire off, this is becasue the unibody. The weight is to much for that little pos
  24. Member Pg-Getta1.8's Avatar
    Jun 27th, 2006
    Long Island
    2003 Getta 20v
    03-08-2011 03:54 PM #24
    glad to hear its good.
  25. Member LouieTHEkid's Avatar
    Jan 27th, 2007
    3o1 kid
    01 GTI 1.8 57trim
    03-08-2011 04:03 PM #25
    Quote Originally Posted by Pg-Getta1.8 View Post
    My jack needs about an extra 3/8" clearance to fit under the pinch welds. It's more than safe to use a smaller jack especially if the wheels never leave the ground. I'm unable to push the car up on wood blocks because well, I'm not the hulk
    Thanks, now just to sort out the oil leak
  26. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    03-09-2011 11:43 AM #26
    http://www.harborfreight.com/rapid-p...ack-92782.html
    all you need homes...
    just sayin...
    Good deal on getting car running though. Bummer on crank seal
