Page 1 of 19 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 636
Thread: Audi tt bt build almost done I guess?
  1. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    03-03-2011 09:28 AM #1
    Well after going from a ko3 to ko4 to gt2871r Elim my gt3076r build is almost done all work is done by alex at went worth motorsports in Brewster ma.lots of pics inside. New update to the parts list
    (Engine)
    Je pistons 83mm coated 8.5.1
    Integrated rods 20mm.
    Ie 83mm head gasket
    Acl coated rod bearings.
    Acl coated main bearings
    Southbend stage 5 clutch single mass flywheel
    Arp Turbo and manifold studs
    Arp rod bolts
    Arp cam bolt
    Arp head bolts
    Diesel geek sigma 6
    Billet dipstick and funnel(wanabe)
    Jrm billet heater core fittings
    Jrm billet thermostat housing
    Jrm billet coolant flange
    Gates racing blue belt
    R8 oil cap
    new radiator
    New alternator 90 amp
    Ie billet light weight alternator pully
    New oil pump
    New water pump metal impeller
    Fluidamper
    Garrett Gt3076r 63ar with polished housing
    Snail turbo billet wheel
    Kinetic top mount manifold
    Turbo blanket eBay
    Tial 38mm waste gate
    Mad max dv
    Turbo smart mbc
    Vibrant fmic custom ss pipes
    Front mount oil cooler
    Braile battery 11.5 lbs
    034 coil pack ss heat shield
    034 ls1 coil pack conversion
    034 transition spacer
    Vibrant catch can
    Apr in take fuel pump and a walbro inline
    C2 motor sports fuel pump kit
    Nitrous fmic spay and purge
    2 14" mishimoto fans
    Low temp thermostat
    Low temp fan switch
    Mishimoto rad hoses
    ATP ful rail with gauge
    Ie fpr adaptor
    Sai block of plate
    Inconel exhaust valves
    Supertech intake valves
    Supertech Titanium retainers
    Supertech springs
    Aeb head
    Integrated crank dowel pin kit
    Cat cam gear
    Abd manifod runners welded to excessive plenum
    Unitronics wide band 830cc file sai delete and maf delete vvt delete
    Race line wide band harness
    Hemi throttle body 80mm
    Vf mounts
    Solid dog bone mount
    Madmax direct port meth
    Snow stage 3 water meth. And fail safe
    3"turbo back no cat no muffler with ss vibrant tips
    Power steering delete
    AC delete
    (Interior)
    Corbeau forza seats black
    Corbeau five point harness silver
    corbeau harness pads
    Rear seat delete custom made
    Stable engineering harness bar
    shift light
    Euro lower dash lighter with pockets
    Momo steering wheel
    Ash tray romoved for nitrous panel
    Generic boost af ratio gauge in pillar pod will be changing the gauges
    Wot box in the column with USB in fuse panel
    Nitrous bottle in trunk painted to match silver
    Snow performance Meth display under ashtray
    OEM seat belts removed
    CD changer removed
    spare and tools removed
    Radio and speakers removed
    (Suspension)
    034 solid sub frame mounts
    034 density pillow mounts
    Gtt aluminum upper strut brace
    H&r rear adjustable sway bar
    ta technix coilovers rear adjusters out and upper perch removed
    Euro sport lower tie bar
    Black forest rear control arms (bottom
    Cpt rear control arms (top)
    Blue Haldex
    42 draft 30mm front 20mm rear adaptors 5×100 to 5×130
    Wheels Porsche 997 8.5" front 9.5" rear they might be reps
    Brakes Porsche boxer front paint black tt stickers
    Hawk hps pads front
    Pbr rear pads stock rear caliper
    All braided ss lines
    Cross drilled sloted rotors
  2. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-03-2011 09:32 AM #2
    Block striped and painted black
    Je pistons pretty lol
  3. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-03-2011 10:09 AM #3
    And got to throw in a pic before I droped here off
    Before you say anything it wasn't lowered yet now it's on h&r springs and this was at waterfest 2009
    This was at seekonk speed way where they do dust of
  4. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-03-2011 10:13 AM #4
    Still waiting to pull the old motor to swap some parts over and I need to order a clutch just don't know what one
  5. Member PLAYED TT's Avatar
    Oct 17th, 2010
    Reading, PA/ Williamsport, PA
    A German thing, and a not so German thing
    03-03-2011 02:30 PM #5
    Slammed Radio Flyer---flickr---My Build Thread 99% of you are idiots therefore I hate you
    Quote Originally Posted by Marcus_Aurelius View Post
    How much lower can you go when you're already scraping stuff??? Soon you'll have the first subterranean vehicle if you keep chasing that goal
  6. Member
    Nov 24th, 2005
    Ottawa
    2001 225 TTCQ
    03-03-2011 04:06 PM #6
    lot of money invested!!!
    damn that'll be day & night with your previous setup.
    Wish I could do that, but think I'll try to get more out of tha ol elim!!!
    BTW let me know for your eliminator!!!
  7. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-03-2011 05:00 PM #7
    i will let u know just cant wait for it to be done
  8. 03-03-2011 08:42 PM #8
    Defenitly suscribe !! This is what i call a great buildup! Can't wait to see the Dyno graph with this Unitronic BT files -
    JeF
  9. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-04-2011 01:32 AM #9
    Thanks Jeff can't wait to get the ecu and your wide band conversion harness that u sent out thanks for helping me pic out what software to run
  10. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-04-2011 02:02 PM #10
    Quote Originally Posted by 01ttgt28 View Post
    got this today
  11. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-04-2011 02:09 PM #11
    some free stuff
  12. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-04-2011 02:10 PM #12
  13. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    03-04-2011 02:24 PM #13
    Best of luck with it!
    bagsarefordeadhookers
    -TCC
  14. 03-08-2011 06:24 PM #14
    DO WANT
  15. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-08-2011 09:20 PM #15
    Quote Originally Posted by Vdub 2.0 View Post
    DO WANT
    Me to it's been a while since I've been 160mph on the highway
  16. Member notoriouszig's Avatar
    Jun 14th, 2010
    Scranton, PA
    2002 Audi TT 225QC
    03-08-2011 09:28 PM #16
    i only ever hit 151 in the tt.... i need to get on your level. keep it up
    You don't own a TT, you support it.
  17. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-17-2011 12:05 AM #17
    Just got the 830 delphi injectors today thanks to condo on vortex
  18. 03-17-2011 07:40 AM #18
    Well you getting there Richard
    Good built !!
  19. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    03-24-2011 08:48 PM #19
    Another part today just got to cut it to fit a 4" intake thanks holytt
  20. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    04-24-2011 10:00 AM #20
    Happy Easter everyone sorry no new progress
  21. Member
    Jun 14th, 2010
    San Diego, CA
    2000 TT 180Q
    04-24-2011 04:24 PM #21
    Enjoy your Sunday! In this case, patience makes perfect. You'll get there, you've made great progress so far!
  22. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    08-26-2011 10:00 AM #22
    Finally some new picsgot the motor out
    And the old motor blown head gasket I'm getting closer south bend stage 5 clutch came in also just have to do all the deletes and delete powersteering
  23. Member PLAYED TT's Avatar
    Oct 17th, 2010
    08-26-2011 10:19 AM #23
    Delete the power steering? Why not just relocate it?
  24. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    08-26-2011 12:31 PM #24
    TRYING TO LOSE SOME WEIGHT PLUSE THE RACK IS LEAKING,I ALLREADY DID AC DELETE REAR SEATS ASHTRAY CD CHANGER ALL HEAT SHEILDS UNDERNETH .RACING STEERING WHEEL RACING SEATS CARBONFIBER BATTERY SPARE TIRE AND TOOLS SO I WAS GOING TO DELETE EVAP SAI POWERSTEERING ANYTHING ELSE I SHOULD DO
  25. Member PLAYED TT's Avatar
    Oct 17th, 2010
    08-26-2011 12:38 PM #25
    Oh ok. I get it now.
  26. Member
    Apr 25th, 2005
    Beaverton, OR
    01 Audi TT Coupe
    08-26-2011 12:56 PM #26
    I am curious how you determined that the head gasket was blown? I have been working on 1.8T's for a long time, and have never seen a 1.8T actually blow a head gasket. I have seen coolant related issues from overheating, and a bunch of turbo-related problems that were blamed as bad head gaskets, but never actually seen where the gasket failed. The 1.8t head clamps on so well, in so many points, it is one of the 1.8T's strong points for sure.
    Your build looks to be coming along well, nice looking car too. Curious also why you chose the 3076? I know that is a great setup when paired with a 2.0L displacement upgrade, but I didn't see if you were increasing displacement to 2.0L? We orignally ran the ATP 2871R kit in a 1.8L, but we replaced the ATP manifold with a better manifold after a year or so, and it made 413whp, and ran 11.26 in the quarter mile at 127mph. Not bad for FWD. We also run the Uni BT software, it is the best (IMHO).
    Keep up the good work.
    2001 Audi TT Coupe, Amulet Red, Summer Project 2011. Mods are... KSport Coilovers, Staggered Miro 111 Concave Wheels (Front 18x8.5 with 20mm Adapters, et20, Rear 18x9.5 with 18mm Adapters, et17), Modshack VTDA Intake (Uni Stage 2).
  27. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    08-26-2011 02:45 PM #27
    Quote Originally Posted by beetlevdubn View Post
    on the headgasket thats what the shop said.i have a lot of oil in my coolant my coolant it is black and the first shop i had rebuild my stock motor said they had to retorque the head becase it was leaking.the shop i deal with now told me you dont retorqe the 1.8t heads thats why i dont deal with that other place any more .i got horror storys for days now i found a good shop thank god!!!!! for the 2871r on a stock motor and clutch i only put down 290 awhp with revo 550 and meth now im going uni 830 .and the 413whp u got thats great wish i got those numbers
  28. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    08-26-2011 03:08 PM #28
    I think you might have some incorrect information. The head torquing procedure changes on what type of hardware you are using.
    If you're using studs you absolutely MUST re-torque the head after one heat cycle. No questions asked it's in the ARP manual and both performance shops I've went to have told me this.
    If you are using OEM stretch bolts you do not re-torque the head. I believe the same goes for ARP bolts, however, I am not sure and would like someone to confirm.
    -TCC
  29. Member MKllllvr28's Avatar
    Sep 15th, 2005
    NC
    01 tt225(parting) 01 jetta vr6 98 vr supercharged 98vr (****box)
    08-26-2011 05:06 PM #29
    Quote Originally Posted by DougLoBue View Post
    I'm running arp bolts and I have not heard this before. I'm about 1000 miles into the new motor and I'm not having any problems. I'll take a look around and see what I can dig up.
    ** Found the installation directions on there website. ARP head bolts don't need to be retorqued.
    http://arpinstructions.com/instructions/204-3901.pdf
  30. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    08-27-2011 09:07 AM #30
    Just wondering if any one has got the weight under 3,000 lbs on their tt.I also need to know when doing all deletes what needs to be resistored just looking for some info
  31. Member velocity196's Avatar
    Feb 19th, 2006
    Washington
    2006 MK4 GTI, 2012 Golf R
    09-26-2011 11:56 PM #31
    Looks great, this should make a killer street car! Providing you got uni to give you all the deletes the only thing that needs either a resister or a solenoid plugged into the electrical plug (no vacuum lines needed) is EVAP and VVT if you deleted VVT. Personally I run with the EVAP solenoid still plugged in, I just hide it, and I plugged in the gold n249 solenoid into the VVT harness and it trims perfectly. Now you'll get a code for no n75 if you choose to delete that also but no CEL
  32. Member speed51133!'s Avatar
    Aug 5th, 2002
    alexandria va/milwaukee wi
    02 audi tt 225 / mk3 jetta /audi 5000s turbo
    09-28-2011 01:06 PM #32
    got this today
    what is this for?
    ive seen DIY's of adding widebands that make no mention of this harness needed.
  33. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2011 06:45 PM #33
    Quote Originally Posted by speed51133! View Post
    what is this for?
    This is a wideband harness its plug and play check out their web site
  34. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2011 06:46 PM #34
    It just makes thing easy
  35. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2011 11:02 PM #35
    I picked up these wheels this weekend for $600 what u think and I found a pic with them on
    What do u guys think their 8 5 in the front and 9 5 in the rear
