Page 15 of 19 FirstFirst ... 5 11 12 13 14 15 16 17 18 19 LastLast
Results 491 to 525 of 636
Thread: Audi tt bt build almost done I guess?
  1. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    09-28-2012 09:48 AM #491
    Quote Originally Posted by 20v master View Post
    Probably about 42-4300 rpms.
    That's not to bad I just want to hit 500whp will see what happens.I might just do a billet wheel
    On the gt3076r
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  2. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2012 09:51 AM #492
    Quote Originally Posted by DougLoBue View Post
    GT 35 is going to have a lot more lag IIRC. I'd stick with what ya got personally.
    Are you going 2.0 Rick?
    Oh and I lowered my compression to 8.5.1
  3. 09-28-2012 09:54 AM #493
    Rick, I agree with Adam! Don't waste money on parts that are not needed or are so expensive for limited returns. Just focus on getting the car running first.
    You were blowing sparks because the gap you were running was too large for the cylinder pressure (mostly a factor of boost). This would have happened on most coils (the ls1 coils are a lot stronger but not necessarily needed). If anything, you can contact Toby Lawrence (Tobs@postrelease) for an almost plug and play option of the Ls1 setup of a fraction of the cost (he makes pigtails and harness connectors that makes that option pretty darn easy).
    I'd also stay on the turbo that you already have, the increased displacement will make it a much more rounded setup. Terminal HP on paper is nice for bragging rights but a wide and solid powerband takes the crown any day.
    If I were you, the only area I spend on (and it is very budget minded) is a direct port water injection setup. Scott at USRT has everything needed as a kit. This will ensure that you have up to par knock suppression and most importantly proper distribution. Throttle body or pre-TB injection always lack even cylinder distribution (first runners getting less juice than the rest). If you call Scott at USRT, tell him I sent you and he'll take care of you.
  4. Member
    May 7th, 2009
    02 TT 180Q (daily), 01 TT 225Q (on jackstands), 03 20thAE GTI (daily), 03 GTI 1.8T (on jackstands)
    09-28-2012 09:56 AM #494
    I was hoping you'd chime in and agree.
  5. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2012 10:03 AM #495
    Quote Originally Posted by Marcus_Aurelius View Post
    I give them a call today thanks for the heads up I'm just trying to cover everything that had a issue
    And upgrade what I can and maybe get some more HP in the process lol!!
  6. Member
    May 7th, 2009
    09-28-2012 10:06 AM #496
    Quote Originally Posted by 01ttgt28 View Post
    This is what we mean. This is the fast approach to wasting money. Do you even know why it blew up the first time? I'd hope you've addressed that before looking for more power.
  7. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2012 10:32 AM #497
    Theirs a couple theorys. I have been talking with ie. And 034 and alex
    If the meth ran out that would be a problem. But it didnt theirs still fluid in
    The tank and my low level light didnt come on so maybe the pump i font know ie whants me to send
    The dyno with air fuel. They did say my timming of 13 degres was. High for
    Pump gas and meth they also said with my head and what's done to it
    I should have no problems rev to 8, 000 rpm this is what ie told me
  8. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2012 10:41 AM #498
    Also fueling might be a issue i need to find out duty cycle at that power level
    I asked ie about a surge tank they didnt think it was needed and to me a extra 1, 000 or 2, 000
    Dollars is just piece of mind so my next step is taking maxs advice and calling
    Usrt
  9. 09-28-2012 10:56 AM #499
    As a guess, I would say it's a result of one of the following things or perhaps a combination of them:
    -Very inadequate crankcase ventilation that pressurized the crank to dangerous levels
    -Reving this motor too high
    -Weak water injection system that may have struggled high in the rpm (Fabian and I only ran the motor to 6500 rpm on the dyno)
  10. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    09-28-2012 01:56 PM #500
    im leaning more to the weak water injection thats why i got the fail safe but i have been talking with ie and 034 you know they say it could be this or that will see def have to fix the crank
    ventilation
  11. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-02-2012 08:05 PM #501
    One new part today momo
    Should be more stuff tommarow
  12. 10-03-2012 12:19 AM #502
    One new part today mono
    and your still married LOLOLOL
    where do you find women like that......
  13. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    10-03-2012 07:27 PM #503
    My first motor was a 1.9L - stock crank with 83mm CP pistons. Sorry to say the lag reduction you have will be minimal. The increase in power and reduction in lag we get is from the longer throw of the 2.0L crank. At least that's my understanding.
    bagsarefordeadhookers
    -TCC
  14. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-03-2012 08:36 PM #504
    With the 1.9 and the fully built aeb head its got to be better not that it was bad
  15. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-03-2012 08:40 PM #505
    Quote Originally Posted by WhanAB View Post
    Its easy buy them a big house a nice car and let them stay home and go shopping when they want
    Happy wife is a happy life
  16. Member
    May 7th, 2009
    10-04-2012 11:07 AM #506
    Yes, there's a torque advantage of the longer crank throw on the piston. The bore helps, but not nearly as much as the stroke. Going from OEM 1.8 to 2008cc was SOOO nice on driveability. 11% doesn't seem like much, but it made a noticeable difference out of boost, whereas the bore increase along won't do that.
  17. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-08-2012 06:37 PM #507
    New parts today coil packs some assembley required
    And spacer from 034 for the aeb head
    Spark plugs 034 recommended for their coil packs
    Part number on the box their Bosch
    Sorry for the crappy pic u think the galaxy s3 would focus better
  18. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-08-2012 06:44 PM #508
    More parts are on the way just got delivery conformation from brett at whanab.com and more
    Parts from ie on the way
  19. 10-08-2012 07:18 PM #509
    on those plugs!
    Do your homework Rick
  20. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-08-2012 08:21 PM #510
    on those plugs!
    Why u think their bad their only $5 each ?they said they use them on their big HP cars
  21. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-08-2012 08:31 PM #511
    on those plugs!
    What's up with usrt I was going to order the kit but told me the block that splits the lines is blue not that big of a deal.He told me their still in the making but what killed me was I whent to order the kit online and one
    Pic the lines and everything looker great and the other had red lines.so when I order it do u
    Know what it looks like ???
  22. 10-08-2012 09:29 PM #512
    You're going to have a fun time gapping those accurately on a consistent basis. Search and you'll come up with many returns of cars running horribly as a result of these plugs.
    The picture with the red synflex lines is from John's car. Everything is going to be black except for the distribution block that is blue for now (until the kit is finalized with matching distribution block). If it matters, you can send the distribution block to me and I'll powder coat it for you free of charge.
  23. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-08-2012 09:46 PM #513
    Dame that sucks i. Always order crap oh well
    The block was no big deal i just didnt whant blue block and red lines
    So i will order it tommarow thanks
  24. 10-08-2012 09:49 PM #514
    Cool, tell Scott I said hello!
  25. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-08-2012 11:07 PM #515
    He whants me to order it of the website not over the phone
  26. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-12-2012 09:14 PM #516
    Got in my new dog bone mount solid from carbid01 great price $65
  27. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-12-2012 09:39 PM #517
    Will post pics having some problems ?????
  28. Member
    May 7th, 2009
    10-13-2012 07:27 AM #518
    Haha, I sold that to him a long time ago.
  29. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-13-2012 07:56 AM #519
    Nice got it for $65 shipped why did u get rid of it to much vibration???
  30. Member
    May 7th, 2009
    10-13-2012 08:22 AM #520
    I had no problem cutting 1.7-1.8 60' times on slicks in my FWD BT GTI with dogbone inserts and both VF side mounts, so didn't really see a need for it. While it's certainly makes things feel "crisp" in terms of throttle response and shifting, get ready for floor board foot massage.
  31. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-13-2012 08:29 AM #521
    Lol I give it a try the VF mounts have been great
  32. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-13-2012 08:36 AM #522
    I hate waiting for parts they take so long or maybe I'm just inpatient
  33. Member
    May 16th, 2006
    Regina/Calgary
    '02 TTQ (RIP); '06 3.2Q A3
    10-13-2012 01:43 PM #523
    Everyone does! A buddy was looking at my car the other day, asking how much I've spent (clearly trying to make me depressed), and I figured that I must have spent $1000 in just shipping stuff for it alone, half of that being because I paid for overnight
    Jeremy Brehm: Regina Wedding Photographer
    '02 Audi TT 225 Build Thread - 2.0L - PTE6262 Daily @ 30PSI - 10.0:1CR - AEB @ 9000RPM - Maestro - RIP
    '06 3.2Q A3 - Stay tuned!
  34. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-15-2012 07:33 PM #524
    Thank god I got some parts in
    Gates belt,head gasket over bore,coated main bearings
    The gates belt is def great quality
  35. Member artur vel 2 hoot's Avatar
    Nov 25th, 2006
    Chicago - Schaumburg IL
    10-16-2012 02:13 AM #525
    Good stuff I got exactly the same parts
    Black TT225q , APR Stage 3+ ( GT2871 ) w/ Eurodyne -Tapp 630cc and a lots of mods
    New Stage Build : http://forums.vwvortex.com/showthrea...Audi-TTquattro
