Page 2 of 19 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 636
Thread: Audi tt bt build almost done I guess?
  1. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    10-04-2011 08:52 PM #36
    Not to much progress but some thing got the valve cover painted timing belt on sai block off plate cut the bracket that holds the power steering pump ie dowel pin installed. deleted the factory oil cooler
    Anything u guys think I should do or any input is all ways appreciated
  2. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-26-2011 06:17 PM #37
    Some new pics
  3. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-26-2011 07:15 PM #38
    So the motor is in Alex from Wentworth motor sports is going to be fabing up the down pipe
  4. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-26-2011 07:18 PM #39
    And how the Turbo is sitting
  5. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    10-26-2011 07:20 PM #40
    I can hear turbo spool right now. god it's glorious.
    bagsarefordeadhookers
    -TCC
  6. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    10-26-2011 08:00 PM #41
    Why smallport?
  7. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-26-2011 08:14 PM #42
    I don't know but its my first build and we did all super tech springs retainers and inconl exhaust valves autotech cam gear. I'm kinda kicking my self in the butt because I didnt do cams will see what happens
    hoping to get close to 500whp
  8. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-26-2011 08:16 PM #43
    Quote Originally Posted by DougLoBue View Post
    Did you every swap out your motor
  9. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-27-2011 07:46 PM #44
    Got the intake Plenum today
  10. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    10-28-2011 09:00 AM #45
    Quote Originally Posted by 01ttgt28 View Post
    I didn't-- I kept adding things to the list. Last week I decided to do ACL coated rod bearings instead of OEM. This week I just got a brand new cam tensioner in because I saw a thread with a failed one last week. All that's left is a decision on manual or hydraulic timing belt and I'm done... or so I think
    -TCC
  11. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-28-2011 09:36 AM #46
    Yeah right you will never be done.I tell my self that all the time and I keep adding things.I'm addicted lol!!!
  12. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    10-31-2011 06:02 PM #47
    Happy Halloween
  13. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-09-2011 08:28 AM #48
    Anyone have problems with the 034 catch can. it hits the ABS pump and won't clip on
  14. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-09-2011 09:04 AM #49
    That's the exact issue I had. In my blackholed buildthread I had documented it as well as emailed 034/INA about it with no direct resolution. I later sold the catch can and decided to go custom. The location of the vent makes for a horrible smell in the cabin.
    If you can I'd return it now for a full refund. The setup also sucked oil vapors into my intake manifold causing it to be flooded with oil over and over again until I disconnected the one way valve they had on it and plugged both the 034 line and the intake manifold.
    -TCC
  15. Member PLAYED TT's Avatar
    Oct 17th, 2010
    Reading, PA/ Williamsport, PA
    A German thing, and a not so German thing
    11-09-2011 09:05 AM #50
    I try to stay away from there stuff. It's not the best I've heard.
    Slammed Radio Flyer---flickr---My Build Thread 99% of you are idiots therefore I hate you
    Quote Originally Posted by Marcus_Aurelius View Post
    How much lower can you go when you're already scraping stuff??? Soon you'll have the first subterranean vehicle if you keep chasing that goal
  16. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-09-2011 11:25 PM #51
    Do u think I can shim the ABS bracket to make it go lower so the can could fit.I don't want to brake a ABS line just woundering
  17. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-09-2011 11:43 PM #52
    Just wondering if any one has ever done a ABS delete and is it bad to delete????
  18. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-09-2011 11:55 PM #53
    What do u guys think of this billet wheel for the gt3076r its $160.00 on ebay
  19. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-10-2011 08:30 AM #54
    I've driven my car with the ABS sensors unplugged - they were having issues and locking my brakes up at speed. It wasn't safe. I had to slam on the brakes because someone cut me off and at only 30mph I skidded for a few feet with blue smoke instead of stopping.
    With the catch can I always planned to make an S shaped bracket for the bottom mounting piece out of some cheap home depot metal and use on the top a vacuum line as a large washer and a long bolt/nut to hold it down. You could try that if you want to keep it?
    -TCC
  20. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-10-2011 07:36 PM #55
    Got some new parts in from jrm fabrication their billet nice
  21. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-10-2011 07:41 PM #56
    Does your tt have the ESP button?
  22. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    11-10-2011 08:26 PM #57
    I don't have traction control on my TT so no ESP button
    -TCC
  23. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-10-2011 08:47 PM #58
    So if u delete ABS you think it would brake funny? I thought it would be like driving my dads Chevy back in the day
  24. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    11-10-2011 08:49 PM #59
    So has anyone tried this wheel or is it junk
  25. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01-27-2012 02:37 PM #60
    hows the project going man?
    -TCC
  26. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    02-02-2012 11:18 AM #61
    not that great its kinda taking the back burner a little.i had to get a new winter beater mine was acting up pretty bad im going to miss her
  27. Member PLAYED TT's Avatar
    Oct 17th, 2010
    02-02-2012 11:55 AM #62
    That's a cool daily
  28. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    02-02-2012 02:42 PM #63
    this is my new one i just picked up some 24s will see
  29. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    02-02-2012 02:45 PM #64
    also got arp cam bolt and all the resistors for all my deletes
  30. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    02-02-2012 02:53 PM #65
    i need to figure out what color for the calipers i was thinking of going with silver.what do u guys think.they look pretty messed up
  31. Member Audiguy84's Avatar
    Nov 14th, 2006
    messing with Texas
    01 Audi TT roadster, 02 Audi TT coupe
    02-02-2012 03:07 PM #66
    What color is the car? If car is silver or white - do a gold color, if black its up to you on that.
  32. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    02-02-2012 03:16 PM #67
    I like the cam bolt- could you link me to that?
    -TCC
  33. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    02-02-2012 07:31 PM #68
    Quote Originally Posted by Audiguy84 View Post
    My car is two tone black and silver.i really don't want red that's what most people do
  34. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    02-02-2012 07:35 PM #69
    Quote Originally Posted by PLAYED TT View Post
    That's a cool daily
    Thanks I loved that truck I loved the air bags the pic is it on its lowest setting but it was a electrical
    nightmare.the doors would lock and unlock while driving and the other one I got is in the shop for a head gasket land rovers suck lol
  35. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    02-02-2012 07:42 PM #70
    Sorry for the late response but here's the link
    http://www.intengineering.com/arp-ca...t-engines.html
