Well after going from a ko3 to ko4 to gt2871r Elim my gt3076r build is almost done all work is done by alex at went worth motorsports in Brewster ma.lots of pics inside. New update to the parts list
Car is forsale $7,000 takes it just got it back today from the build
call or text 5082154857
(Engine)
Je pistons 83mm coated 8.5.1
Integrated rods 20mm.
Ie 83mm head gasket
Acl coated rod bearings.
Acl coated main bearings
Southbend stage 5 clutch single mass flywheel
Arp Turbo and manifold studs
Arp rod bolts
Arp cam bolt
Arp head bolts
Diesel geek sigma 6
Billet dipstick and funnel(wanabe)
Jrm billet heater core fittings
Jrm billet thermostat housing
Jrm billet coolant flange
Gates racing blue belt
R8 oil cap
new radiator
New alternator 90 amp
Ie billet light weight alternator pully
New oil pump
New water pump metal impeller
Fluidamper
Garrett Gt3076r 63ar with polished housing
Snail turbo billet wheel
Kinetic top mount manifold
Turbo blanket eBay
Tial 38mm waste gate
Mad max dv
Turbo smart mbc
Vibrant fmic custom ss pipes
Front mount oil cooler
Braile battery 11.5 lbs
034 coil pack ss heat shield
034 ls1 coil pack conversion
034 transition spacer
Vibrant catch can
Apr in take fuel pump and a walbro inline
C2 motor sports fuel pump kit
Nitrous fmic spay and purge
2 14" mishimoto fans
Low temp thermostat
Low temp fan switch
Mishimoto rad hoses
Ie ful rail black
Ie fpr adaptor
Sai block of plate
Inconel exhaust valves
Supertech intake valves
Supertech Titanium retainers
Supertech springs
Aeb head
Integrated crank dowel pin kit
Cat cam gear
Abd manifod runners welded to excessive plenum
Unitronics wide band 830cc file sai delete and maf delete vvt delete
Race line wide band harness
Hemi throttle body 80mm
Vf mounts
Solid dog bone mount
Madmax direct port meth
Snow stage 3 water meth. And fail safe
3"turbo back no cat no muffler with ss vibrant tips
Power steering delete
AC delete
(Interior)
Corbeau forza seats black
Corbeau five point harness silver
corbeau harness pads
Rear seat delete custom made
Stable engineering harness bar
shift light
Euro lower dash lighter with pockets
Momo steering wheel
Ash tray romoved for nitrous panel
Generic boost af ratio gauge in pillar pod will be changing the gauges
Wot box in the column with USB in fuse panel
Nitrous bottle in trunk painted to match silver
Snow performance Meth display under ashtray
OEM seat belts removed
CD changer removed
spare and tools removed
Radio and speakers removed
(Suspension)
034 solid sub frame mounts
034 density pillow mounts
Gtt aluminum upper strut brace
H&r rear adjustable sway bar
ta technix coilovers rear adjusters out and upper perch removed
Euro sport lower tie bar
Black forest rear control arms (bottom
Cpt rear control arms (top)
Blue Haldex
42 draft 30mm front 20mm rear adaptors 5×100 to 5×130
Wheels Porsche 997 8.5" front 9.5" rear they might be reps
Brakes Porsche boxer front paint black tt stickers
Hawk hps pads front
Pbr rear pads stock rear caliper
All braided ss lines
Cross drilled sloted rotors
(Engine)
Ie 83mm head gasket
Arp rod bolts
Arp cam bolt
Arp head bolts
Diesel geek sigma 6
R8 oil cap
new radiator
New oil pump
Fluidamper
Turbo blanket eBay
Mad max dv
Turbo smart mbc
Vibrant catch can
Low temp thermostat
Low temp fan switch
Mishimoto rad hoses
Ie ful rail black
Ie fpr adaptor
Sai block of plate
Supertech springs
Aeb head
Cat cam gear
Vf mounts
AC delete
(Interior)
shift light
Momo steering wheel
CD changer removed
(Suspension)
Blue Haldex
Hawk hps pads front
