Just looked them up to see if I could find them online, they look like this. Pretty sure these are it:
http://www.ecstuning.com/Audi-B5_A4-...oys/ES2142877/
#1
Quick question - getting a decent deal on some rims and tires and I just wanna see if anyone put Audi rims on their Jetta? If so, do you have any pics? I made sure the bolt pattern was right (5x112) but I'm not sure about offset.
#2
#3
yes, they will fit but they are called wheels. Basketball players and rappers call them rims.
Follow my MK1 build on Instagram. User name: jkrew or http://ink361.com/#/users/322773/photos
#4
They are called wheels.
They are 16x7 +42... Essentially, they will fit but they are too small to look good.
#5
If you are gonna buy new "Wheels", you should definitely upgrade and fill up those fender wells. Another thing you should check when seeing if wheels will fit is the hub opening diameter, which will tell you if u need hub rings or not. Not really that important when comparing VW and Audi because most of them are 57.1 mm. But, when buying aftermarket wheels you should definitely check it. And with aftermarket wheels you also need to know if they use conical seat or ball seat lug bolts.
#6
#7
Audi wheels will fit nice if you stick to similar sizes of your oem set up. 5x112 bolt pattern and similar offsets. Id go no bigger than 18's w our cars man. Im running audi wheels and theres a thread on here somewhere. Search "dubs on audi rims" or somethn like that. Dont do 16's unless theyre 3 peice deep dish bbs' or somethngood luck man
AKdub | INY | THREE.8.WERKS...Ferdinand's Crew
Eurothon11 6.16.13 > @GPNY mt.kisco NY come test your true driving skills on the track!
#8
Tomas Sport Tuning + Bag Riders = BAGS & BBS RS
#9
FWIW, I call them rims or wheels somewhat interchangeably, but I tend to stick with rim even though I am the complete opposite of a basketball player or rapper. Basically, rim + tire = wheel. If you buy a rim, you don't expect to get a tire, too. If you buy a tire, you don't expect to get a rim, either. If buying take-off wheels, I'd expect to get rims and tires. However, is the thing in the trunk called a spare tire or a spare wheel? Anyway..
I picked up a set of those wheels as seen here...
The tires are 215/55 instead of 205/55 so they look a little puffy compared to the stock size.
They are 7x16" et42 as compared to the stock 6.5x16" et50. If I did my math correctly, the outer edge of the rim sticks out about ~14mm more than the stock rim. Here are a couple more pics to show the 'poke'...
#10
#12
Well, I'm going from steel wheels (with caps) to these Audi ones. I'm pretty sure the steel ones I'm using are 15". You still think they would be too small? I'm not looking to make the thing look gorgeous by any means at the current moment, but I'd like to upgrade to alloys prior to do some of the work I'm planning on (replacing taillights, etc.)
#13
Yea its prettymuch persal prefrence. You should be good with any size that sticks to a close diameter as OEM. Anyone correct me or chime in if im wrong here. Just helpin with what i kno
#16
Unitronic stage 2+
DubCreationsNY.com
..:SOWO '12 survivor:..
#19
I like the sleeper look of the 16" wheels.
I found a decent set of 1999 a4 7 spoke rims/wheels for less than new steelies.
I want to use these for winter tires on my 2008 jetta. Being 16" x 7" with a 45mm offset, technically i should be able to get away with some 225 50 r16 in the wheel wells without any rubbing?
what do you guys all think? should i just stick to the 205's?
http://www.wheels-and-rims.com/images/ALY58719U.jpg
