VWVortex.com - Oil light flashing when cranking won't start.
    Results 1 to 4 of 4
    Thread: Oil light flashing when cranking won't start.
    1. n00b
      Mar 3rd, 2009
      Laporte IN
      95 2.0 Jetta 5 speed.(Deceased) 98 2.0 Jetta Auto
      03-06-2011 10:58 PM #1
      I left school last night to come back home for break and it was snowing out and the roads were slushy. I drove for about 10 miles when i lost power and the car bogged down and died. It will crank but not start. The oil light flashes when you are cranking. I've changed all four spark plugs in case water got into one of them but still no luck. Any help would be appreciated.
    2. n00b
      Mar 3rd, 2009
      Laporte IN
      03-10-2011 01:09 PM #2
      Tried an ignition switch and am still having no luck. Any help?
    3. 03-10-2011 01:49 PM #3
      check your oil pressure, may possibly need new oil pump
    4. n00b
      Mar 3rd, 2009
      Laporte IN
      03-10-2011 04:06 PM #4
      I removed the top oil pressure sensor and tried cranking and oil was running out. When it's about to start it backfires. I'm going to see if i can do an oil pressure test later today.
      Edit: I also replaced the ignition coil which is making it want to start more but it backfires.
      Update: The ignition coil did do the trick. The "reliable" ignition rotor from autozone broke but replaced it and the engine fired right up.
