Results 1 to 21 of 21
Thread: Need some ideas and info... 1.8T, RWD, Powerglide, MK4 :)
  1. 03-07-2011 10:57 AM #1
    here is the deal. I am building a RWD Mk4 jetta drag car. Built 1.8T, crazy AEB head, ford 8.8 spooled 31 splines, 4.10+ with 26" tires, ladder bars and coilovers, and a powerglide in the middle.
    I am trying to figure out the converter. Assuming you want the lock up to occur just prior to full tq I am having trouble coming up with a stall speed, since the lil 4 banger makes tw right up to redline. my last setup with a 3076R .83 spooled up 26psi at 4100 and tq really took off around 5K and went right up until redline nice and steady. the turbo I wanted to run this time was a PT6262 .83 est. 26psi or so around 4500. the cams in the head are schrick jobbies that came with the solidlifter conversion, so I cant seem to find too much data on where they make power. I had the grind numbers somewhere when I bought the head, but I dont have them off the top of my head to compare them to a CAT or something more prevalent.
    what do you think? Anyone with automatic transmission experience something like this? lol
  2. Member XXX008XXX's Avatar
    Mar 25th, 2002
    2000 GTI 1.8t, 72 Standard Beetle, 95 Eagle Talon TSI Auto, 2002 Chevy Tahoe
    03-07-2011 04:26 PM #2
    honestly, talk to buscher, the dsm guy. kind of similar motor and they have some cars out there running GM trannies.
    10.30@145 .68 35R
    10.08@141 / 148
    Force Fed Engineering
    Lugtronic
    Boost Factory
    Jul 26th, 2001
    PA
    93 Passat VEEARRRRRRRRR
    03-08-2011 12:43 PM #3
    #1 screw-up the converter guys will do is give you way too low of a stall. 75% of the people who try to run auto trannies on VW's end up with a 2,200 rpm stall, lol.
    Tell the converter guy that you want the engine to run between 6,500 and 9,300 rpm or so, and let them do their job.
    Lugtronic.com
    Eurodyne Maestro Tuning, Stand-Alone ECU Install/Tuning/Wiring Harnesses
  4. Member 71camaro's Avatar
    Apr 20th, 2009
    Cambridge, MD/Penn State
    MK4 GTI VR6(rip)/ Gen2 Camaro Z28/ MK2 Jetta(rip)/S2 Scirocco 16v/S2 Scirocco/D2 S8/ '95 GMC
    03-08-2011 01:01 PM #4
    I can't help, but in for pics/vids
  5. Banned xtremvw2's Avatar
    Nov 27th, 2010
    fort myers fl
    2001 vw golf drag car
    03-08-2011 07:15 PM #5
    yeah when i had my auto i ask tcs converters to give me a 6500 and i could not get it to go pass 4400rpm
    sent it back 3 times never any changes, making low end torque well also affect the converter
    Coan racing know what it takes for small cc engine to stall to higher rpm they did alot of those on fast 4cyl
  6. 03-09-2011 11:44 AM #6
    first off **** buscher racing.
    I know they make an adapter kit (way over priced) to put a GM trans on the 4G63 stuff. And I heard some people asking for his services willing to pay for something and they got a run around and never got anywhere.
    http://projectzerog.com/
    they do alot of those swaps. Bill H on there made his own adapter plate and crank adapter and has been doing so for a while, many are running around now without any issues, and he did all the R&D himself and make them at damn near cost to support the sport and his group! I e-mailed him and he got back to me in less than an hr and we went back and forth a bunch of times in the last 2 days, sharing ideas, i got a great feel for what to do and he told me what he ran into as for problems and how to get around them! MAJOR rep points for Bill!
    I found all the dimensions for the 2 motor/bellhousings. the chevy is a piece of cake and hasnt changed from the beginning of time to the LS motors.. chevy 90 deg they call it. The 1.8T is a little harder. I found one draw online for the 1.9L which should be the same block and all the dimensions I need to make the adapter plate. Lay out both patterns, concentric to the crank centerline and there I go, trans to block is done. then do my measurements to get the tq converter placed right and make a crank adapter.
    chevy sb bell housing dimensions: http://forums.hybridz.org/index.php/...rn-dimensions/
    another: http://www.race-dezert.com/forum/sho...hole-locations
    1.9 tdi engine drawings:
    http://www.haywood-sullivan.com/vanagon/TDI/
    If someone has the 1.8T bell housing and crank centerline measurements, I would UPS a case of beer to you for them!!!
    as for the converter, since the adapter plate and crank adapter surfaces will be OEM chevy specs (dimensions wise) I can use any converter I can find. No need for some custom jobber, plenty of good over the counter units. TCI I think sells them up to a 5500 stall or so irc. I will still be contacting the guy in PA, and the other 4cyl guy you mentioned here also and compare results.
  7. 03-09-2011 11:47 AM #7
    ohh and at project z g alot of those guys are stalling 5000-5500 or so. for what its worth.
  8. 03-09-2011 07:18 PM #8
    I went through the same problems for weeks, trying to find a good torque converter and what stall speed to use for drag racing my 2.0 16v GTI. Without dyno charts of hp and most importantly the torque curve, almost all converter builders that I'd spoke with said I'd be throwing my money away. If I changed cams, it would affect my stall, so go buy another converter! I spoke with PCS and was told with their automatic trans controller that I could program the TTC to lock-up at what ever RPM I wanted. I asked Coan if this would work with the converter they built for me and was told maybe not. PCS saying yes and another saying no. I "gambled" and went for it. With the PCS, I can program my converter to lock-up at my desired MPH and RPM. You can also shift using push buttons on the steering wheel (paddle shift), manual stick shifting or let the trans shift itself. I hope this info helps. FYI my stall speed lock up is 6800 RPMs and was told this was too much because some of the GM 4cyl racers used 4500 RPM stalls. I can lock-up at 1000 RPM if I want. Just make sure your trans is an electronically controled auto trans and not a purely hydro-mechanical transmission if you decide to use a transmission controller. It's alot cheaper in the long run. Especially if you change turbos, replace cams, decrease car weight etc.
  9. 03-14-2011 12:02 PM #9
    Thats some cool stuff! I will have to look into that.
    I know the glide is not a electronic controlled trans so its a no go for me I guess. But still good information!
    thanks!
  10. Member DIRTYMOFO's Avatar
    Oct 13th, 2003
    Eastcoast
    81 CADDY MTDI, 01 1.8T AVANT, 91 E30
    03-20-2011 08:54 AM #10
    Quote Originally Posted by Rolando 101 View Post
    hey rolando, you get that thing straight yet? Sold my Mk3 since the last time I seen you at the track rental. I may go rwd this time or play with this audi quattro I got. Let me know when you go back to the track this year...
    I QUIT FWD SUCKS
  11. 03-21-2011 01:58 AM #11
    Quote Originally Posted by DIRTYMOFO View Post
    It finally passed all "LABORATORY" testing last week. Next, dyno testing, then test & tune at capital. I'll keep you posted.
  12. Banned xtremvw2's Avatar
    Nov 27th, 2010
    fort myers fl
    03-21-2011 09:02 AM #12
    pm sent
  13. Member
    Dec 14th, 2001
    Greensburg, PA
    03-21-2011 09:30 AM #13
    Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
  14. Member zcxerxes's Avatar
    Nov 13th, 2005
    64 notchback, 87 scirocco 16v, 93 corrado
    04-14-2011 12:15 AM #14
    Call quicktime bellhousing. Www.quicktimeinc.com from my understanding they can adapt any engine to any trans. I plan on making my own vr6->tr6060 adapter but if it doesn't hash out I will be contacting them to assist.
    Buscher is just up the road from where I live. They are most def pricks but if you ask the right questions they are usually pretty straightforward with getting it done. I can speak from personal experience that when you walk in there door they are not too fond of vws.
    Best of luck on your quest.
    sometimes you have to do $hit
    aircooled abomination
  15. Banned
    Feb 15th, 2010
    '03 1.8T Jetta
    04-14-2011 10:14 PM #15
    ^^^^^^^^ hahaha
    you are a little late for that
  16. Member zcxerxes's Avatar
    Nov 13th, 2005
    04-14-2011 11:03 PM #16
    Guess so. Glad its so funny.
  17. Member zcxerxes's Avatar
    Nov 13th, 2005
    04-15-2011 06:52 PM #17
    Wait...I hope I am late for the quick time comment because if I am late on the vr6 to tr6060 then I need to know who has that adapter so I can get info
  18. Member zcxerxes's Avatar
    Nov 13th, 2005
    04-15-2011 07:28 PM #18
  19. Banned
    Feb 15th, 2010
    '03 1.8T Jetta
    04-16-2011 11:33 PM #19
    Quote Originally Posted by zcxerxes View Post
    late for QT....
  20. 08-12-2012 03:17 PM #20
    Quote Originally Posted by kkkustom View Post
    Normally in an automatic trans, you will never have the lock up at full throttle! That feature is just for coasting speed to increase mileage. For full power pulls you want the turbine doing its job.
    However there is a turbine from YANK that has multi disc lock up system that can hold WOT but it is freaking expnsive.
  21. Member A2TDI's Avatar
    Apr 8th, 2004
    MK2 wannabe Drag car
    08-13-2012 06:28 PM #21
    i think a 6000 stall with a 2 step would work fantastic! stall that thing as high as you can! i can only get the stock vw converter to stall at 4100 rpm..
    90 4 dr jetta 2L 20V hx super 40 at 30 psi 11.28 @ 129.1 mph 2360lbs
