VWVortex.com - 98 VW Jetta Manual Transmission Won't Go Into First or Fifth Gear!!! HELP PLEASE!!!
    Results 1 to 10 of 10
    Thread: 98 VW Jetta Manual Transmission Won't Go Into First or Fifth Gear!!! HELP PLEASE!!!
    1. n00b
      Feb 3rd, 2011
      Raleigh, NC
      1998 Jetta GL
      03-07-2011 03:22 PM #1
      The subject of this post basically sums up my problem: My 98 VW Jetta GL's manual transmission won't shift into reverse or fifth gear. I have no problem shifting into first, second, third and fourth gear; but it's absolutely no dice on reverse and fifth. I got a quote from a transmission specialist that it owuld be around $500 just to get the transmission out to diagnose the problem. I found a used transmission with high mileage at a local salvage yard for $550. I really just don't know what to do! Could their be something simple or small causing the transmission to not function properly? Should I try and have it looked at somewhere else, or should I just go for a new transmission? Is it wise to buy a high-mileage used transmission, or is it worth it to put a newer one in there? I found some used ones cheaper on ebay, but that seems risky. Any experience there? I am a layman when it comes to automobiles, so I don't even know where to start. I put $1000 over a year ago into the car, and want to keep it running, I just don't know if it's worth putting another grand or so into. Please use your expertise and know-how to help me figure out what could be wrong, and what step to take next. Thanks!
    2. Member jameslol's Avatar
      Aug 30th, 2010
      Baltimore Md
      03-08-2011 11:20 PM #2
      I'm sorry but 500 dollars to just pull the trans is pretty expensive, i got a quote to install (including clutch price) a clutch for about that much.
      Find a local shop that deals with euro's. Google will be your friend!
      89 Mk2 Black GTI Vr6.
      92 Mk2 Red Jetta GL 8v digifart.
      RIP 98 Mk3 Black Jetta GLX.
      RIP 99 Mk3 Silver Jetta Wolfsburg Ed.
      Mar 1st, 2007
      the Hill, PA
      Doris 04 tdi, boris 79, wascal e. wabbit 84, beatrice 90, racecar 80, 84GTIx3. creme dream 81
      03-08-2011 11:56 PM #3
      how much you want for the car?
      Quote Originally Posted by Deutschbag
      .....remind me not to IM anyone about anything important past 8pm on a Friday night.
      M.C.M.S. #1
      Dead Rabbit Society: cultured 'n isht.
    4. Geriatric Member JUS_GT_EYEZ's Avatar
      Nov 12th, 2001
      NY/NJ
      Green MK1, White Rocco, Red Mk2,Yellow Mk4,Grey Wagon
      03-09-2011 02:41 PM #4
      Quote Originally Posted by tSoG-84bit View Post
      OP, do a search on aligning shift linkage on the golf 3 forum.. GL should be an 8v and have shift linkage not cables. A quick overhaul should get you back on the road.
      "Its cool to spool, but I'd rather be blown.." - JUS_GT_EYEZ
      My FLickr <-- DUKEDLF
      Digital.Life.Form
    5. Member VWRedux's Avatar
      Jun 3rd, 2009
      Potomac Maryland
      Started NHTSA DSG Campaign/'09WolfieDSG died@623mi. VW took it back.Bought MkVI/GTI Blk 6spMT/SR/Xen
      03-10-2011 08:54 AM #5
      Quote Originally Posted by JUS_GT_EYEZ View Post
      ^^^ This!
      "There's nothing like a well tuned car on an open road". Paul Newman
      *The New 2011 VW Jetta... At Least You Pay Less To Get Less!*
    6. Member
      Mar 1st, 2007
      the Hill, PA
      03-10-2011 10:56 AM #6
      could be a TDI, and cables. doubt it... but jus sayin...
      M.C.M.S. #1
    7. Geriatric Member JUS_GT_EYEZ's Avatar
      Nov 12th, 2001
      NY/NJ
      03-10-2011 11:13 AM #7
      my experience, if its a diesel or a vr6 it gets mentioned in the post. If not mentioned?... it's a 2.0...
      Digital.Life.Form
      Mar 1st, 2007
      the Hill, PA
      03-10-2011 11:28 AM #8
      I agree, but... either way... I wanna know what the OP wants for it.
      M.C.M.S. #1
      May 12th, 2005
      Central Ohio
      94 Golf; 11 Golf; 11 Jetta;05 Camry; RIP 10 Jetta,04 Passat 1.8T&98 Jetta TDI (199,970mi)
      03-10-2011 11:44 PM #9
      I would say you ran it low or out of gear lube, or used the wrong type, and cooked some gears. A total rebuild from the best of the best is $750, so $500 is high. Just to pull it and look should be more like $250 or $300. If you do the repair to the gears, you might as well do the rest (clutch, seals, etc.), so look at $750 to $1000. The car is likely not worth that much.
      look here:
      www.brokevw.com
